root@mail:~# uname -a
Linux x.ru 3.2.0-4-amd64 #1 SMP Debian 3.2.81-1 x86_64 GNU/Linux
root@mail:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:16:e6:d9:69:8f
inet addr:88.88.88.88 Bcast:88.88.88.83 Mask:255.255.255.248
inet6 addr: fe80::216:e6ff:fed9:698f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:296242 errors:0 dropped:980 overruns:0 frame:0
TX packets:56904 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:21251651 (20.2 MiB) TX bytes:326593698 (311.4 MiB)
Interrupt:17
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:25915 errors:0 dropped:0 overruns:0 frame:0
TX packets:25915 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:22093095 (21.0 MiB) TX bytes:22093095 (21.0 MiB)
root@mail:~# cat /proc/interrupts
CPU0 CPU1
0: 141 0 IO-APIC-edge timer
1: 8 0 IO-APIC-edge i8042
8: 1 0 IO-APIC-edge rtc0
9: 0 0 IO-APIC-fasteoi acpi
12: 146 0 IO-APIC-edge i8042
14: 0 0 IO-APIC-edge ata_piix
15: 0 0 IO-APIC-edge ata_piix
16: 416768 0 IO-APIC-fasteoi stex
19: 0 0 IO-APIC-fasteoi ata_piix
44: 320463 0 PCI-MSI-edge eth0
45: 151 0 PCI-MSI-edge snd_hda_intel
46: 1 0 PCI-MSI-edge i915
NMI: 112 50 Non-maskable interrupts
LOC: 1237339 1053433 Local timer interrupts
SPU: 0 0 Spurious interrupts
PMI: 112 50 Performance monitoring interrupts
IWI: 0 0 IRQ work interrupts
RES: 282765 423785 Rescheduling interrupts
CAL: 131 52025 Function call interrupts
TLB: 6838 7454 TLB shootdowns
TRM: 0 0 Thermal event interrupts
THR: 0 0 Threshold APIC interrupts
MCE: 0 0 Machine check exceptions
MCP: 99 99 Machine check polls
ERR: 0
MIS: 0
root@mail:~# ethtool -i eth0
driver: sky2
version: 1.30
firmware-version: N/A
bus-info: 0000:05:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
root@mail:~# ethtool -S eth0
NIC statistics:
tx_bytes: 338182019
rx_bytes: 22479924
tx_broadcast: 1
rx_broadcast: 173034
tx_multicast: 6
rx_multicast: 495
tx_unicast: 244980
rx_unicast: 123231
tx_mac_pause: 0
rx_mac_pause: 0
collisions: 0
late_collision: 0
aborted: 0
single_collisions: 0
multi_collisions: 0
rx_short: 0
rx_runt: 0
rx_64_byte_packets: 240634
rx_65_to_127_byte_packets: 45330
rx_128_to_255_byte_packets: 4638
rx_256_to_511_byte_packets: 5244
rx_512_to_1023_byte_packets: 705
rx_1024_to_1518_byte_packets: 209
rx_1518_to_max_byte_packets: 0
rx_too_long: 0
rx_fifo_overflow: 0
rx_jabber: 0
rx_fcs_error: 0
tx_64_byte_packets: 3047
tx_65_to_127_byte_packets: 11965
tx_128_to_255_byte_packets: 3099
tx_256_to_511_byte_packets: 401
tx_512_to_1023_byte_packets: 612
tx_1024_to_1518_byte_packets: 225863
tx_1519_to_max_byte_packets: 0
tx_fifo_underrun: 0
root@mail:~# lspci
00:00.0 Host bridge: Intel Corporation 82P965/G965 Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 82P965/G965 PCI Express Root Port (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82G965 Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev f2)
00:1f.0 ISA bridge: Intel Corporation 82801HB/HR (ICH8/R) LPC Interface Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801H (ICH8 Family) 4 port SATA Controller [iDE mode] (rev 02)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 02)
00:1f.5 IDE interface: Intel Corporation 82801HR/HO/HH (ICH8R/DO/DH) 2 port SATA Controller [iDE mode] (rev 02)
01:00.0 PCI bridge: Intel Corporation 80333 Segment-A PCI Express-to-PCI Express Bridge
01:00.2 PCI bridge: Intel Corporation 80333 Segment-B PCI Express-to-PCI Express Bridge
02:0e.0 RAID bus controller: Promise Technology, Inc. 80333 [superTrak EX8350/EX16350], 80331 [superTrak EX8300/EX16300]
05:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
root@mail:~#
Вообще пытался заставить оба ядра обрабатывать eth с помощью smp_affinity но ничего не получилось
Кстати в centos на 2.6.32 все ядра обрабатывают прерывания от eth а на дебиан нет.
