Решил лишние выпилить из src.conf
И вот какой момент вогнал в ступор:
The values of variables are ignored regardless of their setting; even if
they would be set to ``FALSE'' or ``NO''.  Just the existence of an
option will cause it to be honoured by make(1).
Значения переменных игнорируются, независимо от их установки; даже если
они будут установлены в `` FALSE '' или `` NO ''.
Просто существование опции заставит ее быть выполненной.
Т.е. если, что то мне не нужно из src.conf, то это не нужно указывать?
Именно.
Если ты написал опцию - значит будет сделано так, как написано в документации про неё.
Пример.
WITHOUT_ACCT=
# Set to not build process accounting tools such as accton(8) and sa(8).
WITHOUT_AMD=
# Set to not build amd(8) (automatically mount file systems), and related programs
WITHOUT_ASSERT_DEBUG=
# Set to compile programs and libraries without the assert(3) checks.
WITHOUT_ATM=
# Set to not build programs and libraries related to ATM networking.
WITHOUT_I4B=
# Set to not build isdn4bsd package.
WITHOUT_AUDIT=
# Set to not build audit support into system programs.
WITHOUT_AUTHPF=
# Set to not build authpf(8).
WITHOUT_BLUETOOTH=
# Set to not build Bluetooth related kernel modules, programs and libraries.
WITH_BSD_GREP=
# Install BSD-licensed grep as '[ef]grep' instead of GNU grep.
WITHOUT_BSNMP=
# Set to not build or install bsnmpd(1) and related libraries and data files.
WITHOUT_CALENDAR=
# Set to not build calendar(1).
WITHOUT_CAPSICUM=
# Set to not build Capsicum support into system programs.
WITHOUT_CDDL=
# Set to not build code licensed under Sun's CDDL.
# When set, it also enforces the following options: WITHOUT_ZFS
WITHOUT_ZFS=
# Set to not build ZFS file system.
WITH_CLANG=
# Set to build the Clang C/C++ compiler.
WITH_CLANG_EXTRAS=
# Set to build additional clang and llvm tools, such as bugpoint.
WITH_CLANG_FULL=
# Set to build the ARCMigrate, Rewriter and StaticAnalyzer compo nents of
# the Clang C/C++ compiler.
WITH_CLANG_IS_CC=
# Set to install the Clang C/C++ compiler as /usr/bin/cc, /usr/bin/c++ and
# /usr/bin/cpp.
# broken: 2013.09 WITHOUT_CRYPT/WITHOUT_OPENSSL
# http://www.freebsd.org/cgi/query-pr.cgi?pr=kern/160922
# http://www.freebsd.org/cgi/query-pr.cgi?pr=kern/164208
#WITHOUT_CRYPT=
# Set to not build any crypto code.
#WITHOUT_OPENSSL=
# Set to not build OpenSSL.
WITHOUT_OPENSSH=
# Set to not build OpenSSH.
WITHOUT_KERBEROS=
WITHOUT_KERBEROS_SUPPORT=
# Set this if you do not want to build Kerberos 5 (KTH Heimdal).
WITHOUT_GSSAPI=
# Set to not build libgssapi.
WITHOUT_CTM=
# Set to not build ctm(1) and related utilities.
WITHOUT_DEBUG_FILES=
WITHOUT_DICT=
# Set to not build the Webster dictionary files.
WITHOUT_ED_CRYPTO=
# Set to build ed(1) without support for encryption/decryption.
#WITHOUT_EXAMPLES=
# Set to avoid installing examples to /usr/share/examples/.
WITH_FDT=
# Set to build Flattened Device Tree support as part of the base system.
# This includes the device tree compiler (dtc) and libfdt support library.
WITHOUT_FLOPPY=
# Set to not build or install programs for operating floppy disk driver.
WITHOUT_FREEBSD_UPDATE=
# Set to not build freebsd-update(8).
WITHOUT_GAMES=
# Set to not build games.
WITHOUT_GCC=
# Set to not install gcc and g++.
WITHOUT_GCOV=
# Set to not build the gcov(1) tool.
WITHOUT_GNUCXX=
# Do not build the GNU C++ stack (g++, libstdc++). This is the default on
# platforms where clang is the system compiler.
WITH_HESIOD=
