Здравствуйте.
Терминал GEPON BDCOM P3310. На него можно зайти только через консоль. При загрузке интерфейсы есть, но они не активны. Помогите советом. Можно ли его отремонтировать, если да то где это можно сделать.
при загрузки терминала выводит следующие сообщения
Decompress 5267249 byte. Please wait system up...
Warning: Unit 0 Port ge0: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge1: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge2: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge3: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge4: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge5: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge6: Failed to set initial mode: Feature unavailable
Warning: Unit 0 Port ge7: Failed to set initial mode: Feature unavailable
а при выполнении команды show run
Building configuration...
Current configuration:
!version 10.1.0B build 29333
service timestamps log date
service timestamps debug date
service password-encryption
hostname Prigorodnoe-1
ip default-gateway 95.167.80.65
no spanning-tree
spanning-tree bpdu-terminal
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 7 1330455C244F
interface GigaEthernet0/1
switchport pvid 30
interface GigaEthernet0/2
interface GigaEthernet0/3
interface GigaEthernet0/4
interface GigaEthernet0/5
interface GigaEthernet0/6
interface VLAN30
ip address 95.167.80.66 255.255.255.248
vlan 1,30,1008-1015,1101
ip http server
ip sshd enable
time-zone tz 8 0
sntp master 4
sntp server 95.167.80.7
!Pending configurations for absent linecards:
!!slot 0 84
switchport trunk vlan-allowed 30,1008-1015,1101
switchport trunk vlan-untagged none
switchport mode trunk
speed 1000
duplex full
speed 1000
duplex full