Вот думаю от железа это или от опций ядра при компиляции?
В centos по умолчанию irqbalance работает, а на дебиане вроде нет. Имхо.
PID TTY STAT TIME COMMAND
1 ? Ss 0:00 /sbin/init
2 ? S 0:00 [kthreadd]
3 ? S 0:00 [migration/0]
4 ? S 0:00 [ksoftirqd/0]
5 ? S 0:00 [stopper/0]
6 ? S 0:00 [watchdog/0]
7 ? S 0:00 [migration/1]
8 ? S 0:00 [stopper/1]
9 ? S 0:00 [ksoftirqd/1]
10 ? S 0:00 [watchdog/1]
11 ? S 0:00 [migration/2]
12 ? S 0:00 [stopper/2]
13 ? S 0:00 [ksoftirqd/2]
14 ? S 0:00 [watchdog/2]
15 ? S 0:00 [migration/3]
16 ? S 0:00 [stopper/3]
17 ? S 0:00 [ksoftirqd/3]
18 ? S 0:00 [watchdog/3]
19 ? S 0:00 [events/0]
20 ? S 0:00 [events/1]
21 ? S 0:00 [events/2]
22 ? S 0:00 [events/3]
23 ? S 0:00 [events/0]
24 ? S 0:00 [events/1]
25 ? S 0:00 [events/2]
26 ? S 0:00 [events/3]
27 ? S 0:00 [events_long/0]
28 ? S 0:00 [events_long/1]
29 ? S 0:00 [events_long/2]
30 ? S 0:00 [events_long/3]
31 ? S 0:00 [events_power_ef]
32 ? S 0:00 [events_power_ef]
33 ? S 0:00 [events_power_ef]
34 ? S 0:00 [events_power_ef]
35 ? S 0:00 [cgroup]
36 ? S 0:00 [khelper]
37 ? S 0:00 [netns]
38 ? S 0:00 [async/mgr]
39 ? S 0:00 [pm]
40 ? S 0:00 [sync_supers]
41 ? S 0:00 [bdi-default]
42 ? S 0:00 [kintegrityd/0]
43 ? S 0:00 [kintegrityd/1]
44 ? S 0:00 [kintegrityd/2]
45 ? S 0:00 [kintegrityd/3]
46 ? S 0:00 [kblockd/0]
47 ? S 0:00 [kblockd/1]
48 ? S 0:00 [kblockd/2]
49 ? S 0:00 [kblockd/3]
50 ? S 0:00 [kacpid]
51 ? S 0:00 [kacpi_notify]
52 ? S 0:00 [kacpi_hotplug]
53 ? S 0:00 [ata_aux]
54 ? S 0:00 [ata_sff/0]
55 ? S 0:00 [ata_sff/1]
56 ? S 0:00 [ata_sff/2]
57 ? S 0:00 [ata_sff/3]
58 ? S 0:00 [ksuspend_usbd]
59 ? S 0:00 [khubd]
60 ? S 0:00 [kseriod]
61 ? S 0:00 [md/0]
62 ? S 0:00 [md/1]
63 ? S 0:00 [md/2]
64 ? S 0:00 [md/3]
65 ? S 0:00 [md_misc/0]
66 ? S 0:00 [md_misc/1]
67 ? S 0:00 [md_misc/2]
68 ? S 0:00 [md_misc/3]
69 ? S 0:00 [linkwatch]
71 ? S 0:00 [khungtaskd]
72 ? S 0:00 [kswapd0]
73 ? SN 0:00 [ksmd]
74 ? SN 0:00 [khugepaged]
75 ? S 0:00 [aio/0]
76 ? S 0:00 [aio/1]
77 ? S 0:00 [aio/2]
78 ? S 0:00 [aio/3]
79 ? S 0:00 [crypto/0]
80 ? S 0:00 [crypto/1]
81 ? S 0:00 [crypto/2]
82 ? S 0:00 [crypto/3]
