Добрый день.
Имеется RB2011UiAS-RM, не удается поднять PPPoE соединение до провайдера, MT не видит приходящих пакетов PADO.
Конфигурация:
/export compact
# RouterOS 6.35.1
/interface vlan
add interface=ether6 name=VL_ISP1 vlan-id=4
add interface=ether6 name=VL_ISP2 vlan-id=5
add interface=if-lacp name=VL_ISP1_2 vlan-id=4
add interface=if-lacp name=VL_DMZ vlan-id=142
add interface=if-lacp name=VL_LOCAL vlan-id=140
add interface=if-lacp name=VL_TECH vlan-id=143
/interface bridge
add name=br-manage protocol-mode=none
add name=brTest protocol-mode=none
add name=internet protocol-mode=none
/interface bridge port
add bridge=br-manage interface=VL_TECH
add bridge=br-manage interface=ether10
add bridge=internet interface=VL_ISP2
add bridge=internet interface=ether9
add bridge=brTest interface=VL_ISP1
add bridge=brTest interface=VL_ISP1_2
add bridge=br-manage interface=ether8
/interface pppoe-client
add add-default-route=yes interface=VL_ISP2 name=INTERNET_ISP2 password=\
   pwd user=usr
/ppp profile
set *0 change-tcp-mss=default
/interface bonding
add mode=802.3ad name=if-lacp slaves=ether1,ether2
/ip address
add address=192.168.168.62/26 interface=VL_TECH network=192.168.168.0
Лог MT:
may/10 17:11:17 pppoe,ppp,info INTERNET_ISP2: initializing...
may/10 17:11:17 pppoe,ppp,info INTERNET_ISP2: connecting...
may/10 17:11:17 pppoe,debug,packet VL_ISP2: sent PADI to FF:FF:FF:FF:FF:FF
may/10 17:11:17 pppoe,debug,packet     session-id=0x0000
may/10 17:11:17 pppoe,debug,packet     host-uniq=0x1e70002
may/10 17:11:17 pppoe,debug,packet     service-name=
may/10 17:11:18 pppoe,debug,packet VL_ISP2: sent PADI to FF:FF:FF:FF:FF:FF
may/10 17:11:18 pppoe,debug,packet     session-id=0x0000
may/10 17:11:18 pppoe,debug,packet     host-uniq=0x1e70002
may/10 17:11:18 pppoe,debug,packet     service-name=
may/10 17:11:20 pppoe,debug,packet VL_ISP2: sent PADI to FF:FF:FF:FF:FF:FF
may/10 17:11:20 pppoe,debug,packet     session-id=0x0000
may/10 17:11:20 pppoe,debug,packet     host-uniq=0x1e70002
may/10 17:11:20 pppoe,debug,packet     service-name=
may/10 17:11:21 pppoe,debug,packet VL_ISP2: sent PADI to FF:FF:FF:FF:FF:FF
may/10 17:11:21 pppoe,debug,packet     session-id=0x0000
may/10 17:11:21 pppoe,debug,packet     host-uniq=0x1e70002
may/10 17:11:21 pppoe,debug,packet     service-name=
may/10 17:11:21 pppoe,ppp,info INTERNET_ISP2: terminating...
Показания снифера с того же MT:
No.     Time        Source                Destination           Protocol Length Info
    35 23.460215   Routerbo_7a:00:00     Broadcast             PPPoED   32     Active Discovery Initiation (PADI)
    36 23.462285   Ericsson_00:58:d4     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    37 23.462418   Ericsson_00:c9:bd     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    38 23.462471   Ericsson_00:c9:bc     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    39 23.462600   Ericsson_00:c9:b1     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    40 23.462699   Ericsson_00:a2:0e     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    41 23.462718   Ericsson_00:a2:03     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    42 23.462762   Ericsson_00:93:33     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    43 23.462788   Ericsson_00:a2:0f     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    44 23.462869   Ericsson_00:93:3f     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    45 23.462914   Ericsson_00:93:3e     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    46 23.463419   Ericsson_00:58:c8     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
    47 23.569462   Ericsson_00:58:d3     Routerbo_7a:00:00     PPPoED   60     Active Discovery Offer (PADO) AC-Name='*'
В чем может быть проблема, где подкрутить?
Попробуйте в настройке влана поставить галочку усе сервисе таг, при подключении к некоторым коммутаторам при использовании QinQ без этого не работает.
А почему у вас pppoe-client на interface=VL_ISP2, при это этот же интерфейс - слейв для бриджа bridge=internet interface=VL_ISP2?
У Микротика были какие-то косяки при таком подходе. Попробуйте, для начала, либо интерфейс с бриджа убрать, либо pppoe на бридж перенести.
Бридж создавался для тестов.
Убрал VL_ISP2 из бриджа, соединение установилось, благодарю за помощь.
This topic is now closed to further replies.
