Приветствую спецов по Linux.
Вопрос в названии темы, возможно ли самому обновить драйвер GobiNet в прошивке роутера? или подгружать в ручную?
роутер: 4G LTE ROUTER LR77 V2 http://www.bb-smartcellular.eu/4g-lte-router-lr77-v2/
Нужна поддержка модуля Sierra Wireless AirPrime MC7455 в этом роутере, он пока поддерживает только MC7710, MC7304.
[spoiler=Команда dmesg выдает такое:]
# dmesg
brd: module loaded
RBv2 GPIO Driver
smi fc000000.flash: mtd .name=sp s25fl128 .size=1000000(16M)
smi fc000000.flash: .erasesize = 0x10000(64K)
7 ofpart partitions found on MTD device sp s25fl128
Creating 7 MTD partitions on "sp s25fl128":
0x000000000000-0x000000010000 : "XLoader"
0x000000010000-0x000000030000 : "U-Boot"
0x000000030000-0x000000040000 : "Env1"
0x000000080000-0x0000000a0000 : "Backup"
0x000000100000-0x000000400000 : "Kernel"
0x000000400000-0x000000e00000 : "RootFS"
0x000000e00000-0x000001000000 : "UserFS"
smi fc000000.flash: mtd .name=es mr25h10 .size=20000(0M)
smi fc000000.flash: .erasesize = 0x1000(4K)
1 ofpart partitions found on MTD device es mr25h10
Creating 1 MTD partitions on "es mr25h10":
0x000000000000-0x000000020000 : "DataFS"
tun: Universal TUN/TAP device driver, 1.6
tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
stmmac - user ID: 0x10, Synopsys ID: 0x34
No HW DMA feature register supported
Enhanced/Alternate descriptors
RX Checksum Offload Engine supported (type 2)
TX Checksum insertion supported
Wake-Up On Lan supported
stmmac: probed
eth0: PHY ID 20005c90 at 1 IRQ POLL (stmmac-0:01)
MACB_mii_bus: probed
macb ab000000.eth: eth1: no PHY found
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver rt2800usb
usbcore: registered new interface driver sierra_net
usbcore: registered new interface driver qmi_wwan
GobiNet: 2014-04-15/SWI_2.24
usbcore: registered new interface driver GobiNet
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
spear-ehci e1800000.ehci: SPEAr EHCI
spear-ehci e1800000.ehci: new USB bus registered, assigned bus number 1
spear-ehci e1800000.ehci: irq 26, io mem 0xe1800000
spear-ehci e1800000.ehci: USB 0.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: SPEAr EHCI
usb usb1: Manufacturer: Linux 3.5.0-lsp-3.3.1 ehci_hcd
usb usb1: SerialNumber: e1800000.ehci
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
spear-ohci e1900000.ohci: SPEAr OHCI
spear-ohci e1900000.ohci: new USB bus registered, assigned bus number 2
spear-ohci e1900000.ohci: irq 25, io mem 0xe1900000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: SPEAr OHCI
usb usb2: Manufacturer: Linux 3.5.0-lsp-3.3.1 ohci_hcd
usb usb2: SerialNumber: e1900000.ohci
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
spear-ohci e2100000.ohci: SPEAr OHCI
spear-ohci e2100000.ohci: new USB bus registered, assigned bus number 3
spear-ohci e2100000.ohci: irq 27, io mem 0xe2100000
usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: SPEAr OHCI
usb usb3: Manufacturer: Linux 3.5.0-lsp-3.3.1 ohci_hcd
usb usb3: SerialNumber: e2100000.ohci
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver cdc_wdm
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
USB Serial support registered for generic
usbserial: USB Serial Driver core
usbcore: registered new interface driver cp210x
USB Serial support registered for cp210x
usbcore: registered new interface driver ftdi_sio
USB Serial support registered for FTDI USB Serial Device
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
usbcore: registered new interface driver GobiSerial
USB Serial support registered for GobiSerial
GobiSerial: 2014-04-15/SWI_2.18:GobiSerial
usbcore: registered new interface driver pl2303
USB Serial support registered for pl2303
USB Serial support registered for Sierra USB modem
rtc-ds1390 spi0.0: rtc core: registered ds1390 as rtc0
ISL88013 Watchdog Driver
u32 classifier
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (926 buckets, 3704 max)
ctnetlink v0.93: registering with nfnetlink.
