Привет. Возникла необходимость в балансировке трафика между 2 ISP. Решено перейти на BGP. У провайдера запросил серый IP и номер AS. Настроил BIRD, сессия BGP поднялась, но провайдер не видит моих маршрутов. Вопрос как диагностировать подобные неполадки?
Конфиг BIRD
root@pppoe1:~# cat /etc/bird.conf
# Configure logging
log syslog { debug, trace, info, remote, warning, error, auth, fatal, bug };
#log birdlog { debug, trace, info, remote, warning, error, auth, fatal, bug };
#log stderr all;
#log "tmp" all;
# Override router ID
router id 172.30.100.2;
# You can define your own symbols...
#define xyzzy = (120+10);
#define '1a-a1' = (30+40);
# Define a route filter...
filter lan__filter {
if net ~ 10.222.0.0/19 then accept;
if net ~ 91.230.72.169/30 then accept;
else reject;
#filter sink { reject; }
#filter okay { accept; }
#include "filters.conf";
# Define another routing table
#table testable;
# Turn on global debugging of all protocols
#debug protocols all;
# The direct protocol automatically generates device routes to
# all network interfaces. Can exist in as many instances as you wish
# if you want to populate multiple routing tables with device routes.
#protocol direct {
# interface "-eth*", "*"; # Restrict network interfaces it works with
# This pseudo-protocol performs synchronization between BIRD's routing
# tables and the kernel. If your kernel supports multiple routing tables
# (as Linux 2.2.x does), you can run multiple instances of the kernel
# protocol and synchronize different kernel tables with different BIRD tables.
protocol kernel {
# learn; # Learn all alien routes from the kernel
# persist; # Don't remove routes on bird shutdown
scan time 20; # Scan kernel routing table every 20 seconds
# import none; # Default is import all
export all; # Default is export none
# kernel table 5; # Kernel table to synchronize with (default: mai n)
# This pseudo-protocol watches all interface up/down events.
protocol device {
scan time 10; # Scan interfaces every 10 seconds
# Static routes (again, there can be multiple instances, so that you
# can disable/enable various groups of static routes on the fly).
protocol bgp {
# disabled;
description "B";
local as 65168;
neighbor 172.30.100.1 as 65500;
# multihop;
# hold time 240;
# startup hold time 240;
# connect retry time 120;
# keepalive time 80; # defaults to hold time / 3
# start delay time 5; # How long do we wait before initial connect
# error wait time 60, 300;# Minimum and maximum time we wait after an erro r (when consecutive
# # errors occur, we increase the delay exponentia lly ...
# error forget time 300; # ... until this timeout expires)
# disable after error; # Disable the protocol automatically when an err or occurs
# next hop self; # Disable next hop processing and always adverti se our local address as nexthop
# path metric 1; # Prefer routes with shorter paths (like Cisco d oes)
# default bgp_med 0; # MED value we use for comparison when none is d efined
# default bgp_local_pref 0; # The same for local preference
export all;
import all;
source address 172.30.100.2 ; # What local address we use for the TCP connection
# password "secret"; # Password used for MD5 authentication
# rr client; # I am a route reflector and the neighor is my c lient
# rr cluster id 1.0.0.1; # Use this value for cluster id instead of my ro uter id
# export where source=RTS_STATIC;
# export filter {
# if source = RTS_STATIC then {
# bgp_community = -empty-; bgp_community = add(bgp_communi ty,(65000,5678));
# bgp_origin = 0;
# bgp_community = -empty-; bgp_community.add((65000,5678)) ;
# if (65000,64501) ~ bgp_community then
# bgp_community.add((0, 1));
# if bgp_path ~ [= 65000 =] then
# bgp_path.prepend(65000);
# accept;
# reject;
# Template usage example
#template bgp rr_client {
# disabled;
# local as 65000;
# multihop;
# rr client;
#protocol bgp rr_abcd from rr_client {
# neighbor 10.1.4.7 as 65000;
Логи BIRD
Mar 23 09:15:35 pppoe1 bird: Restarting protocol kernel1
Mar 23 09:15:35 pppoe1 bird: Restarting protocol device1
Mar 23 09:15:35 pppoe1 bird: Restarting protocol bgp1
Mar 23 09:15:39 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:15:43 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:15:47 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:15:55 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:16:00 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:16:04 pppoe1 bird: sk_open: bind: Cannot assign requested address
Mar 23 09:16:08 pppoe1 bird: sk_open: bind: Cannot assign requested address
Статус BIRD
bird> show protocols
name proto table state since info
kernel1 Kernel master up 09:15
device1 Device master up 09:15
bgp1 BGP master up 09:16 Established
bird> sh route
0.0.0.0/0 via 172.30.100.1 on eth2.244 [bgp1 09:16] * (100) [AS65500i]
bird> ^C
ifconfig
eth2 Link encap:Ethernet HWaddr 90:e2:ba:79:05:e7
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:895898 errors:0 dropped:44 overruns:0 frame:0
TX packets:20765 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:80727888 (76.9 MiB) TX bytes:2471099 (2.3 MiB)
Memory:f7c00000-f7c20000
eth2.244 Link encap:Ethernet HWaddr 90:e2:ba:79:05:e7
inet addr:172.30.100.2 Bcast:172.30.100.3 Mask:255.255.255.252
RX packets:6263 errors:0 dropped:0 overruns:0 frame:0
TX packets:7242 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:383584 (374.5 KiB) TX bytes:541609 (528.9 KiB)
ip r
default via 172.30.100.1 dev eth2.244 proto bird
10.222.0.0/19 dev eth1 proto kernel scope link src 10.222.0.5
172.30.100.0/30 dev eth2.244 proto kernel scope link src 172.30.100.2
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.100
Edited by Рамиль_
source address 91.x.x.x ; # What local address we use for the TCP connection
Думаю этого достаточно чтобы понять где ошибка.
