Перестал работать доступ по web в виртуалбокс
всякие VBoxManage setproperty websrvauthlibrary null делал, не помогает
/var/www/phpvirtualbox/config.php
<?php
* phpVirtualBox example configuration.
* @version $Id: config.php-example 585 2015-04-04 11:39:31Z imoore76 $
* rename to config.php and edit as needed.
class phpVBoxConfig {
/* Username / Password for system user that runs VirtualBox */
var $username = 'root';
var $password = 'Tester';
/* SOAP URL of vboxwebsrv (not phpVirtualBox's URL) */
var $location = 'http://192.168.1.202:8080/';
/* Default language. See languages folder for more language options.
* Can also be changed in File -> Preferences -> Language in
* phpVirtualBox.
var $language = 'ru';
/* Set the standard VRDE Port Number / Range, e.g. 1010-1020 or 1027 */
var $vrdeports = '9000-9100';
* Not-so-common options / tweaking
// Multiple servers example config. Uncomment (remove /* and */) to use.
// Add ALL the servers you want to use. Even if you have the server set
// above. The default server will be the first one in the list.
var $servers = array(
       array(
               'name' => 'London',
               'username' => 'user',
               'password' => 'pass',
               'location' => 'http://192.168.1.1:18083/',
               'authMaster' => true // Use this server for authentication
       array(
               'name' => 'New York',
               'username' => 'user2',
               'password' => 'pass2',
               'location' => 'http://192.168.1.2:18083/'
// Disable authentication
#var $noAuth = true;
// Host / ip to use for console connections
var $consoleHost = '192.168.1.202';
// Disable "preview" box
#var $noPreview = true;
// Default preview box update interval in seconds
#var $previewUpdateInterval = 30;
/etc/default/virtualbox
# Defaults for VirtualBox.
# Sourced by vboxweb-service on startup
VBOXWEB_USER=root
VBOXWEB_HOST=192.168.1.202
VBOXWEB_PORT=8080
/etc/nginx/conf.d/phpvirtualbox.conf
server {
       listen   192.168.1.202:8080;
       root /var/www/phpvirtualbox/;
       index index.php index.html index.htm;
       location / {
               # First attempt to serve request as file, then
               # as directory, then fall back to index.html
               try_files $uri $uri/ /index.html;
               # Uncomment to enable naxsi on this location
               # include /etc/nginx/naxsi.rules
       # pass the PHP scripts to FastCGI server listening on 1$
       location ~ \.php$ {
               try_files $uri =404;
               fastcgi_split_path_info ^(.+.php)(.*)$;
               fastcgi_pass unix:/var/run/php5-fpm.sock;
               fastcgi_index index.php;
               fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
               include fastcgi_params;
выдает в вебе после ввода логина и пароля:
xception Object
   [message:protected] => Not Allowed (http://192.168.1.202:8080/)
   [string:Exception:private] =>
   [code:protected] => 64
   [file:protected] => /var/www/phpvirtualbox/endpoints/lib/vboxconnector.php
   [line:protected] => 220
   [trace:Exception:private] => Array
           [0] => Array
                   [file] => /var/www/phpvirtualbox/endpoints/lib/vboxconnector.php
                   [line] => 5527
                   [function] => connect
                   [class] => vboxconnector
                   [type] => ->
                   [args] => Array
произошло после выключения виртуальной машины
Edited by fractal