gre: GRE over IPv4 demultiplexor driver
ip_gre: GRE over IPv4 tunneling driver
ip_tables: © 2000-2006 Netfilter Core Team
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
NET: Registered protocol family 15
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
rtc-ds1390 spi0.0: setting system clock to 2016-05-06 09:33:12 UTC (1462527192)
Warning: unable to open an initial console.
VFS: Mounted root (jffs2 filesystem) on device 31:5.
devtmpfs: mounted
Freeing init memory: 120K
usb 1-1: new high-speed USB device number 2 using spear-ehci
usb 1-1: config 1 has an invalid interface number: 8 but max is 4
usb 1-1: config 1 has an invalid interface number: 10 but max is 4
usb 1-1: config 1 has no interface number 1
usb 1-1: config 1 has no interface number 4
usb 1-1: New USB device found, idVendor=1199, idProduct=68c0
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: MC7455
usb 1-1: Manufacturer: Sierra Wireless, Incorporated
usb 1-1: SerialNumber: LQ550500410110xx
GobiSerial 1-1:1.0: GobiSerial converter detected
usb 1-1: GobiSerial converter now attached to ttyUSB6
GobiSerial 1-1:1.2: GobiSerial converter detected
usb 1-1: GobiSerial converter now attached to ttyUSB7
GobiSerial 1-1:1.3: GobiSerial converter detected
usb 1-1: GobiSerial converter now attached to ttyUSB8
GobiNet 1-1:1.8: usb0: register 'GobiNet' at usb-e1800000.ehci-1, QmiNet Ethernet Device, c6:0f:12:48:8f:xx
eth0: device MAC address 00:0a:14:80:df:xx
PHY stmmac-0:10 not found
No MAC Management Counters available
PHY: stmmac-0:01 - Link is Up - 100/Full
HTB: quantum of class 10001 is big. Consider r2q change.
GobiNet 1-1:1.8: usb0: unregister 'GobiNet' usb-e1800000.ehci-1, QmiNet Ethernet Device
GobiNet: probe of 1-1:1.8 failed with error -110
usb 1-1: USB disconnect, device number 2
GobiSerial driver ttyUSB6: GobiSerial converter now disconnected from ttyUSB6
GobiSerial 1-1:1.0: device disconnected
GobiSerial driver ttyUSB7: GobiSerial converter now disconnected from ttyUSB7
GobiSerial 1-1:1.2: device disconnected
GobiSerial driver ttyUSB8: GobiSerial converter now disconnected from ttyUSB8
GobiSerial 1-1:1.3: device disconnected
usb 1-1: new high-speed USB device number 3 using spear-ehci
usb 1-1: USB disconnect, device number 3
usb 1-1: new high-speed USB device number 4 using spear-ehci
nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
GobiNet выдает ошибку и сетевой интерфейс не подключается:
имеется последняя прошивка LR77-v2-5.3.5 и последний драйвер SierraLinuxQMIdriversS2.25N2.36.tar.bz2
что-то спойлер и урл не работают на странице
Edited by Frans
Добавить можно. Для того, чтобы собрать этот драйвер под вашу прошивку, портебен SDK от этой прошивки. Иногда он называется GPL code или типа того. Иными словами, нужны исходники ядра со всеми теми изменениями, что там наворотил производитель.
Прошивка на ядре:
cat /proc/version
Linux version 3.5.0-lsp-3.3.1 (root@localhost) (gcc version 4.9.3 (GCC) ) #1 custom
а вот исходники ядра я не достану, это закрытая чешская контора, делает промышленные роутеры. Для поддержки, даже не регистрирует физических лиц, только организации.
