Использую этот сервер: http://www.pro-bono-publico.de/projects/tac_plus.html
Есть странность, которую я никак не пойму.
Есть такая конфигурация:
       acl = office {
               nac = 10.1.144.3
       group = monitor {
               acl = office
               message = "Login as @monitor (status and audit), username %%u\n"
               default service = deny
               enable = permit
               service = shell {
                       default command = deny
                       default attribute = deny
                       set priv-lvl = 1
                       set orign-priority = 1
                       cmd = show { permit .* }
                       cmd = search { permit .* }
                       cmd = test { permit .* }
                       cmd = ping { permit .* }
                       cmd = enable { permit .* }
       user = check {
               login = clear "password"
               member = monitor@access
Не могу выполнить вход под логином check.
В логах такое:
2016-09-23 14:56:33 +0300       10.1.13.127     check    tty1           shell login denied by ACL
Но я выполняю вход из 10.1.144.3.
И если ACL выключить, перезапустить сервис и попытаться войти повторно, то вход под логином check выполняется и в логах вот что:
2016-09-23 14:48:54 +0300       10.1.13.127     check    tty1   10.1.144.3      start   task_id=47      zonelist=UTC    service=shell   priv-lvl=1
#!/usr/local/sbin/tac_plus
syslog default = deny
id = spawnd {
       listen = { port = 49 }
       spawn = {
               instances min = 1
               instances max = 4
id = tac_plus {
       debug = ACL PACKET AUTHEN AUTHOR
       authentication log = /store/mgmt/logs/tacacs-access.log
       authorization log  = /store/mgmt/logs/tacacs-author.log
       accounting log     = /store/mgmt/logs/tacacs-account.log
       host = world {
               key = "no-access"
               address = 0.0.0.0/0
       host = access {
               key = secret
               address = 10.1.10.0/24
               address = 10.1.11.0/24
               address = 10.1.12.0/24
               address = 10.1.13.0/24
               address = 10.1.14.0/24
#               single-connection may-close = yes
               prompt = "\n(access level)\n\n"
               welcome banner = "\nUnauthorized access is prohibited.\n Host %%r, client %%c (logged)\n"
               motd banner = "Welcome, %%u. Date is %F, clock is %T (%Z %:z)\n"
       acl = special {
#               nac = 10.1.0.0/16
       acl = special {
               port = tty0
       acl = backbone {
#               nac = 10.1.0.0/16
       acl = office {
#               nac = 10.1.144.3
       acl = local {
               port = tty0
       group = admin {
               acl = special
               message = "Login as @admin (full access), username %%u\n"
               default service = permit
               service = shell {
                       default command = permit
                       default attribute = permit
                       set priv-lvl = 15
       group = service {
               acl = special
               message = "Login as @service (service and maintenance), username %%u\n"
               service = shell {
                       set priv-lvl = 15
       group = support {
               acl = office
               message = "Login as @support (support and port control), username %%u\n"
               service = shell {
                       set priv-lvl = 15
       group = monitor {
               acl = office
               enable = permit
               service = shell {
                       message permit = "Permitted '%c %a'"
                       message deny = "Denied '%c %a'"
                       set priv-lvl = 1
                       set autocmd = "show version"
       user = admin {
               login = clear "pwd"
               member = admin@access
       user = oper {
               login = clear "pwd"
               member = service@access
       user = check {
               login = clear "pwd"
       user = user1 {
               login = clear "pwd"
               member = support@access
В ходе экспериментов обнаружилось, что ACL, в которых используется nac или port, работают неадекватно.
То работают, то не работают, чаще не работают, закономерности никакой нет.
Глючит случайно не ACL?
        acl = special {
               port = tty0
Не уверен, но с тас+ скакал по граблям из-за несинхронности времени на нас и такаксе, там типа члючи шифрования уезжали от несинхрона. Но это было давно.... Смутно помню, что если нас отставал во времени и впадал в 1970г, то тас+ не авторизовывал вообще никого, на диалапе еще дело было...
Часы я проверял, они синхронизированы.
Там что-то другое.
Включил дебаг и в дебаге он явно писал, что NAC != 10.1.144.3.
А вот почему - непонятно, в дебаге полученное значение NAC я не нашел.
Удаленное устройство это NAS, по нему ACL срабатывают успешно.
А вот по NAC то работают, то не работают.
Скорей всего проблема может быть в том что свич не в верном формате передает ip address компьютера, который на него подключается или не передает вовсе.
P.S. Имеет ли вообще смысл ограничивать входы с определенных IP адресов?
