Добрый день, имеем:
BDCOM P3310B Software, Version 10.1.0B Build 29333
Copyright by Shanghai Baud Data Communication CO. LTD.
Compiled: 2015-7-21 17:47:52 by SYS_29333, Image text-base: 0x80008000
ROM: System Bootstrap, Version 0.3.4, Serial num:0031300XXXX
System image file is "Switch.bin"
(RISC) processor with 131072K bytes of memory, 8192K bytes of flash
Base ethernet MAC Address: fc:fa:f7:XX:XX:XX
Растут ошибки на EPON 0/3, начали жаловаться клиенты про "тормоза" и на потери пакетов.
EPON0/3 is up, line protocol is up
Ifindex is 10, unique port number is 9
Description: ХХХХХХХХ
Hardware is GigaEthernet-PON, address is fcfa.f7c9.ЧЧЧЧ (bia fcfa.f7c9.ЧЧЧЧ)
MTU 1500 bytes, BW 1000000 kbit, DLY 2000 usec
Encapsulation ARPA
Full-duplex, 1000Mb/s
flow-control off
5 minutes input rate 6145377 bits/sec, 2890 packets/sec
5 minutes output rate 49986044 bits/sec, 4486 packets/sec
Received 13083370507 packets, 3955020949185 bytes
4093922 broadcasts, 3830616 multicasts
0 discard, 5000730 error, 0 PAUSE
0 align, 0 FCS, 0 symbol
0 carriersense
Transmited 20189363885 packets, 26668753843740 bytes
7807472 broadcasts, 110349 multicasts
0 discard, 0 error, 0 PAUSE
0 sqettest, 0 deferred
0 single, 0 multiple, 0 excessive, 0 late
Как найти ту ону, которая портит картину? Вот уровни сигналов, с которыми OLT видит ONU:
interface RxPower
epon0/3:1 -20.3
epon0/3:2 -18.9
epon0/3:3 -20.1
epon0/3:4 -20.5
epon0/3:5 -20.1
epon0/3:6 -20.9
epon0/3:7 -20.7
epon0/3:8 -20.5
epon0/3:9 -20.3
epon0/3:10 -21.3
epon0/3:11 -25.3
epon0/3:13 -20.5
epon0/3:15 -21.0
epon0/3:16 -18.9
epon0/3:17 -20.3
epon0/3:18 -20.0
epon0/3:19 -24.8
epon0/3:20 -21.2
epon0/3:21 -20.4
epon0/3:22 -20.3
epon0/3:23 -19.8
epon0/3:24 -19.8
epon0/3:26 -20.2
epon0/3:27 -20.3
epon0/3:28 -24.6
epon0/3:29 -20.7
epon0/3:31 -20.4
epon0/3:32 -20.9
epon0/3:33 -20.7
epon0/3:34 -21.5
epon0/3:35 -21.8
epon0/3:36 -20.7
epon0/3:37 -20.6
epon0/3:38 -21.9
epon0/3:39 -22.2
epon0/3:40 -20.3
epon0/3:41 -20.5
epon0/3:42 -20.4
epon0/3:43 -20.9
epon0/3:44 -20.9
epon0/3:45 -20.9
epon0/3:49 -22.1
epon0/3:50 -21.1
epon0/3:51 -19.6
epon0/3:52 -20.6
epon0/3:53 -22.3
epon0/3:54 -19.5
epon0/3:55 -20.2
Вроде ничего криминального нет, посмотрел статистику на ону где сигнал ниже -20 - ошибок нет.
Edited by uk2558
Добрый день!
Предположительно в вашем случае образовался дефект оптической трассы где происходит отражение оптического сигнала.
Чтобы локализовать проблемный участок оптической трассы предлагаю посмотреть сведения на интерфейсах ONU:
sh epon interface epoN 0/3:X onu pon-port statistics
- где X номер ONU
Пройдитесь по всем ONU на проблемном порту, тем самым по отсутствию ошибок на интерфейсах можно исключить целые участки и примерно обнаружить где возникает проблема.
Замена SFP не помогла, ошибки продолжают расти. Так же меняли патчкорд оптический у OLT.
Добрый день!
Предлагаю продолжить с замены EPON порта. Так Вы сможете исключить проблему с самой OLT.
Замена порта не вариант, свободных портов нет на OLT. Подскажите лучше, какой командной можно потушить ONU на время? Если такое вообще возможно.
На более свежих версиях софта можно воспользоваться командой:
Switch_config#epon onu-blacklist mac xxxx.xxxx.xxxx
ROM: System Bootstrap, Version 0.3.4, Serial num:0031xxxxxx
Base ethernet MAC Address: fc:fa:f7:xx:xx:xx
snmp info:
product_ID:228 system_ID:1.3.6.1.4.1.3320.1.228.0
OLT_XXXXX uptime is 259:22:33:37, The current time: 2016-9-13 9:16:35
Нет такой команды на данной версии прошивки. Посоветуйте для данного bootloader стабильную версию прошивки, где будет black-list для ONU.