Выковырять из того, что есть на роутере не получится? и скомпилировать вручную, по данным Makefiles в драйвере? потом еще как то устанавливать надо :(
есть список модулей в ядре роутера *.ko в файле: modules.builtin и само ядро роутераkernel
Edited by Frans
Сколько вы готовы заплатить? И сколько роутеров возможно сломать в результате экспирементов?
Как сформируете ответы на эти вопросы - пишите мне в ЛС.
по условиям GPL - обязаны вам, как покупателю, предоставить. можете попробовать стребовать через суд (или как минимум заикнуться об этом).
от самого ядра без исходников толку, скорее всего, 0 целых хрен десятых.
Вот нашел, что:
GPL license. Source codes under GPL license are available free of charge by sending an email to info@conel.cz
попробую им написать.
p.s. ответили быстро.
Написали, что гуляют до вторника, во вторник ответят.
Edited by Frans
Прошивка на ядре:
cat /proc/version
На каком ядре эта прошивка дело десятое. Драйвер, а, вернее, модуль ядра, собирается (кмпилируется) не под версию ядра а под конкретное ядро. С конкретно теми опциями как самого ядра так и компилятора и, в некоторых случаях, именно тем компилятором, с которыми/которым собиралось именно ваше ядро. Так что от прошивки, как её не ковыряй, толку нет.
ну тут вы не правы, все зависит от того, что за модуль.
какой-нибудь драйвер устройства общего назначения вполне возможно собрать с ванильным ядром и подложить к имеющемуся, предварительно поправив версию, у меня много раз в разработках прокатывало.
А бывало, что и не прокатывало. Сколько раз в GCC ломали бинарную совместимость?
Бинарную совместимость с чем? С процессором? Ниразу, это же компилятор :)
Может вы имели ввиду *libc или libstdc*?
Тогда да, совместимость ломается часто, при условии, что вы собираете новым gcc софт под старую платформу, и не линкуетесь статически. Но для ядра/модулей это не важно, как раз их можно собирать разными компиляторами практически безболезненно.
На самом деле подобрать версию компилятора очень легко, почти в каждом бинарнике есть сигнатуры gcc с версиями. Максимум придется ждать, пока нужный gcc соберется из исходников, обычно же их куча готовых уже есть у каждого разработчика.
Вот нашел, что:
Ответили, требуют: название компании и вашей должности, корпоративный мейл
' timestamp='1462731003' post=1280090]
с бинарниками, скомпилеными другой версией же.
попробуйте собрать ядро каким-нить 4.5 а модуль 4.9, расскажете потом.
и да, без конфига ядра модуль в принципе работоспособный не собрать (к примеру, замена аллокатора SLAB на SLUB/SLOB у части бинарников 100% вызывает панику).
ну тут 2 варианта:
1. придумывать компанию/давать корпоративный мэйл
2. говорить, что ты не сотрудник компании, и налегать на то что GPL обязует предоставлять исходники любому покупателю продукции, а не только компаниям.
Вы про что? есть стандартные декларации вызовов именно для таких целей: чтобы любую библиотечную функцию можно было вызвать из любого бинарника независимо от остальных условий: https://ru.wikipedia.org/wiki/%D0%A1%D0%BE%D0%B3%D0%BB%D0%B0%D1%88%D0%B5%D0%BD%D0%B8%D0%B5_%D0%BE_%D0%B2%D1%8B%D0%B7%D0%BE%D0%B2%D0%B5
Т.е. единственное, что требуется от двух компиляторов - иметь равные понятия о соглашениях о вызове.
Это вы скажите nvidia, которое свои модули собирает хрен пойми каким компилятором, а работают они (почти) везде. И да, у меня есть опыт сборки 4.4 -> 4.9, он положительный, хотя я не буду говорить за всех. Ну не заработает - берите другой компилятор, сложно разве?
Не так уж много производителей вообще что-то меняют в стоковых WRS-ядрах, например.
В любом случае, это проблемы, решаемые за пару часов максимум и без конфига ядра, я и не говорил, что заработает 100% сразу :)
' timestamp='1463043586' post=1281145]
ну-ну, слинкуйте 2 объектных файла, один из которых создан gcc 4.5, а второй - 4.9 (или лучше 5.3). потом расскажете как оно работает.
