Всем привет!
Есть стык с другой AS по MBGP, через который нужно установить MSDP подключение. Стык через BGP работает, маршруты получаем и отдаем:
RP/0/0/CPU0:m9-asr01#sh bgp ipv4 multicast
Fri May 6 07:59:42.177 UTC
BGP router identifier XXX.XXX.184.1, local AS number XX787
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0xe0100000 RD version: 77
BGP main routing table version 77
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* iXXX.XXX.146.192/29 10.100.4.2 0 100 0 12714 i
*> XXX.XXX.24.90 0 0 12714 i
* iXXX.XXX.146.201/32 10.100.4.2 0 100 0 12714 i
* iXXX.XXX.146.205/32 10.100.4.2 0 100 0 12714 i
* iXXX.XXX.146.206/32 10.100.4.2 0 100 0 12714 i
* iXXX.XXX.24.20/32 10.100.4.4 0 100 0 ?
*>i 10.100.4.3 0 100 0 ?
* i 10.100.4.4 0 100 0 ?
* iXXX.XXX.24.21/32 10.100.4.3 0 100 0 ?
* iXXX.XXX.24.22/32 10.100.4.4 0 100 0 ?
*>i 10.100.4.4 0 100 0 ?
*> XXX.XXX.24.23/32 0.0.0.0 0 32768 ?
*> XXX.XXX.24.88/30 0.0.0.0 0 32768 ?
* iXXX.XXX.24.96/29 10.100.4.3 0 100 0 ?
* iXXX.XXX.24.104/29 10.100.4.4 0 100 0 ?
*> 193.33.184.1/32 0.0.0.0 0 32768 ?
* i193.33.184.3/32 10.100.4.3 0 100 0 ?
* i193.33.184.4/32 10.100.4.4 0 100 0 ?
router bgp XX787
bgp router-id XXX.XXX.184.1
bgp redistribute-internal
address-family ipv4 multicast
redistribute connected route-policy CONECTED-TO-BGP
neighbor XXX.XXX.24.90
remote-as XX714
route-policy ANY-NETS in
route-policy ANY-NETS out
router msdp
originator-id Loopback6
peer XXX.XXX.146.205
connect-source Loopback6
remote-as 12714
description NBN-MSDP-1
router bgp XX714
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor XXX.XXX.24.89 remote-as XX787
neighbor XXX.XXX.24.89 description ASR01
address-family ipv4
exit-address-family
network XXX.XXX.146.192 mask 255.255.255.248
network XXX.XXX.146.201 mask 255.255.255.255
network XXX.XXX.146.205 mask 255.255.255.255
network XXX.XXX.146.206 mask 255.255.255.255
neighbor XXX.XXX.24.89 activate
exit-address-family
ip msdp peer XXX.XXX.24.23 connect-source Loopback1 remote-as XXX787
ip msdp cache-sa-state
Но MSDP подключение не работает. Висит состояние Listen т.к. в unicast таблице маршрутов нет. Как можно выйти из ситуации, без настройки unicast address-family в BGP? Вот тут вроде все работает через MBGP http://forum.nag.ru/forum/index.php?showtopic=60268
в теме на которую вы ссылаетесь же указано
ip msdp peer 95.90.1.1 remote-as 6434
interface Vlan4060
mtu 9216
ip address 95.90.1.2 255.255.255.252
ip pim bsr-border
ip pim sparse-dense-mode
так что, имхо
interface Vlan4060
mtu 9216
ip pim bsr-border
так что, имхо
Короче тут http://forum.nag.ru/forum/index.php?showtopic=60268 как я понял, MSDP соединение устанавливается непосредственно на стыковых интерфейсах. У меня в итоге так тоже заработало. Но это неудобно т.к. проходится все делать на ASBR роутере.
fox_m
msdp и mbgp решают разные задачи. msdp нужен, чтобы получать пары (source_ip, multicast_dst_ip), а mbgp - просто чтобы RPF пройти. Без mbgp можно легко обойтись - прописать ip mroute или (вариант хуже, очевидно) простой ip route
В смысле? Нет маршрута до пира? L3 связность нужно организовать. если она есть, то дебажьте msdp почему оно не устанавливается
Короче тут http://forum.nag.ru/...showtopic=60268 как я понял, MSDP соединение устанавливается непосредственно на стыковых интерфейсах
ну да, об этом я и написал :) msdp без маршрута в unicast не взлетит
Да, с ASBR все работает, если делать на стыковых интерфейсах. Но я хочу поднять с MSDP с роутера, внутри моей AS.
А ничё, что с другой стороны прописан только один пир? Если нужен MSDP внутри сети (не частый кейс, но я им побеждал баг Cisco), то устанавливайте msdp-пир с вашим ASBR, но лучше задумайтесь о дизайне
Почему вам нужен msdp-пиринг внутри вашей AS?
Я планировал приземлить MSDP на роутер, где у нас RP, где формируются собственные мультикасты и где находятся мультиплексоры. Так удобнее. Теперь же придется как-то получать мультикасты от ASBR.
fox_m
Вы странный. Вам всё равно от ASBR до второго роутера надо как-то гнать мультикаст и тут очевидно 2 варианта. 1ый простой - сделать L2, второй - сделать L3 multicast routing, т.е. поднимать multicast на ASBR и дальше гнать внутрь своей сети - классический вариант это будет PIM в GRT
fox_m
Понятно. Короче придется внутри еще mesh-groupd делать. Что бы мультикасты с ASBR долетели внутрь сети.
