В сети есть сервер с прошивками.
Обычно я их забираю по TFTP, но одна железка хочет FTP.
На скорую руку настроил vsftpd (версия vsFTPd version 3.0.2+ (ext.1)):
# Server settings
listen=YES
listen_port=21
port_enable=YES
pasv_enable=YES
pasv_min_port=40000
pasv_max_port=40999
ftpd_banner=Service Area
log_ftp_protocol=YES
dual_log_enable=YES
xferlog_enable=YES
background=YES
# Common settings
anonymous_enable=YES
anon_root=/files/firmware
guest_enable=YES
guest_username=service
write_enable=YES
allow_writeable_chroot=YES
В каталоге /files/firmware доступ 777, в файлах 666.
Пытаюсь подключиться и не получается:
> ftp -d -n 10.1.128.9
Связь с 10.1.128.9.
220 Service Area
ftp> user ftp
---> USER ftp
331 Please specify the password.
Пароль:
---> PASS ftp
230 Login successful.
ftp> dir
---> PORT 192,168,1,9,155,162
500 Illegal PORT command.
---> LIST
425 Use PORT or PASV first.
ftp> pasv
Недопустимая команда.
ftp> pwd
---> XPWD
257 "/"
ftp> list
ftp> remote
---> HELP
214-The following commands are recognized.
ABOR ACCT ALLO APPE CDUP CWD  DELE EPRT EPSV FEAT HELP LIST MDTM MKD
MODE NLST NOOP OPTS PASS PASV PORT PWD  QUIT REIN REST RETR RMD  RNFR
RNTO SITE SIZE SMNT STAT STOR STOU STRU SYST TYPE USER XCUP XCWD XMKD
XPWD XRMD
214 Help OK.
ftp> quit
---> QUIT
221 Goodbye.
В логах сервера:
Tue Sep 27 19:01:33 2016 [pid 17704] CONNECT: Client "10.1.144.3"
Tue Sep 27 19:01:33 2016 [pid 17704] FTP response: Client "10.1.144.3", "220 Service Area"
Tue Sep 27 19:01:36 2016 [pid 17704] FTP command: Client "10.1.144.3", "USER ftp"
Tue Sep 27 19:01:36 2016 [pid 17704] [ftp] FTP response: Client "10.1.144.3", "331 Please specify the password."
Tue Sep 27 19:01:38 2016 [pid 17704] [ftp] FTP command: Client "10.1.144.3", "PASS <password>"
Tue Sep 27 19:01:38 2016 [pid 17703] [ftp] OK LOGIN: Client "10.1.144.3", anon password "ftp"
Tue Sep 27 19:01:38 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "230 Login successful."
Tue Sep 27 19:01:41 2016 [pid 17705] [ftp] FTP command: Client "10.1.144.3", "PORT 192,168,1,9,155,162"
Tue Sep 27 19:01:41 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "500 Illegal PORT command."
Tue Sep 27 19:01:41 2016 [pid 17705] [ftp] FTP command: Client "10.1.144.3", "LIST"
Tue Sep 27 19:01:41 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "425 Use PORT or PASV first."
Tue Sep 27 19:01:45 2016 [pid 17705] [ftp] FTP command: Client "10.1.144.3", "XPWD"
Tue Sep 27 19:01:45 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "257 "/""
Tue Sep 27 19:02:44 2016 [pid 17705] [ftp] FTP command: Client "10.1.144.3", "HELP"
Tue Sep 27 19:02:44 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "214-The following commands are recognized."
Tue Sep 27 19:02:44 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "214 Help OK."
Tue Sep 27 19:02:46 2016 [pid 17705] [ftp] FTP command: Client "10.1.144.3", "QUIT"
Tue Sep 27 19:02:46 2016 [pid 17705] [ftp] FTP response: Client "10.1.144.3", "221 Goodbye."
То есть ошибок на сервере не вижу.
А почему FTP не работает, понять не могу.
NAT есть, но на клиенте, не на сервере. Шлюзом у клиента работает Zyxel Keenetic с ALG FTP, обычно с FTP проблем не было.
Кстати, с проблемой разобрался.
vsftpd работал нормально.
Это встроенный в Windows ftp-клиент странно работает, не все команды отправляет. Если команды отправлять через quote, то они выполняются все.
Железка загружает файл без каких-либо проблем.
по логу видно.
они начинают договариваться о ftp passive mode. и обламываются. это не все ftp клиенты коррректно умеют.
одна строчка в конфиге vsftpd - pasv_address=10.1.128.9 решает. уж точно не вредит.
