Собственно тестируем железку - все нравиться. Решили подумать заменить пару своих 6500 на Nexus 3064 - но вот не задача.
Никак не можем применить PBR на Int vlan внутри VRF (65 без проблем делает)
при попытке применить PBR на Int vlan внутри VRF:
% Cannot share the same route-map <PBR> among different VRFs for PBR
собственно конфиг
interface Vlan3103
 no shutdown
 vrf member dddd
 ip address 192.168.0.1/30
Nexus3064# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Nexus3064(config)# interface Vlan3103
Nexus3064(config-if)# ip policy route-map PBR
гуголь ничего не подсказывает
сам роутмап
route-map PBR deny 10
 match ip address NO-PBR
route-map PBR permit 101
 match ip address PBR-01
 set ip next-hop 10.10.0.255
route-map PBR permit 102
 match ip address PBR-02
 set ip next-hop 10.10.0.253
команд:
set ip vrf next-hop
set ip global next-hop
set ip default vrf
нету.
Nexus3064# conf t
Nexus3064(config)# route-map PBR permit 101
Nexus3064(config-route-map)# set ip ?
 address     Specify IP address
 default     Set default next-hop
 next-hop    Next hop address
 precedence  Set precedence field
Nexus3064(config-route-map)# set ?
 as-path             Prepend string for a BGP AS-path attribute
 comm-list           Set BGP community list (for deletion)
 community           Set BGP community attribute
 dampening           Set BGP route flap dampening parameters
 distance            Set the Administrative distance of route
 extcomm-list        Set BGP extcommunity list (for deletion)
 extcommunity        Set BGP extcommunity attribute
 forwarding-address  Set the forwarding address
 interface           Output interface
 ip                  Configure IP features
 ipv6                Configure IPv6 features
 label-index         Set Segment Routing (SR) label index of route
 level               Where to import route
 local-preference    BGP local preference path attribute
 metric              Set metric for destination routing protocol
 metric-type         Type of metric for destination routing protocol
 nssa-only           OSPF NSSA Areas
 origin              BGP origin code
 path-selection      Path selection criteria for BGP
 tag                 Tag value for destination routing protocol
 weight              BGP weight for routing table
