Есть следующая схема:
192.168.17.0/24 - MT1 - VLAN провайдера - MT2 - 10.17.18.64/26
Настройки:
MT1:
/interface vlan
add interface=lacp name=vl-101-lacp vlan-id=101
add interface=lacp name=vl-1480-lacp vlan-id=1480
/ip address
add address=192.168.17.254/24 interface=vl-101-lacp network=192.168.17.0
add address=192.168.23.5/30 interface=vl-1480-lacp network=192.168.23.4
add address=192.168.23.9/30 interface=ipip-tun-1 network=192.168.23.8
/interface ipip
add !keepalive local-address=192.168.23.5 name=ipip-tun-1 remote-address=192.168.23.6
/routing ospf instance
set [ find default=yes ] metric-other-ospf=30 redistribute-connected=as-type-1
/routing ospf interface
add interface=ipip-tun-1 network-type=point-to-point
/routing ospf network
add area=backbone network=192.168.23.8/30
/ip ipsec peer
add address=192.168.23.10/32 secret=111
/ip ipsec policy
add dst-address=192.168.23.10/32 sa-dst-address=192.168.23.10 sa-src-address=192.168.23.9 src-address=192.168.23.9/32
MT2:
/interface vlan
add interface=ether1 name=vl-1480-1 vlan-id=1480
add interface=ether3 name=vl-rpc3-1018 vlan-id=1018
/ip address
add address=10.17.18.126/26 interface=vl-rpc3-1018 network=10.17.18.64
add address=192.168.23.6/30 interface=vl-1480-1 network=192.168.23.4
add address=192.168.23.10/30 interface=ipip-tun-1 network=192.168.23.8
/interface ipip
add !keepalive local-address=192.168.23.6 name=ipip-tun-1 remote-address=192.168.23.5
set [ find default=yes ] redistribute-connected=as-type-1
/ip ipsec peer
add address=192.168.23.9/32 secret=111
/ip ipsec policy
add dst-address=192.168.23.9/32 sa-dst-address=192.168.23.9 sa-src-address=192.168.23.10 src-address=192.168.23.10/32
Маршруты в удаленную сеть на MT1:
/ip route> pr
       DST-ADDRESS        PREF-SRC        GATEWAY            DISTANCE
ADo     10.17.18.64/26                     192.168.23.10      110
Маршруты в удаленную сеть на MT2:
/ip route> pr
ADo     192.168.17.0/24                    192.168.23.9       110
Теперь ставлю эксперимент, на МТ1:
/ip ipsec peer
set 0 secret="1"
Сети 192.168.17.0/24 - 10.17.18.64/26 доступны, 192.168.23.10 - 192.168.23.9 нет.
Связь же должна пропасть или не прав? Получается трафик 192.168.17.0/24 - 10.17.18.64/26 не шифруется?
Как шифровать трафик в канале провайдера?
Хотите просто зашифровать туннель - для RouterOS выше 6.30 есть настройка IPSEC непосредственно в настройках туннеля. Просто добавьте свойство "ipsec-secret=ключ" к свойствам ipip туннеля.
Edited by nkusnetsov
Да, хочу шифровать туннель.
Но при попытке создания туннеля с ipsec-secret - ошибка:
/interface ipip
add local-address=192.168.23.5 name=ipip-tun-1 remote-address=192.168.23.6 ipsec-secret=123
cannot enable fastpath together with ipsec yet
Пробовал отключить fastpath в /ip settings - не помогло.
Alexey_G, цитата из вики:
"eoip, gre, ipip interfaces (since 6.33). Eoip, gre, ipip interfaces have per interface setting "allow-fast-path". ..."
То есть, вам надо явно указать для IPIP-туннеля еще один параметр параметр "allow-fast-path=no"
Например:
/interface ipip add allow-fast-path=no ipsec-secret=123 local-address=192.168.23.5 name=ipip-tun-1 remote-address=192.168.23.6
Alexey_G, вопрос по архитектуре сети - если у Вас есть VLAN от провайдера, зачем вы еще внутрь его тоннель прокидываете? Не проще ли сразу трафик между подключенными к VLAN интерфейсами шифровать, не заморачиваясь инкапсуляцией? А то ресурсы теряете, MTU понижаете, конфиг усложняете.
Например:
Спасибо, так заработало
Сетей за MT1 и MT2 много, если в туннельном режме настраивать, то правила для каждого пересечения сетей прописывать или можно одним policy обойтись?
Вроде такого:
/ip ipsec policy add src-address=192.168.0.0/26 dst-address=192.168.0.0/26 action=encrypt tunnel=yes sa-src-address=192.168.23.5 sa-dst-address=192.168.23.6
А так, конечно не хочется производительность снижать.
Alexey_G, если у вас точек подключения к VLAN больше двух, то правила всё равно придется писать отдельно, т.к. для каждого конца IPSEC-соединения нужно использовать свой "sa-dst-address", вот как у Вас "... sa-dst-address=192.168.23.6"
А если только два, MT1 и MT2, тогда можно агрегировать подсети в одно правило.
Сами MT соеденены одним каналом.
При туннельном режиме придется вообще в правилах прописать 0.0.0.0/0, т.к. весь трафик с MT2 будет проходить через MT1.
Попробую в обоих режимах настроить и протестировать.
Насколько я понял, если в src-address/dst-address прописать 0.0.0.0/0, то весь трафик, подпадающий под это условие уйдет в IPSec туннель, вне зависимости от настроек маршрутизации?
Если так, то мне только транспортный режим подходит.
Кстати, нашел почему не работала первоначальная конфигурация:
/ip ipsec policy
Т.е. IPSec внутри туннеля, а надо снаружи:
/ip ipsec policy
add dst-address=192.168.23.5/32 sa-dst-address=192.168.23.5 sa-src-address=192.168.23.6 src-address=192.168.23.6/32
Edited by Alexey_G
