Имеется голова ZTE ZXA C320:
Rack Shelf Slot CfgType RealType Port    HardVer SoftVer         Status
1    1     1    GTGO    GTGOG    8       120301  V1.2.5P3        INSERVICE
1    1     3    PRAM    PRAM     3               V1.01           INSERVICE
1    1     4    SMXA    SMXA     3       110702  V1.2.5P3        INSERVICE
На ней работают онушки huawei, tp-link. Конфиг по минимуму, все в режиме моста. Все ок.
На днях попалась в руки ONU SERCOMM RV6688BCM.MGTS
Онушка подключается, даже проходят пинги, но она постоянно отключается от головы и снова подключается.
Возможно что-то нужно дописать в конфиг?
Дебаг с головы:
May 19 18:34:31 192.168.252.10 2016 May 19 18:34:31 ZTE debug-log:MAC: 29541.44s olt:7 onu:2(1) DEACTIVE ONU success
May 19 18:34:32 192.168.252.10 2016 May 19 18:34:31 ZTE debug-log:
OMCI: 29541.44s olt:7 ont:2 OMCI deactivate result: 0
May 19 18:34:34 192.168.252.10 2016 May 19 18:34:33 ZTE debug-log:MAC: 29543.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:34:44 192.168.252.10 2016 May 19 18:34:43 ZTE debug-log:MAC: 29553.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:34:54 192.168.252.10 2016 May 19 18:34:53 ZTE debug-log:MAC: 29563.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:04 192.168.252.10 2016 May 19 18:35:03 ZTE debug-log:MAC: 29573.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:04 192.168.252.10 2016 May 19 18:35:03 ZTE debug-log:MAC: 29573.45s olt:7 onu:2(1) MUX ACTIVE ONU return value:0
task:MuxOnuState
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.51s olt:7 onu:2(1) RANG OK:265515
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.53s olt:7 onu:2(1) PASSWORD OK:
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.53s olt:7 onu:2(1) ACTIVE ONU success
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.55s olt:7 onu:2(1) OMCC OK
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.58s olt:7 onu:2(1) ALLOCID OK tcont:1
May 19 18:35:05 192.168.252.10 2016 May 19 18:35:04 ZTE debug-log:MAC: 29574.59s olt:7 onu:2(1) ALLOCID OK tcont:257
May 19 18:35:06 192.168.252.10 2016 May 19 18:35:06 ZTE debug-log:
OMCI: 29576.39s olt:7 ont:2 Old ONT
May 19 18:35:06 192.168.252.10 2016 May 19 18:35:06 ZTE debug-log:MAC: 29576.39s olt:7 onu:2(1) REPORT OMCC OK
OMCI: 29576.40s olt:7 ont:2 mibDataSyncAtOlt:91,mibDataSyncAtOnt:91
OMCI: 29576.40s olt:7 ont:2 Not need trigger mib upload
OMCI: 29576.40s olt:7 ont:2 Deliver finished
OMCI: 29576.40s olt:7 ont:2 Mib upload finished, success! syncReason:2.1-period,2-reEst,3-start
Mib sync result report type:0.0-omccReady,1-no report,2-mibDataSync not equal for omccReady,3-mibDataSync not equal for RestoreAPI
May 19 18:35:12 192.168.252.10 2016 May 19 18:35:11 ZTE debug-log:MAC: 29581.64s olt:7 onu:2(1) MUX DEACTIVE ONU return value:0
task:tXponNpPlCtrl
May 19 18:35:12 192.168.252.10 2016 May 19 18:35:11 ZTE debug-log:MAC: 29581.66s olt:7 onu:2(1) DEACTIVE ONU success
OMCI: 29581.66s olt:7 ont:2 OMCC lost
OMCI: 29581.66s olt:7 ont:2 OMCI deactivate result: 0
May 19 18:35:14 192.168.252.10 2016 May 19 18:35:13 ZTE debug-log:MAC: 29583.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:24 192.168.252.10 2016 May 19 18:35:23 ZTE debug-log:MAC: 29593.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:34 192.168.252.10 2016 May 19 18:35:33 ZTE debug-log:MAC: 29603.45s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:44 192.168.252.10 2016 May 19 18:35:43 ZTE debug-log:MAC: 29613.64s olt:7 onu:2(1) SN:SCOM14173675
May 19 18:35:44 192.168.252.10 2016 May 19 18:35:43 ZTE debug-log:MAC: 29613.64s olt:7 onu:2(1) MUX ACTIVE ONU return value:0
task:MuxOnuState
May 19 18:35:45 192.168.252.10 2016 May 19 18:35:44 ZTE debug-log:MAC: 29614.70s olt:7 onu:2(1) RANG OK:265515
May 19 18:35:45 192.168.252.10 2016 May 19 18:35:44 ZTE debug-log:MAC: 29614.72s olt:7 onu:2(1) PASSWORD OK:
Конфиг головы:
Building configuration...
