Всем привет
внезапно, по неизвестной причине cisco отказалась принимать модули сфп
до этого проработала длительное время
конфигурация не менялась
модуля не менялись
в логах вот такое
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/1 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/9 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/10 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/11 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/12 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/13 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/14 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/15 is not supported
%ETHPORT-3-IF_UNSUPPORTED_TRANSCEIVER: Transceiver on interface Ethernet1/16 is not supported
линк не поднимает соответсвенно
что ей надо? как лечить?
и второй вопрос, может обновить ее? не поделитесь прошивкой свежей?
у меня
Software
 BIOS:      version 1.5.0
 loader:    version N/A
 kickstart: version 5.1(3)N1(1)
 system:    version 5.1(3)N1(1)
 power-seq: Module 1: version v1.2
 BIOS compile time:       11/30/10
 kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1.bin
 kickstart compile time:  12/6/2011 22:00:00 [12/07/2011 09:08:01]
 system image file is:    bootflash:///n5000-uk9.5.1.3.N1.1.bin
 system compile time:     12/6/2011 22:00:00 [12/07/2011 10:47:44]
Hardware
 cisco Nexus5010 Chassis ("20x10GE/Supervisor")
 Intel(R) Celeron(R) M CPU    with 2065536 kB of memory.
 Device name:
 bootflash:    1003520 kB
Kernel uptime is 0 day(s), 0 hour(s), 8 minute(s), 22 second(s)
Last reset at 336681 usecs after  Wed May  4 14:12:46 2016
 Reason: Reset Requested by CLI command reload
 System version: 5.1(3)N1(1)
 Service:
plugin
 Core Plugin, Ethernet Plugin
нет
sh interface ethernet 1/13 transceiver calibrations
Ethernet1/13
   transceiver is present
   type is 10Gbase-SR
   name is Arista Networks
   part number is SFP-10G-SR
   revision is 0002
   serial number is XCW1227FD0K3
   nominal bitrate is 10300 MBit/sec
   Link length supported for 50/125um OM2 fiber is 82 m
   Link length supported for 50/125um OM3 fiber is 300 m
   cisco id is --
   cisco extended id number is 4
               SFP Internal Calibrations Information
               Slope  Offset      Rx4/Rx3/Rx2/Rx1/Rx0
   Temperature     0      0
   Voltage         0      0
   Current         0      0
   Tx Power        0      0
   Rx Power                       0.0000/0.0000/0.0000/0.0000/0.0000
В логах кроме
что то еще было?
еще вот это постоянно сыпет в логи
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/1 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/9 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/10 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/11 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/12 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/13 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/14 is down (None)
%ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/15 is down (None)
sh interface ethernet 1/1 transceiver calibrations
Покажите, может там проблема. Все SFP 10g?
нет, половина гигабитных модулей
Ethernet1/1
   type is SFP-1000BASE-LX
   name is OEM
   part number is SFP-WDM1.25G-31
   revision is 1.0
   serial number is PD78303376
   nominal bitrate is 1300 MBit/sec
   Link length supported for 9/125um fiber is 3 km
   cisco id is --
SFP calibration is invalid
Скорость принудительно выставлена, там где модуля 1G? Что то подобное когда то встречал.
да
 description UP_MedConv
 no cdp enable
 switchport access vlan 10
 spanning-tree bpduguard disable
 spanning-tree bpdufilter enable
 speed 1000
noname# sh int eth 1/1 status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/1        UP_MedConv         connected 10        full    1000    SFP-1000BAS
Ethernet1/1 is up
 Hardware: 1000/10000 Ethernet, address: 0005.9b27.4188 (bia 0005.9b27.4188)
 Description: UP_MedConv
 MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
 reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation ARPA
 Port mode is access
 full-duplex, 1000 Mb/s, media type is 10G
 Beacon is turned off
 Input flow-control is off, output flow-control is off
 Rate mode is dedicated
 Switchport monitor is off
 EtherType is 0x8100
 Last link flapped 00:43:56
 Last clearing of "show interface" counters 01:09:17
 30 seconds input rate 363848 bits/sec, 291 packets/sec
 30 seconds output rate 227000 bits/sec, 24 packets/sec
 Load-Interval #2: 5 minute (300 seconds)
   input rate 325.48 Kbps, 211 pps; output rate 106.09 Kbps, 7 pps
 RX
   185578 unicast packets  143148 multicast packets  255201 broadcast packets
   583927 input packets  87108756 bytes
   0 jumbo packets  0 storm suppression packets
   0 runts  0 giants  0 CRC  0 no buffer
   0 input error  0 short frame  0 overrun   0 underrun  0 ignored
   0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
   0 input with dribble  0 input discard
   0 Rx pause
 TX
   35012 unicast packets  95 multicast packets  8 broadcast packets
   35115 output packets  26369270 bytes
   0 jumbo packets
   0 output errors  0 collision  0 deferred  0 late collision
   0 lost carrier  0 no carrier  0 babble 0 output discard
   0 Tx pause
 1 interface resets
noname# conf
Enter configuration commands, one per line.  End with CNTL/Z.
