VolanD666 Posted August 30, 2016 Posted August 30, 2016 (edited) Добрый день! Есть схема: | c6500 |g4/47|------[trunk]------| g0/0/3| ASR1002f | Как собрал такую схему- сразу стал тикать input errors на инт-се c6500 - g4/47 на инт-се g0/0/3 - все хорошо. Причем, потерь нет, клиенты не жалуются- просто тикает счетчик: g4/47 GigabitEthernet4/47 is up, line protocol is up (connected) Hardware is C6k 1000Mb 802.3, address is 0012.80c7.04de (bia 0012.80c7.04de) Description: Link to asr1002f-1 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 14/255, rxload 41/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT input flow-control is off, output flow-control is off Clock mode is auto ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters 09:18:10 Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 160938000 bits/sec, 20173 packets/sec 5 minute output rate 58258000 bits/sec, 17267 packets/sec 154295390 packets input, 135788600661 bytes, 0 no buffer Received 4121 broadcasts (3863 multicasts) 0 runts, 0 giants, 0 throttles 367 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 138657812 packets output, 67045673270 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out g0/0/3 GigabitEthernet0/0/3 is up, line protocol is up Hardware is 4XGE-BUILT-IN, address is 4055.399d.9203 (bia 4055.399d.9203) Description: Link to c6506E MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 40/255, rxload 14/255 Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set Keepalive not supported Full Duplex, 1000Mbps, link type is auto, media type is T output flow-control is on, input flow-control is on ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:10, output 00:00:11, output hang never Last clearing of "show interface" counters never Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 30 second input rate 57823000 bits/sec, 16808 packets/sec 30 second output rate 159113000 bits/sec, 19761 packets/sec 2576235394 packets input, 1105227377945 bytes, 0 no buffer Received 269 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 52402 multicast, 0 pause input 2888300571 packets output, 2688926885221 bytes, 0 underruns 0 output errors, 0 collisions, 6 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out Посмотрел sh int g4/47 counters errors вроде ничего криминального Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards Gi4/47 0 0 0 377 0 0 Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants Gi4/47 0 0 0 0 0 0 0 Port SQETest-Err Deferred-Tx IntMacTx-Err IntMacRx-Err Symbol-Err Gi4/47 0 0 0 0 0 Настройки на инт-сах такие: g4.47 interface GigabitEthernet4/47 description Link to asr1002f-1 switchport switchport trunk encapsulation dot1q switchport trunk native vlan 666 switchport trunk allowed vlan 115,200 switchport mode trunk switchport nonegotiate logging event link-status end g0/0/3 interface GigabitEthernet0/0/3 description Link to c6506E no ip address load-interval 30 negotiation auto end Сам порт (4/47) находится на WS-X6748-GE-TX суп-WS-SUP720-3B Пробовал менять кабель и модуль на ASR- проблема осталась. Может конечно с интерфейсом что-то, но трафик то ходит без проблем (трафика примерно 300 мбит). Больше склонюсь к багу ИОСа 12.2(33)SXI6, может кто сталкивался с таким? Edited August 30, 2016 by VolanD666 Вставить ник Quote
sol Posted August 30, 2016 Posted August 30, 2016 Ну, написанному верить. Как быстро растёт счётчик? А так, физика скорее всего. Вставить ник Quote
VolanD666 Posted August 30, 2016 Author Posted August 30, 2016 Странно просто что в sh int g4/47 counters errors только Rcv-Err растет. Вставить ник Quote
dmvy Posted August 30, 2016 Posted August 30, 2016 при 20килопакетах 400 ошибок ерунда. не в этом причина Вставить ник Quote
VolanD666 Posted August 30, 2016 Author Posted August 30, 2016 Да это то да, мне просто понять почему так происходит. Две железки стоят рядом. Кабель 100% рабочий. А счетчик тикает :( Вставить ник Quote
dmvy Posted August 30, 2016 Posted August 30, 2016 STP? при topology change пакеты дропаются. бебаг включить - порбовать там выловить ошибки, отправив на syslog все сообщения для парсинга. Вставить ник Quote
VolanD666 Posted August 30, 2016 Author Posted August 30, 2016 STP на всех вланах выключен Вставить ник Quote
VolanD666 Posted August 31, 2016 Author Posted August 31, 2016 Попробую порт поменять на с6500. Еще есть предположение, что это из-за того, что на g0/0/3 раньше был erspan настроен как destination. Он уже давно выключен (удален из конфига), но почему то sh platform hardware qfp active feature erspan state показывает статус Active. Вставить ник Quote
sui245 Posted September 5, 2016 Posted September 5, 2016 Обратите внимание на flow-control на интерфейсах Вставить ник Quote