!**********Before interface -- show run on RP start!*********
sdisk disable
set-pnp enable
add-rack rackno 1 racktype C320Rack
add-shelf rackno 1 shelfno 1 shelftype C320_SHELF
add-subcard rackno 1 shelfno 1 slotno 4 subcardno 1 UCDC/1
add-card rackno 1 shelfno 1 slotno 1 GTGO
system-monitor watchdog rackno 1 shelfno 1 slotno 1 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 1 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 1 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 1 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 1 all
system-monitor watchdog rackno 1 shelfno 1 slotno 3 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 3 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 3 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 3 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 3 all
system-monitor watchdog rackno 1 shelfno 1 slotno 4 disable
system-monitor watchdog-duration rackno 1 shelfno 1 slotno 4 value 5
system-monitor endless-loop duration rackno 1 shelfno 1 slotno 4 value 75
system-monitor endless-loop reboot rackno 1 shelfno 1 slotno 4 disable
system-monitor task-suspend-reboot rackno 1 shelfno 1 slotno 4 all
system-monitor inner-port-check disable
his-performance sample disable
his-performance alarm disable
his-performance auto-upload disable
clock
ptp
security port-protect disable
eth-switch max-frame-length 1600
vlan database
vlan 20
vlan 20
ip dhcp snooping
epon
port-location access-node-identifier inband-mac
port-location hostname cc1afab43450
port-location flexible-syntax enable
port-location flexible-syntax add string zte
port-location flexible-syntax add variable access_node_id
port-location flexible-syntax add string Vlan
port-location flexible-syntax add variable cvlan
port-location flexible-syntax add string +1/
port-location flexible-syntax add variable slot
port-location flexible-syntax add string /
port-location flexible-syntax add variable port
port-location flexible-syntax add string :
port-location flexible-syntax add variable onu-id
dhcp-option82 enable
dhcp6-option18 disable
pppoe-plus disable
ndp-lio disable
igmp disable
mld disable
gpon
profile tcont 500M type 4 maximum 500000
gpon
pon
onu-type HG8010C gpon description 1GE
onu-type HG8010C gpon max-tcont 7
onu-type HG8010C gpon max-gemport 32
onu-type HG8010C gpon max-switch-perslot 1
onu-type HG8010C gpon max-flow-perswitch 8
onu-type HG8346M gpon description 4FE,2POTS,WIFI
onu-type HG8346M gpon max-tcont 7
onu-type HG8346M gpon max-gemport 32
onu-type HG8346M gpon max-switch-perslot 1
onu-type HG8346M gpon max-flow-perswitch 8
onu-type RV6688BMC gpon description 4GE,2POTS,WIFI
onu-type RV6688BMC gpon max-tcont 8
onu-type RV6688BMC gpon max-gemport 32
onu-type RV6688BMC gpon max-switch-perslot 8
onu-type RV6688BMC gpon max-flow-perswitch 8
onu-type RV6688BMC gpon max-iphost 1
onu-type RV6688BMC gpon service-mgmt-via-non-omci wifi enable
onu-type TLGP110 gpon description 1GE
onu-type TLGP110 gpon max-tcont 16
onu-type TLGP110 gpon max-gemport 64
onu-type TLGP110 gpon max-switch-perslot 1
onu-type TLGP110 gpon max-flow-perswitch 8
onu-type-if HG8010C eth_0/1
onu-type-if HG8346M eth_0/1
