Всем доброго времени суток! Скажите пожалуйста, возможно ли настроить Openvswitch так чтобы bpdu (rstp) уходили тегированными?
Имею следующую конфигурацию:
Distributor ID: Debian
Description: Debian GNU/Linux 8.4 (jessie)
Release: 8.4
Codename: jessie
Linux node-3 3.2.0-4-amd64 #1 SMP Debian 3.2.78-1 x86_64 GNU/Linux
Конфигурация коммутатора ovs0:
ovs-vsctl list Bridge
_uuid : 977a5dc1-8819-410f-8847-5cdc034dfd1f
auto_attach : []
controller : []
datapath_id : "0000008cfa05d804"
datapath_type : ""
datapath_version : "2.5.0"
external_ids : {}
fail_mode : []
flood_vlans : []
flow_tables : {}
ipfix : []
mcast_snooping_enable: false
mirrors : []
netflow : []
other_config : {rstp-ageing-time="600", rstp-force-protocol-version="2", rstp-priority="14336"}
ports : [1aafc63b-bcc3-440a-91e7-254162612023, 6680924b-fb9d-4d3d-8ff1-0cfd87feb62b, 96c9c85f-a683-4271-ae54-8bb7a63bdb66, a98f9689-7ff2-40b9-b70c-dd790299bafe, fb7707b8-ecc7-4ddf-b4e4-834e2f994379]
protocols : []
rstp_enable : true
rstp_status : {rstp_bridge_id="3.000.008cfa05d804", rstp_bridge_port_id="0000", rstp_designated_id="3.000.008cfa05d804", rstp_designated_port_id="0000", rstp_root_id="3.000.008cfa05d804", rstp_root_path_cost="0"}
sflow : []
status : {}
stp_enable : false
Конфигурация порта tap0 коммутатора ovs0:
ovs-vsctl list Port tap0
_uuid : 1aafc63b-bcc3-440a-91e7-254162612023
bond_active_slave : []
bond_downdelay : 0
bond_fake_iface : false
bond_mode : []
bond_updelay : 0
external_ids : {}
fake_bridge : false
interfaces : [14e6c76b-b909-4af0-84c0-b8cdae61da77]
lacp : []
mac : []
other_config : {rstp-enable="true"}
qos : []
rstp_statistics : {rstp_error_count=1756, rstp_rx_count=0, rstp_tx_count=1, rstp_uptime=1706}
rstp_status : {rstp_designated_bridge_id="3.000.008cfa05d804", rstp_designated_path_cost="0", rstp_designated_port_id="8004", rstp_port_id="8004", rstp_port_role=Designated, rstp_port_state=Forwarding}
statistics : {}
status : {}
tag : []
trunks : [0, 8, 555]
vlan_mode : []
Ну и показатель того что уходят bpdu нетегированными, а приходят (от микротика) тегированными:
root@node-3:~# tcpdump -i tap0 -Uw - | tcpdump -en -r - -vv | grep STP
tcpdump: WARNING: tap0: no IPv4 address assigned
tcpdump: listening on tap0, link-type EN10MB (Ethernet), capture size 65535 bytes
reading from file -, link-type EN10MB (Ethernet)
01:49:21.557499 26:4a:af:47:32:cd > 01:80:c2:00:00:00, 802.3, length 60: LLC, dsap STP (0x42) Individual, ssap STP (0x42) Command, ctrl 0x03: STP 802.1w, Rapid STP, Flags [Proposal, Learn, Forward], bridge-id 3000.00:8c:fa:05:d8:04.8004, length 43
01:49:22.363319 02:13:3d:af:ff:14 > 01:80:c2:00:00:00, ethertype 802.1Q (0x8100), length 57: vlan 555, p 0, LLC, dsap STP (0x42) Individual, ssap STP (0x42) Command, ctrl 0x03: STP 802.1w, Rapid STP, Flags [Learn, Forward], bridge-id 8000.e4:8d:8c:e1:65:ce.8002, length 36
01:49:22.363851 02:13:3d:af:ff:14 > 01:80:c2:00:00:00, ethertype 802.1Q (0x8100), length 57: vlan 8, p 0, LLC, dsap STP (0x42) Individual, ssap STP (0x42) Command, ctrl 0x03: STP 802.1w, Rapid STP, Flags [Learn, Forward], bridge-id 8000.e4:8d:8c:e1:65:ce.8002, length 36
Заранее благодарю за ответ!
Стесняюсь спросить, а кто решил что stp фреймы должны тегироваться?
Микротик шлет мне их тегированными и получается что мои bpdu он не видит, отсюда и возник такой вопрос) tap0 в коммутаторе это openvpn l2 интерфейс...
да тут походу речь про l2-vpn с bpdu-тунелингом
Я портянку не читал, но по-моему тут все же сервер включен в два микротика для резерва и L2 кольцо пытаются разорвать с помощью stp, я бы так не делал, но очень похоже на то
Если быть точнее, то два сервера, на каждом из которых openvswitch. И микротик должен быть включен в два этих серва, но он не реагирует на bpdu..
ничего не знаю про openvswitch и про микротик, но по-моему openvswitch прав, так как работает как свитч и генерит стандартные rstp bpdu, а микротик неправ потому что запускает отдельный инстанс на каждый влан, циска делает также, но она хотя бы совместима с классическим стп на случай таких стыков