# Set to build Hesiod support.
WITHOUT_HTML=
# Set to not build HTML docs.
#WITHOUT_INSTALLLIB=
# Set this if you do not want to install optional libraries.
# For example when creating a nanobsd(8) image.
WITHOUT_IPFILTER=
# Set to not build IP Filter package.
WITHOUT_IPX=
# Set to not build programs and libraries related to IPX networking.
# WITHOUT_IPX_SUPPORT, WITHOUT_NCP
WITHOUT_IPX_SUPPORT=
# Set to build some programs without IPX support.
WITHOUT_NCP=
# Set to not build programs, libraries, and kernel modules related to
# NetWare Core protocol.
WITHOUT_JAIL=
# Set to not build tools for the support of jails; e.g. jail(8).
#WITHOUT_KVM=
# Set to not build the libkvm library as a part of the base system.
#WITHOUT_KVM_SUPPORT=
# Set to build some programs without optional libkvm support.
WITHOUT_LDNS=
# Setting this variable will prevent the LDNS library from being built.
WITHOUT_LDNS_UTILS=
# Setting this variable will prevent building the LDNS utilities drill(1) and host(1).
WITHOUT_UNBOUND=
# Not build unbound and related programs.
#WITHOUT_LIB32= WKS!
# On amd64, set to not build 32-bit library set and a ld-elf32.so.1 runtime linker.
WITH_LLDB=
# Set to build the LLDB debugger.
WITHOUT_LPR=
# Set to not build lpr(1) and related programs.
WITHOUT_MAIL=
# Set to not build any mail support (MUA or MTA). When set, it also enforces
# the following options: WITHOUT_MAILWRAPPER, WITHOUT_SENDMAIL
WITHOUT_MAILWRAPPER=
# Set to not build the mailwrapper(8) MTA selector.
WITHOUT_SENDMAIL=
# Set to not build sendmail(8) and related programs.
WITHOUT_NDIS=
# Set to not build programs and libraries related to NDIS emulation support.
WITHOUT_NIS=
# Set to not build NIS(8) support and related programs. If set, you might need
# to adopt your nsswitch.conf(5) and remove `nis' entries.
WITHOUT_NS_CACHING=
# Set to disable name caching in the nsswitch subsystem. The generic caching
# daemon, nscd(8), will not be built either if this option is set.
# Need for OpenSSH
#WITHOUT_PAM=
# Set to not build PAM library and modules.
#WITHOUT_PAM_SUPPORT=
# Set to build some programs without PAM support, particularly ftpd(8) and ppp(8).
WITHOUT_PORTSNAP=
# Set to not build or install portsnap(8) and related files.
WITHOUT_PPP=
# Set to not build ppp(8) and related programs.
WITHOUT_QUOTAS=
# Set to not build quota(8) and related programs.
WITHOUT_RCMDS=
# Disable building of the BSD r-commands. This includes rlogin(1), rsh(1), etc.
WITHOUT_RCS=
# Set to not build rcs(1) and related utilities.
#WITHOUT_SHAREDOCS=
# Set to not build the 4.4BSD legacy docs.
#WITHOUT_SOURCELESS= WKS radeon
#WITHOUT_SOURCELESS_HOST=
#WITHOUT_SOURCELESS_UCODE=
# Set to not build kernel modules that include sourceless code
# (either microcode or native code for host CPU).
WITHOUT_SVN=
WITHOUT_SVNLITE=
# Set to not build svnlite(1) and related programs.
WITHOUT_TELNET=
# Not build telnet(8) and related programs.
WITHOUT_WIRELESS=
# Set to not build programs used for 802.11 wireless networks;
# especially wpa_supplicant(8) and hostapd(8). When set, it also
# enforces the following options: WITHOUT_WIRELESS_SUPPORT
WITHOUT_WIRELESS_SUPPORT=
# Set to build libraries, programs, and kernel modules without 802.11
# wireless support.
WITHOUT_WPA_SUPPLICANT_EAPOL=
# Build wpa_supplicant(8) without support for the IEEE 802.1X protocol and
# without support for EAP-PEAP, EAP-TLS, EAP-LEAP, and EAP-TTLS protocols
# (usable only via 802.1X).