onu-type-if HG8346M eth_0/2
onu-type-if HG8346M eth_0/3
onu-type-if HG8346M eth_0/4
onu-type-if HG8346M pots_0/1
onu-type-if HG8346M pots_0/2
onu-type-if HG8346M wifi_0/1
onu-type-if RV6688BMC eth_0/1
onu-type-if RV6688BMC eth_0/2
onu-type-if RV6688BMC eth_0/3
onu-type-if RV6688BMC eth_0/4
onu-type-if RV6688BMC pots_0/1
onu-type-if RV6688BMC pots_0/2
onu-type-if TLGP110 eth_0/1
uncfg-onu-display-info model version mac sn pw hexpw loid loidpw rid
onu-pnp
ip-service ip-source-guard disable
ip dhcp snooping enable
fan high-threshold 75
interface gpon-olt_1/1/8
onu 2 type RV6688BMC sn SCOMxxxxxxxx
interface gpon-onu_1/1/8:2
name -
sn-bind enable sn
tcont 1 name T1 profile 500M
gemport 1 unicast tcont 1 dir both
switchport mode hybrid vport 1
service-port 1 vport 1 user-vlan 20 vlan 20
port-location format flexible-syntax vport 1
dhcp-option82 enable vport 1
dhcp-option82 trust true replace vport 1
ip dhcp snooping enable vport 1
interface gei_1/4/3
hybrid-attribute copper
negotiation auto
flowcontrol disable
uplink-isolate disable
switchport mode trunk
switchport vlan 20 tag
!**********After interface -- show run on RP start!**********
pon
pon-onu-mng gpon-onu_1/1/8:2
service HSI type internet gemport 1 cos 0 vlan 20
vlan port eth_0/1 mode tag vlan 20
pon
mpnat trans-table aging-time 60
mpnat onu-telnet idle-time 3
mpnat onu-ftp aging-time 5
mpnat onu-snmp aging-time 30
mpnat onu-ftp-data aging-time 5
mpnat onu-mng-port auto-alloc disable
bcm-server listen-port 5000
auto-write disable
user-suspend mode none
alarm disable
alarm confirm
nms-hello-trap disable
alarm trap-confirm retry 1 timeout 30
control-panel
packet-limit all 1000
end
Дебаг с самой онушки:
[PloamHandler] DIS SERIAL NUM 0.
[PloamHandler] DIS SERIAL NUM 1.
[PloamHandler] CONFIGURE PORT ID P65535 M1.
[PloamHandler] DACT ONU.
[PloamHandler] ASSIGN ONU ID 2.
[PloamHandler] CONFIGURE PORT ID P2 M0.
[MJ] socapi.c:5289: create OMCI channel[flow id:0, tcontId:0 tcont queue id:0, gem port2, isEncry:0, priority queue:0]
[PloamHandler] ENCRYPTED PORT ID P2 M0.
[MJ] socapi.c:5326: modify OMCI channel[isEncry:0]
[PloamHandler] ENCRYPTED PORT ID P130 M0.
[PloamHandler] ASSIGN ALLOC ID 2 S0.
[PloamHandler] ASSIGN ALLOC ID 257 S0.
OMCCRX:
RX time : sec 504, usec 649870
33 86 49 0A 01 01 00 00 40 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 4F C8 4C 6E
OMCI Request Message Header
Transaction id = 0x3386
Message type = 0x49 - Get, DB = 0, AR = 1, AK = 0
Device id = 0x0A
Entity class = 257 (0x0101) - Ont2G
Entity instance = 0x0000
OMCI Request Message Content
Attribute mask = 0x4000
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI50:0, AI9, IV0x000000A1.
OMCI Response Message Header
Message type = 0x29 - Get, DB = 0, AR = 0, AK = 1
Device id = 0x0A
OMCI Response Message Content
Result = 0x00 - Command processed successfully
OmccVersion = 0xA0
Padding:
Optional attribute mask = 0x0000
Attribute execution mask = 0x0000
OMCCTX:
TX time : sec 504, usec 673130
33 86 29 0A 01 01 00 00 00 40 00 A0 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 89 0A 05 7A
[iN] ontpmx.c:342: CRCtx: TI13190, PRI0, AI9, MEIC257:0, CRC0x890A057A.
