Зравствуйте!
CPU Mac f8:f0:82:73:49:f6
Vlan MAC f8:f0:82:73:49:f5
SoftWare Version 7.0.3.5(R0102.0182)
BootRom Version 7.1.40
HardWare Version R01
CPLD Version N/A
Serial No.:SW041610E820000092
Copyright © 2016 NAG LLC
All rights reserved
Last reboot is cold reset.
Uptime is 2 weeks, 6 days, 22 hours, 11 minutes
Проблема с ipv6
ipv6 access-list 600 deny any-source any-destination
SNR-S2990G-48T-PVK#conf t
SNR-S2990G-48T-PVK(config)#int eth1/0/30
SNR-S2990G-48T-PVK(config-if-ethernet1/0/30)#ipv6 access-group 600 in
WARNING: No resource to bind access-list [600] to interface Ethernet1/0/30!
ipv6 access-list extended vacl_a6
exit
SNR-S2990G-48T-PVK(config)#vacl ipv6 access-group vacl_a6 in vlan 801
WARNING: No resource to apply acl vacl_a6 to ingress vlan 801!
на том же vlan висит vacl ipv4. Если его убрать, все то же самое
=================================== Stage Ingress FP ================================
stageId = 0, sliceCount = 8, total rules num = 1024.
slice 0:( 0) Single (dcn type 25) Protocol
slice size = 128
SDK group id = 1
SDK entry total num = 56
1 - 2 5 - 6 9 11 13 - 17 23 - 24 27 29 - 30
33 - 34 37 - 38 41 43 45 47 - 48 51 - 52 55 - 56
59 - 60 63 65 - 68 73 75 77 79 81 - 83
87 - 92 99 101 103 - 104 107 109 141
slice 1:( 1) Single (dcn type 19) LPM
slice size = 128
SDK group id = 2
SDK entry total num = 2
111 113
slice 2:( 2) Single (dcn type 28) IP-FW
slice size = 128
SDK group id = 3
SDK entry total num = 13
0 0 0 0 0 0 0 0
0 0 0 0 135
slice 3:( 3) Single (dcn type 34) ing-vlan stat
slice size = 128
SDK group id = 5
SDK entry total num = 3
146 - 148
slice 4:( 4) Single (dcn type 27) MAC-FW
slice size = 128
SDK group id = 4
157 - 159
slice 5:( 5) Single (dcn type 27) MAC-FW
slice size = 128
SDK group id = 4
157 - 159
slice 6:( 6) Single (dcn type 0) ARP-SCAN
slice size = 128
SDK group id = 6
152 154
slice 7:
=================================== Stage Lookup FP =================================
stageId = 3, sliceCount = 4, total rules num = 0.
slice 0: Err: Slice is NULL
slice 1:
slice 2:
slice 3:
the func return 0x0
На SNR-S2990-24T та же история.
slice size = 128
SDK group id = 1
SDK entry total num = 58
1 - 55 58 - 59 63
slice size = 128
SDK group id = 2
56 - 57
slice 2:( 2) Single (dcn type 27) MAC-FW
slice size = 128
SDK group id = 3
SDK entry total num = 9
60 - 62 64 - 69
slice 3:( 3) Single (dcn type 27) MAC-FW
slice size = 128
SDK group id = 3
60 - 62 64 - 69
slice 4:( 4) Single (dcn type 34) ing-vlan stat
slice size = 128
SDK group id = 4
70 - 72
slice 5:( 5) Single (dcn type 0) ARP-SCAN
slice size = 128
SDK group id = 5
73 - 74
slice 6:( 6) Single (dcn type 28) IP-FW
slice size = 128
SDK group id = 6
SDK entry total num = 10
75 - 84
slice 7:
slice 1:
slice 2:
slice 3:
the func return 0x0
Возможно, что не хватает TCAM.
Попробуй для эксперимента поубирать некоторые фичи.
Точно только саппорт скажет, они точно знают сколько TCAM'а хочет IPv6-FW.
У меня, кстати, тоже не вышло:
ss-pe-730#su
ss-pe-730(sdiag)#tshell debug call dumpslice
slice  0:
slice size = 128
SDK group id = 2
 56 -  57
slice  2:
slice  3:( 3) Single  (dcn type 33) ing-vlan stat
slice size = 128
SDK group id = 5
SDK entry total num = 6
 65 -  70
slice  4:( 4) Single  (dcn type  8) DCSCM
slice size = 128
SDK group id = 4
 85 -  87
slice  5:
slice size = 128
SDK group id = 6
 71 -  72
slice  7:( 7) Single  (dcn type 25) Protocol
slice size = 128
SDK group id = 1
 12 -  13     50        54        58        83
slice  1:
slice  2:
slice  3:
the func return 0x0
