Поделитесь опытом, при подключении с NAT сессия после старта сразу вылетает с ошибкой
Time: 13.09.2016 16:48:51
Packet type: Accounting-Request
Identifier: 202
Authenticator: {5E 7D F4 66 9E C8 9A 44 B4 91 4C 0F 02 5E 4F 3B}
Attributes:
NAS-Identifier=RedBack
User-Name=78
NAS-IP-Address=10.0.0.103
NAS-Port=553655734
Service-Type=2
Framed-Protocol=1
Acct-Status-Type=2
Framed-IP-Address=10.171.194.38
Framed-IP-Netmask=255.255.255.255
Acct-Delay-Time=1
Acct-Input-Octets=1245
Acct-Output-Octets=653
Acct-Session-Id=0100FFFF68001828-57D7F5B0
Acct-Authentic=1
Acct-Session-Time=0
Acct-Input-Packets=18
Acct-Output-Packets=14
Acct-Terminate-Cause=15
Acct-Input-Gigawords=0
Acct-Output-Gigawords=0
NAS-Port-Id=2/1 vlan-id 34 pppoe 7606
Event-Timestamp=1473770930
NAS-Port-Type=5
Acct-Input-Octets-64={00 00 00 00 00 00 04 DD}
Client-DNS-Pri=11.111.194.17
Acct-Output-Octets-64={00 00 00 00 00 00 02 8D}
Client-DNS-Sec=11.111.194.10
Acct-Input-Packets-64={00 00 00 00 00 00 00 12}
Acct-Output-Packets-64={00 00 00 00 00 00 00 0E}
Dynamic-QoS-Param=police-class-rate INET rate-absolute 92160
Dynamic-QoS-Param=police-class-burst INET 13824000
Dynamic-QoS-Param=police-class-excess-burst INET 27648000
Dynamic-QoS-Param=meter-class-rate INET rate-absolute 92160
Dynamic-QoS-Param=meter-class-burst INET 13824000
Dynamic-QoS-Param=meter-class-excess-burst INET 27648000
Acct-Mcast-In-Octets-64={00 00 00 00 00 00 00 00}
Acct-Mcast-Out-Octets-64={00 00 00 00 00 00 00 00}
Acct-Mcast-In-Packets-64={00 00 00 00 00 00 00 00}
Acct-Mcast-Out-Packets-64={00 00 00 00 00 00 00 00}
Session-Error-Code=26
Session-Error-Msg=Subscriber provisioning failed
Acct-Update-Reason=2
Mac-Addr=08-00-27-37-87-52
Acct-Mcast-In-Octets=0
Acct-Mcast-Out-Octets=0
Acct-Mcast-In-Packets=0
Acct-Mcast-Out-Packets=0
Qos-Policing-Profile-Name=DEFAULT-IN
Qos-Metering-Profile-Name=DEFAULT-OUT
Platform-Type=4
Medium-Type=11
NAT-Policy-Name=NAT
OS-Version=11.1.2.7
NAS-Real-Port=553648162
Edited by zavndw
Time: 12.09.2016 09:22:24
Packet type: Access-Request
Identifier: 175
Authenticator: {9A 03 53 A4 90 8A B6 94 BB D0 9D 74 C9 30 E1 72}
Attributes:
User-Name=78
CHAP-Password={01 28 BB 37 0E 4D C1 C0 00 05 B2 29 6F 4D 29 08 27}
NAS-Port=553663146
Service-Type=2
Framed-Protocol=1
NAS-Port-Id=2/1 vlan-id 34 pppoe 15018
CHAP-Challenge=�\u3S������Нt�0�r
NAS-Port-Type=5
OS-Version=11.1.2.7
Mac-Addr=6a-de-b0-81-e0-d4
Platform-Type=4
Medium-Type=11
Packet type: Access-Accept
Identifier: 175
Authenticator: {E1 68 63 D2 10 A0 BF 1F 52 EA 2B 67 AE 42 A1 2F}
Attributes:
User-Password=User-Password
Service-Type=2
Framed-Protocol=1
Framed-IP-Address=10.171.192.61
NAT-Policy-Name=NAT
subscriber default
qos policy policing DEFAULT-IN
qos policy metering DEFAULT-OUT
dns primary 11.111.194.10
dns secondary 11.111.194.17
flow apply ip profile flow-profile1 both
Edited by zavndw
nat policy NAT
connections tcp maximum 3000
connections udp maximum 3000
connections icmp maximum 20
! Default class
ignore
timeout tcp 600
timeout udp 30
timeout fin-reset 60
timeout icmp 10
timeout syn 60
admission-control tcp
admission-control udp
admission-control icmp
endpoint-independent filtering udp
icmp-notification
! Named classes
access-group NAT-acl-pppoe
class NAT-pppoe0
pool NAT-pppoe0 pppoe
timeout tcp 600
timeout udp 60
timeout icmp 10
timeout syn 60
no icmp-notification
Edited by zavndw
хм. выглядит вроде всё нормально. есть 2 пути:
1) запустить дебаг, попробовать подключиться и смотреть в дебаг
2) попробовать повесить nat policy не через radius, например так
subscriber name 78
nat policy-name NAT
но я не уверен что именно в этом проблема.
контекст у вас называется pppoe?
без атрибута nat подключается и работает всё нормально?
Да тот же
"IP адреса, используемые в NAPT пулах не должны пересекаться с адресными пространствами L3 интерфейсов контекста маршрутизации где они определены."
Я видимо уже запутался, вот конфиг
context pppoe
ip nat pool NAT-pppoe0 napt multibind
address 31.171.194.11/32 port-block 1 to 15
nat policy NAT
! Default class
ignore
timeout tcp 600
timeout udp 30
timeout icmp 10
timeout syn 60
icmp-notification
! Named classes
class NAT-pppoe0
timeout tcp 600
timeout udp 60
timeout icmp 10
timeout syn 60
interface core
ip address 10.0.0.103/24
ip source-address radius
interface loop1 loopback
ip address 31.171.192.17/32
interface pppoe multibind lastresort
ip unnumbered loop1
interface route
ip address 31.171.192.11/29
no logging console
aaa authentication administrator local
aaa authentication administrator maximum sessions 1
aaa authentication subscriber radius
aaa accounting subscriber radius
aaa update subscriber 10
radius max-retries 5
radius timeout 30
radius attribute nas-ip-address interface core
radius attribute nas-port format session-info
radius attribute nas-identifier RedBack3
subscriber default
dns primary 31.171.194.17
dns secondary 31.171.194.10
ip route 0.0.0.0/0 31.171.192.12
у вас какая схема? провайдер даёт вам /29 из своего блока?
если так, то применима такая схема. вы натягиваете с провайдером /30 или /31, можно серую. Он прописывает в вашу сторону статический маршрут на белую сеть /29.