OMCCRX:
RX time : sec 504, usec 678677
33 87 49 0A 00 02 00 00 80 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 64 76 35 00
Transaction id = 0x3387
Device id = 0x0A
Entity class = 2 (0x0002) - OntData
Attribute mask = 0x8000
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI51:0, AI9, IV0x000000A2.
Device id = 0x0A
MibDataSync = 0x5B
Padding:
OMCCTX:
TX time : sec 504, usec 701374
33 87 29 0A 00 02 00 00 00 80 00 5B 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 F1 18 BB DA
[iN] ontpmx.c:342: CRCtx: TI13191, PRI0, AI9, MEIC2:0, CRC0xF118BBDA.
OMCCRX:
RX time : sec 504, usec 706304
33 88 49 0A 00 F7 00 00 20 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 D8 90 00 E8
[MN] pmutil.c:933: Unknown class number: ONU0:0, TI0x3388(13192), MT0x49(AI9), CNI247:0.
[MN] ontpm.c:3899: ValidateRxPacket() failed: TI13192, PRI0, AI9, MEIC247:0, RT0.
Transaction id = 0x3388
Device id = 0x0A
Entity class = 247 (0x00F7) - None
Attribute mask = 0x0000
[MN] pmprint.c:597: Unknown class number.
Padding:
OMCCTX:
TX time : sec 504, usec 720790
33 88 29 0A 00 F7 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 56 E2 E4 FA
[iN] ontpmx.c:342: CRCtx: TI13192, PRI0, AI9, MEIC247:0, CRC0x56E2E4FA.
[MN] ontpmx.c:217: OmciProcessRxPacket() failed.
OMCCRX:
RX time : sec 504, usec 726410
33 89 49 0A 01 07 01 01 00 08 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 28 CB F8 DB
Transaction id = 0x3389
Device id = 0x0A
Entity class = 263 (0x0107) - AniG
Entity instance = 0x0101
Attribute mask = 0x0008
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI1:257, AI9, IV0x000000A3.
Device id = 0x0A
OntRspTime = 0x0000
Padding:
OMCCTX:
TX time : sec 505, usec 84136
33 89 29 0A 01 07 01 01 00 00 08 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 58 19 24 83
[iN] ontpmx.c:342: CRCtx: TI13193, PRI0, AI9, MEIC263:257, CRC0x58192483.
OMCCRX:
RX time : sec 505, usec 88642
33 8A 4B 0A 00 02 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 E6 AA C3 35
Transaction id = 0x338A
Message type = 0x4B - Get all alarms, DB = 0, AR = 1, AK = 0
Device id = 0x0A
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI52:0, AI11, IV0x000000A4.
Message type = 0x2B - Get all alarms, DB = 0, AR = 0, AK = 1
Device id = 0x0A
Number Of subsequent commands = 0x0001
Padding:
OMCCTX:
TX time : sec 505, usec 110953
33 8A 2B 0A 00 02 00 00 00 01 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 58 D6 AF 73
[iN] ontpmx.c:342: CRCtx: TI13194, PRI0, AI11, MEIC2:0, CRC0x58D6AF73.
OMCCRX:
RX time : sec 505, usec 116423
33 8B 49 0A 00 07 00 00 F0 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 4C 01 FC BD
Transaction id = 0x338B
Device id = 0x0A
Entity class = 7 (0x0007) - SwImage
Attribute mask = 0xF000
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI72:0, AI9, IV0x000000A5.
Device id = 0x0A
Version = 7363332E312E3433000000000000
IsCommitted = 0x00
IsActive = 0x00
IsValid = 0x01
Padding:
OMCCTX:
TX time : sec 505, usec 143087
33 8B 29 0A 00 07 00 00 00 F0 00 73 63 33 2E 31
2E 34 33 00 00 00 00 00 00 00 00 01 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 A4 B2 7C 6D
[iN] ontpmx.c:342: CRCtx: TI13195, PRI0, AI9, MEIC7:0, CRC0xA4B27C6D.