а еще есть такие прелестные моменты, как разный размер типов (тот же size_t может быть int, а может быть long) и т.п...
учите матчасть, нвидиевский ядерный модуль собирается непосредственно на машине куда ставится драйвер. юзерспейс блоб - отдельный разговор.
конфиг правят на ура. да и код ядра порой пилят под свои костыли (хоть и точечно).
да-да,перебрать все комбинации нескольких сотен опций ядра всего лишь...
А что с этим не так? Уже который год линкуюсь с hisilicon'овскими обьектниками, резализующими стек gpon, уже три версии компилятора сменил, а оно до сих пор работает.
Собирается только транслятор вызовов, ибо ядра бывают очень разные, и желательно бы из хеадеров подтянуть нужную инфу. Бинарь самого модуля от этого никак не меняется.
Зачем их слепо перебирать? натраивалиаем strings на ядро, и сравниваем по выводимым сообщениям конфиг. В ядрес очень мало опций, которые бы не добавляли свои уникальные printk.
Ладно, разговор ни о чем, мы живем в параллельных реальностях :)
' timestamp='1463054038' post=1281220]
ну не считая того, что разработчики gcc напрмую заявляют о несовместимости ABI разных веток - ничего :)
как это сделать без пробной пересборки ядра 100500 раз? :)
Вообще, достаточно нужного ключика "-fabi-version=x", но лучше почитать доконца:
https://gcc.gnu.org/onlinedocs/gcc-3.4.4/gcc/C_002b_002b-Dialect-Options.html
Там не 100500 будет, если вообще нет никаких зацепок, в том числе и неизвестна версия ядра (modversion выкорчеваны, в ядре сигнатуры затерты) - да, и такое я повидал.
Опять же, в таком случае зацепкой будут экспортируемые символы стандартных модулей.
Conel мурыжит с ответом, пришлось писать заново с другого адреса.
Появился вопрос, а возможно подсунуть ядру модуль, через insmod GobiNet.ko не изменяя прошивку, написав в скрипт подгрузку этого модуля?
insmod , rmmod роутер понимает:
# rmmod GobiNet.ko
ERROR: Module GobiNet does not exist in /proc/modules
# insmod GobiNet.ko debug=1
insmod: can't read 'GobiNet.ko': No such file or directory
Edited by Frans
insmod нужно полный путь к файлу указывать.
это получится, если модуль не будет занять каким-то процессом после загрузки, иначе придется искать этот процесс и правильно останавливать/запускать его для подмены модуля.
# rmmod GobiNet.ko
rmmod GobiNet, без .ko
insmod /path-to-file/GobiNet.ko
  • 2 months later...
Достал я исходник, не прошло и 3 месяцев. Вот он: https://drive.google.com/a/conel.ru/file/d/0B7j5n6cgpWxfcEs4OERkZ3hiZk0/view?usp=drive_web
Посмотрел я ваш архив.
Вам нужно собирать (предварительно пропатчив, патчи там прилагаются) одно из ядер (там три лежат, надо собирать то, которое соответствует вашей прошивке) и собирать к нему новый модуль gobinet.
Но это архив именно GPL-source, т.е. саму прошивку вы не соберете, для этого нужен SDK или, как минимум, какой-нибудь firmware-mod-kit.
Но вы на правильном пути, и вам остается почитать инструкции по сборке ядра, коих полно на просторах интернета.
Спасибо. Попробую поискать firmware-mod-kit для роутеров Conel, насколько я понял, без этого даже не стоит собирать ядро.
Тут https://bitbucket.org/bbsmartworx/ нашел: ModulesSDK, Toolchains, SNMP-MIB, у меня V2 routers (ARM 926EJ-S), Linux version 3.5.0-lsp-3.3.1 (gcc version 4.9.3 (GCC).
Еще тут: https://github.com/bb-elec/v2-api-public SDK-v2.tgz
Это может пригодится для сборки прошивки?
Edited by Frans