89 ? S 0:00 [kthrotld/0]
90 ? S 0:00 [kthrotld/1]
91 ? S 0:00 [kthrotld/2]
92 ? S 0:00 [kthrotld/3]
94 ? S 0:00 [kpsmoused]
95 ? S 0:00 [usbhid_resumer]
96 ? S 0:00 [deferwq]
129 ? S 0:00 [kdmremove]
130 ? S 0:00 [kstriped]
318 ? S 0:00 [scsi_eh_0]
319 ? S 0:00 [scsi_eh_1]
352 ? S 0:00 [scsi_eh_2]
353 ? S 0:00 [scsi_eh_3]
354 ? S 0:00 [scsi_eh_4]
355 ? S 0:00 [scsi_eh_5]
468 ? S 0:00 [kdmflush]
470 ? S 0:00 [kdmflush]
488 ? S 0:00 [jbd2/dm-0-8]
489 ? S 0:00 [ext4-dio-unwrit]
582 ? S<s 0:00 /sbin/udevd -d
742 ? S 0:00 [hd-audio0]
957 ? S 0:00 [kdmflush]
998 ? S 0:00 [jbd2/sda1-8]
999 ? S 0:00 [ext4-dio-unwrit]
1000 ? S 0:00 [jbd2/dm-2-8]
1001 ? S 0:00 [ext4-dio-unwrit]
1006 ? S 0:00 [flush-253:0]
1038 ? S 0:00 [kauditd]
1422 ? S<sl 0:00 auditd
1444 ? Sl 0:00 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
1510 ? Ss 0:00 /usr/sbin/sshd
1590 ? Ss 0:00 /usr/libexec/postfix/master
1596 ? S 0:00 pickup -l -t fifo -u
1597 ? S 0:00 qmgr -l -t fifo -u
1604 ? Ss 0:00 crond
1618 tty1 Ss+ 0:00 /sbin/mingetty /dev/tty1
1620 tty2 Ss+ 0:00 /sbin/mingetty /dev/tty2
1622 tty3 Ss+ 0:00 /sbin/mingetty /dev/tty3
1624 tty4 Ss+ 0:00 /sbin/mingetty /dev/tty4
1626 tty5 Ss+ 0:00 /sbin/mingetty /dev/tty5
1628 tty6 Ss+ 0:00 /sbin/mingetty /dev/tty6
1635 ? S< 0:00 /sbin/udevd -d
1636 ? S< 0:00 /sbin/udevd -d
1637 ? Ss 0:00 sshd: root@pts/0
1641 pts/0 Ss 0:00 -bash
1667 pts/0 S+ 0:00 /usr/bin/mc -P /tmp/mc-root/mc.pwd.1641
1669 pts/1 Ss 0:00 bash -rcfile .bashrc
2346 pts/1 R+ 0:00 ps ax
в centos нет irqbalance, либо в ядре либо в железе, в ядре какой параметр отвечает за балансировку?
Никакой. Нет там балансировки.
В дебиане более свежее ядро просто не позволяет делать эти глупости с smp_affinity, а центос позволяет.
Но все это бестолковая хрень, в реальности никакой балансировки не происходит, пакеты поочередно обрабатываются ядрами и вы имеете только ухудшение ситуации.
Простыми словами - при определенном трафике на дебиане вы упретесь в 100% на одном ядре, а на центосе - в 2 ядра по 50%. Причем трафика в первом случае пролезет больше.
т.е. вся ветка про обсуждение router linux - ересь полная?