OMCCRX:
RX time : sec 505, usec 149119
33 8C 49 0A 00 07 00 01 F0 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 98 DD 68 00
Transaction id = 0x338C
Device id = 0x0A
Entity instance = 0x0001
Padding:
[iN] ontpmx.c:199: ProcessMsg: MEI72:1, AI9, IV0x000000A6.
Device id = 0x0A
IsCommitted = 0x01
IsActive = 0x01
IsValid = 0x01
Padding:
OMCCTX:
TX time : sec 505, usec 177895
33 8C 29 0A 00 07 00 01 00 F0 00 73 63 33 2E 31
2E 34 33 00 00 00 00 00 00 01 01 01 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 FB 12 B6 FC
[iN] ontpmx.c:342: CRCtx: TI13196, PRI0, AI9, MEIC7:1, CRC0xFB12B6FC.
OMCCRX:
RX time : sec 505, usec 517329
33 8D 4C 0A 00 02 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 4C DD 37 A2
Transaction id = 0x338D
Message type = 0x4C - Get all alarms next, DB = 0, AR = 1, AK = 0
Device id = 0x0A
Command sequence number = 0x0000
Padding:
Message type = 0x2C - Get all alarms next, DB = 0, AR = 0, AK = 1
Device id = 0x0A
Entity class reported alarms = 0x0100 - OntG
Entity instance reported alarms = 0x0000
Alarms bitmap = 0x20000000000000000000000000000000000000000000000000000000
OMCCTX:
TX time : sec 505, usec 533802
33 8D 2C 0A 00 02 00 00 01 00 00 00 20 00 00 00
00 00 00 00 00 00 00 00 00 00 00 28 58 3D 7B C4
[iN] ontpmx.c:342: CRCtx: TI13197, PRI0, AI12, MEIC2:0, CRC0x583D7BC4.
[MJ] socapi.c:5367: remove OMCI channel[tcontId:0, rate control id:716231564, tcont queue id:0]
Подскажите в какую сторону копать?
вам нужно гуглить это сообщение:
Если в кратце, то вы какой-то конфиг в онушку засунули, попытались выгрузить, чтобы сверить, а он оказался другим.
Скорее всего какая-то из команд конфигурации не поддерживается, но молча проглатывается, вместо возвращения omci error.
к сожалению ничего не гуглиться по этому сообщению (
судя по дебагу с онушки не поддерживается Entity class = 247 (0x00F7)
OMCCRX:
Device id = 0x0A
Padding:
но что это за класс такой?
Лучше наверное у ребят из ZTE спросить, или это не вариант?
Можете написать мне ЛС с полным дебагом с обоих сторон, я посмотрю более конкретно.
На голове хуавей сие чудо работает в таком режыме - на голове конфиг под бридж, на ону - подключение ВАН. Прошивка от МГТС страшно урезана. Вай-фай плавает. Вебка грузиться долго.
П.С. Чем такой дебаг делаете?
Edited by Dobromyr
Ужас. Зачем вы такое говно к себе тащите? Еще и eci в таком засветился.
Невозможность работать нормальным бриджем - это какое-то признание умственной отсталости (учитывая, что в стандарте прямо описана необходимость поддержки такого конфига).
А у ТС там похоже залочка под конкретную olt, или очень старое оборудование.
' timestamp='1464758338' post=1287762]
Ну я не тащил. Взял на тест, понял, что толку не будет, отдал назад )) Тока хуавей, тп-линк (и то есть нюансы). Еще нетис неплохо работает, то нет на рынке.
Шифрование-то включено, или по-старинке, хакер вася пупкин видит у себя на ONU весь downstream-трафик?
Это я к тому, что алгоритмы у них несколько разные.
Такой дебаг в консоле, если включить дебаг GPON через веб интерфейс.
Вообщем проблема решилась даунгрейдом головы на прошивку V1.2.5P2
This topic is now closed to further replies.