noname(config)# int eth 1/1
noname(config-if)# shu
noname(config-if)# no shu
noname(config-if)# sh int eth 1/1 status
Ethernet1/1 is up
 Encapsulation ARPA
 Port mode is access
 EtherType is 0x8100
 Last link flapped 00:00:11
 Last clearing of "show interface" counters 01:09:54
 30 seconds input rate 164248 bits/sec, 176 packets/sec
 30 seconds output rate 6088 bits/sec, 4 packets/sec
   input rate 297.18 Kbps, 200 pps; output rate 85.14 Kbps, 14 pps
 RX
   188130 unicast packets  145086 multicast packets  258715 broadcast packets
   591931 input packets  88079084 bytes
   0 Rx pause
 TX
   35193 unicast packets  104 multicast packets  8 broadcast packets
   35305 output packets  26403055 bytes
   0 jumbo packets
   0 Tx pause
 2 interface resets
и другой порт, 10 гигабитный модуль
noname# sh int eth 1/13 sta
Eth1/13       Ser2_141           notconnec 20        full    10G     10Gbase-SR
Ethernet1/13 is down (Link not connected)
 Hardware: 10000 Ethernet, address: 0005.9b27.4194 (bia 0005.9b27.4194)
 Description: Ser2_141
 MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
 Encapsulation ARPA
 Port mode is access
 full-duplex, 10 Gb/s, media type is 10G
 EtherType is 0x8100
 Last link flapped never
 Last clearing of "show interface" counters never
 30 seconds input rate 0 bits/sec, 0 packets/sec
 30 seconds output rate 0 bits/sec, 0 packets/sec
   input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
 RX
   0 unicast packets  0 multicast packets  0 broadcast packets
   0 input packets  0 bytes
   0 Rx pause
 TX
   0 output packets  0 bytes
   0 jumbo packets
   0 Tx pause
 0 interface resets
noname# conf
noname(config)# int eth 1/13
noname(config-if)# sh int eth 1/13 sta
 Encapsulation ARPA
 Port mode is access
 EtherType is 0x8100
 RX
   0 Rx pause
 TX
   0 jumbo packets
   0 Tx pause
 0 interface resets
да, на 13, 14, 15 ,16 тоже должны быть
а их нет
патчи и модуля меняли
да и не могли сразу куча модулей сгореть одновременно
В первом порту линк всё-таки поднялся?
>Ethernet1/1 is up
>Ethernet1/1 is up
да, в первом поднят линк
Ну? И что вы для этого сделали?
У вас же в первом тоже была такая же ситуация, что и с остальными. Ансапортед трансивер, все дела.
это я делал еще до создания темы
просто сам поднялся
как посмотреть что то типа дебаг лога?
А уровень сигнала проверчяли?
Попробуйте между двумя 10G портами петлю сделать. Линк поднимется?
запетляли 13 и 14 порт, в логах вот такое
2016 May  4 16:45:26 noname %ETHPORT-5-SPEED: Interface Ethernet1/13, operational speed changed to 10 Gbps
2016 May  4 16:45:26 noname %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/13, operational duplex mode changed to Full
2016 May  4 16:45:26 noname %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/13, operational Receive Flow Control state changed to off
2016 May  4 16:45:26 noname %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/13, operational Transmit Flow Control state changed to off
2016 May  4 16:45:26 noname %ETHPORT-5-SPEED: Interface Ethernet1/14, operational speed changed to 10 Gbps
2016 May  4 16:45:26 noname %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/14, operational duplex mode changed to Full
2016 May  4 16:45:26 noname %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/14, operational Receive Flow Control state changed to off
2016 May  4 16:45:26 noname %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/14, operational Transmit Flow Control state changed to off
2016 May  4 16:45:26 noname %ETHPORT-5-IF_UP: Interface Ethernet1/13 is up in mode access
2016 May  4 16:45:26 noname %ETHPORT-5-IF_UP: Interface Ethernet1/14 is up in mode access
получается дело не в кошке? и не модулях на ее стороне?
