7201 крашится через день.
У кого есть партнерский аккаунт, помогите с багсерчем по версии, в чем дело?
Jul 31 10:39:16.574 MSK: %SYS-2-CHUNKNOROOT: Root chunk need to be specified for 4000000
-Process= "BGP Update", ipl= 0, pid= 214
-Traceback= 730A88 8376C8 837BF0 FA7298 F365A0
%Software-forced reload
10:39:16 MSK Sun Jul 31 2016: Unexpected exception to CPU: vector 700, PC = 0x88C078  , LR = 0x88BFA0
-Traceback= 88C078 88BFA0 8376D0 837BF0 FA7298 F365A0
---- Partial decode of process block ----
Pid 214: Process "BGP Update "
stack 0x61BBCA0  savedsp 0x3FD59A4
Flags: analyze crashblock prefers_new wakeup_posted process_arg_valid
Status     0x00000000 Orig_ra   0x00000000 Routine    0x00F36444 Signal 0
Caller_pc  0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State  0
Totmalloc  95229560   Totfree   1351248    Totgetbuf  0
Totretbuf  0          Edisms    0x0        Eparm 0x0
Elapsed    0x11D838   Ncalls    0xB9740    Ngiveups 0x583
Priority_q 3          Ticks_5s  0          Cpu_5sec   409      Cpu_1min 295
Cpu_5min   370        Stacksize 0x1770     Lowstack 0x1770
Ttyptr     0x3FA4228  Mem_holding 0x4455C8   Thrash_count 0
Wakeup_reasons      0x0FFFFFFF  Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000  Direct_wakeup_minor 0x00000000
Regs R14-R31, CR, PC, MSR at last suspend; R3 from proc creation, PC unused:
    R3 : 00000000  R14: 00000000  R15: 00000000  R16: 00000000  R17: 00000000
    R18: 038D0000  R19: 03E60000  R20: 02E70000  R21: 03B50000  R22: 03B50000
    R23: 038B0000  R24: 03B60000  R25: 061BD3C8  R26: 061BD3CC  R27: 061BD3C4
    R28: 03E60DC4  R29: 059B71F4  R30: 00000000  R31: 00000000  CR: 80000022
    PC : 0083CCB8  MSR: 00009032
версия
Cisco IOS Software, 7200 Software (C7200P-A3JK91S-M), Version 12.2(31)SB18, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 25-Mar-10 11:07 by debajpal
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
xxxx  uptime is 1 day, 36 minutes
System returned to ROM by error - a Software forced crash, PC 0x88C078 at 10:39:25 MSK Sun Jul 31 2016
System restarted at 10:40:42 MSK Sun Jul 31 2016
System image file is "disk0:c7200p-a3jk91s-mz.122-31.SB18.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 7201 (c7201) processor (revision B) with 917504K/65536K bytes of memory.
Processor board ID 78003820
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
1 slot midplane, Version 2.0
Last reset from power-on
1 FastEthernet interface
4 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Спасибо.
У меня такое было, когда использовал NAT и BGP.
Можно подкрутить тайминги и параметры NAT, либо убрать BGP, но это только отсрочит краши, основная проблема это недостаток памяти для трансляций. И судя по рисуемым графикам, памяти не хватает, потому что после того, как количество трансляций превысит определенный порог, начинаются утечки памяти.
Как только я стал выдавать белые IP, проблема решилась.
да ничего,
два аплинка FV с включенным soft реконфигом и один ibgp сосед.
Просто раз падает по bgp update, то и ковырять надо bgp.
Может вам FV убрать? Или хотя бы до /23 срезать. Это будет в два раза меньше префиксов. Ну и софт-реконфиг тоже.
Железка чисто бордер или что-то еще делает? По памяти как?