Сменил source address 91.x.x.x на source address 172.30.100.2. Маршрутов в bird больше не стало.
bird> show route
0.0.0.0/0 via 172.30.100.1 on eth2.244 [bgp1 11:53] * (100) [AS65500i]
bird>
В сислоге ошибка пропала.
Какую сеть вы пытаетесь анонсировать?
Я запутался окончательно в маршрутизации. У меня есть два адреса 172.30.100.1 and 172.30.100.2 что бы мой роутер поднял TCP-соединение с роутером провайдера. На этом соединение поднялась bgp-сессия. От провайдера у меня есть еще 1 белый IP-адрес 91.х.х.х в 30 сети. На PC с Debian на борту я настроил eth2.244 (ip 172.30.100.2) Поднялось TCP-соединение.Далее BGP-сессия поднялась между neighbor as 65500 и local as 65168. Задача: мне нужно отправить провайдеру маршрут до моего белого адреса подсети 30, в которой находится мой белый адрес.
Я пока нигде не ошибаюсь в логике работы BGP?
Edited by Рамиль_
Ошибаешься, от начала и до конца. BGP в этой ситуации не нужен абсолютно, надо просто смаршрутизировать выданную подсеть /30 через выданую же пиринговую пару..
Или тупо прописать выданный /30 на интерфейсе и использовать свободный адрес.
Дальше планируется ходить в инет с этим белым ИП и через другого провайдера.
Рамиль_
Это невозможно принципиально.
Почему нет то? Для одного провайдера я буду eBGP маршрутизатором, для другого iBGP. Так не взлетит что ли?
Edited by Рамиль_
Потому что вам провайдер выдал диапазончег 91.х.х.х/30. Мало того что любой уважающий себя ISP реджектит префиксы длиннее 24-х бит, так вы же ему пытаетесь анонсить эту сетку.
ТАК не взлетит )))
ЗЫ. Я бы вообще послушал изначальную задачу. Чего хотите сделать?
Потому что вам провайдер выдал диапазончег 91.х.х.х/30. Мало того что любой уважающий себя ISP реджектит префиксы с маской более 24-х бит, так вы же ему пытаетесь анонсить эту сетку.
ТАК не взлетит )))
Есть 2 ISP. 1 основной, 2 в резерве. Основной вечерами в полке. Хочу использовать оба канала с нормальной балансировкой нагрузки.
С этого и надо было начинать. Балансировать вы можете только исходящий трафик. BGP служит немного для других целей. В вашем случае, кмк, достаточно ip rule + ip route.
Сервис работающий на IP ISP1 никакими танцами не сможет работать через ISP2.
Для этого нужно купить/взять в аренду /24 блок IP + AS и уже ИХ анонсировать любому числу провайдеров. Других путей нет.
Не согласен. Задача ТС: "планируется ходить в инет с этим белым ИП и через другого провайдера" может выполняться. А вот ответы мира ТС через второго провайдера будут только при суммарном совпадении следующих условий:
1. Второй провайдер анонсирует в мир адрес ТС/32. Скорее ОнАнсирует)))
2. Все согласны редистрибутить его /32. ВЕСЬ МИР.
3. Канеш все отключают у себя фильтры из ripe/arin и остальных регуляторов
Чисто теоретически - возможно. Но не более.
