Дано:
GigabitEthernet0/0/0 -pppoe провайдер
GigabitEthernet0/0/1 - внутренняя сеть
Смысл такой: - на самой Cisco интернет есть.
- в сети интернета нет.
Я понимаю, что вопрос глупый. Просто первый раз настраиваю такое оборудование.
Конфигурацию прилагаю:
Current configuration : 2400 bytes
! Last configuration change at 19:44:05 utc Wed Jan 18 2017
version 15.5
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname RO1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$7JHv$UxqJIaIPLu/gLpQl/m8ky1
no aaa new-model
clock timezone utc 5 0
ip name-server 8.8.8.8
ip dhcp excluded-address 10.10.72.1 10.10.72.50
ip dhcp pool Work
network 10.10.72.0 255.255.248.0
default-router 10.10.72.1
domain-name mkd.ro
dns-server 8.8.8.8
subscriber templating
multilink bundle-name authenticated
license udi pid ISR4321/K9 sn FDO20420PFC
spanning-tree extend system-id
username root privilege 15 secret 5 $1$Tpa2$iWimWg1XjDx
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
description LAN
ip address 10.10.72.1 255.255.248.0
ip nat inside
ip tcp adjust-mss 1412
negotiation auto
ip virtual-reassembly
interface GigabitEthernet0/1/0
shutdown
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname v1632
ppp chap password 7 031041585
ip nat inside source list 101 interface Dialer0 overload
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip 10.10.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
password 7 1311031F0
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 10 output
password 7 06121B2C
login
line vty 5 97
password 7 06121B2
login
end
Edited by kuzminalexey
скорее всего должно быть
access-list 101 permit ip 10.10.0.0 0.0.255.255 any
п.с. password 7 лучше убирать перед постами на форумах)
Password 5 тоже лучше прятать. С мощной видяхой очень быстро подбирается :)
