День добрый!
Установил у себя на работе EdgeRouter Lite-3 и уже некоторое время его понемногу настраиваю. Ни с чем особых проблем не возникало, кроме как с настройкой балансировки нагрузок.
В общем, настроил сеть для работы в режиме 70% серфинг, 10% скачка, 10 прочее, думаю когда разберусь, то еще и 10% для VoIP SIP выделить, чтоб разговоры не подлагивали.
Прописывал следующее.
set traffic-policy shaper download
set traffic-policy shaper download bandwidth 9.7Mbit
set traffic-policy shaper download default bandwidth 10%
set traffic-policy shaper download default ceiling 100%
set traffic-policy shaper download default priority 3
set traffic-policy shaper download default queue-type fair-queue
set traffic-policy shaper download class 10 bandwidth 10%
set traffic-policy shaper download class 10 ceiling 100%
set traffic-policy shaper download class 10 priority 4
set traffic-policy shaper download class 10 queue-type fair-queue
set traffic-policy shaper download class 10 match icmp ip protocol icmp
set traffic-policy shaper download class 10 match ssh ip source port 22
set traffic-policy shaper download class 10 match dns ip source port 53
set traffic-policy shaper download class 20 bandwidth 70%
set traffic-policy shaper download class 20 ceiling 100%
set traffic-policy shaper download class 20 priority 5
set traffic-policy shaper download class 20 queue-type fair-queue
set traffic-policy shaper download class 20 match http ip source port 80
set traffic-policy shaper download class 20 match https ip source port 443
set interfaces ethernet eth10 traffic-policy out download
set traffic-policy shaper upload
set traffic-policy shaper upload bandwidth 9.7Mbit
set traffic-policy shaper upload class 2 bandwidth 10%
set traffic-policy shaper upload class 2 ceiling 100%
set traffic-policy shaper upload class 2 priority 4
set traffic-policy shaper upload class 2 queue-type fair-queue
set traffic-policy shaper upload class 2 queue-limit 16
set traffic-policy shaper upload class 2 match icmp ip protocol icmp
set traffic-policy shaper upload class 2 match ssh ip destination port 22
set traffic-policy shaper upload class 2 match dns ip destination port 53
set traffic-policy shaper upload class 5 bandwidth 70%
set traffic-policy shaper upload class 5 ceiling 100%
set traffic-policy shaper upload class 5 priority 5
set traffic-policy shaper upload class 5 queue-type fair-queue
set traffic-policy shaper upload class 5 match http ip destination port 80
set traffic-policy shaper upload class 5 match https ip destination port 443
set traffic-policy shaper upload default bandwidth 10%
set traffic-policy shaper upload default ceiling 100%
set traffic-policy shaper upload default priority 3
set traffic-policy shaper upload default queue-type fair-queue
set interfaces ethernet eth0 traffic-policy out upload
После применения данных настроек не увидел вообще никакой разницы закачка так и не режется.
В чём может быть проблема?
Заранее спасибо!
Если они не сильно переделали шейпер Vyatta, то
ceiling - это максимально возможная при свободном канале, то есть если есть запас, то оно не режется. У вас 100% - пока не нагрузите канал остальными классами - этот класс не начнет резать.
bandwidth - "гарантированная" скорость, которая зарезервирована за данным классом и будет выдана ему при любой нагрузке нагрузке на канал в ущерб ceiling остальных классов.
Если я правильно понял, то мне нужно celling выставить в соответствии с параметром bandwidth?
Если есть возможность, опишите как примерно должно всё выглядеть.
