Добрый день,
существует ли у PAT'a на циске аналог опции микротика same (same - gives a particular client the same source/destination IP address from supplied range for each connection.) Или PAT на циске именно таким образом и работает?
NAT FAQ
If no ports are available in the relevant group on the first IP address, NAT moves on to the next IP address in the pool and tries to allocate the original source port requested.
