Всем доброго времени суток!
Cisco Catalyst WS-C3750-48PS-S. Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE10, RELEASE SOFTWARE (fc2).
Есть vlan 62, настроен dhcp server с option 82:
ip dhcp pool VLAN62
  network 10.90.21.32 255.255.255.224
  default-router 10.90.21.33
  dns-server 10.90.23.1
  option 42 ip 10.90.23.1
  lease 0 0 30
  class PC1
     address range 10.90.21.36 10.90.21.36
  class PC2
     address range 10.90.21.37 10.90.21.37
Описаны классы:
ip dhcp class PC1
  remark CoreSwitch Fa1/0/11
  relay agent information
     relay-information hex 01060004003e010d02080006001b2b670e00
ip dhcp class PC2
  remark CoreSwitch Fa1/0/12
     relay-information hex 01060004003e010e02080006001b2b670e00
Работало всё отлично, выдавались IP адреса. Но возникла необходимость, что бы в данном пуле, выдавались адреса без привязки к порту. Но не тут то было, dchpd материться в лог:
007690: Mar 20 00:29:35.719 Yakutsk: DHCPD: Sending notification of DISCOVER:
007691: Mar 20 00:29:35.719 Yakutsk:   DHCPD: htype 1 chaddr 001a.4d3d.0c8d
007692: Mar 20 00:29:35.719 Yakutsk:   DHCPD: remote id 0006001b2b670e00
007693: Mar 20 00:29:35.719 Yakutsk:   DHCPD: circuit id 0004003e0112
007694: Mar 20 00:29:35.719 Yakutsk:   DHCPD: interface = Vlan62
007695: Mar 20 00:29:35.719 Yakutsk:   DHCPD: class id 4d53465420352e30
007696: Mar 20 00:29:35.719 Yakutsk:   DHCPD: out_vlan_id 0
007699: Mar 20 00:29:35.719 Yakutsk: DHCPD: Sending notification of ASSIGNMENT FAILURE:
007700: Mar 20 00:29:35.719 Yakutsk:   DHCPD: htype 1 chaddr 001a.4d3d.0c8d
007701: Mar 20 00:29:35.719 Yakutsk:   DHCPD: remote id 020a00000a5a15210e000000
007702: Mar 20 00:29:35.719 Yakutsk:   DHCPD: interface = Vlan62
007703: Mar 20 00:29:35.719 Yakutsk:   DHCPD: class id 4d53465420352e30
007704: Mar 20 00:29:35.719 Yakutsk:   DHCPD: out_vlan_id 0
007705: Mar 20 00:29:35.719 Yakutsk: DHCPD: Sending notification of ASSIGNMENT_FAILURE:
007706: Mar 20 00:29:35.728 Yakutsk:  DHCPD: due to: NO MATCHING CLASS NAME
007707: Mar 20 00:29:35.728 Yakutsk:   DHCPD: htype 1 chaddr 001a.4d3d.0c8d
007708: Mar 20 00:29:35.728 Yakutsk:   DHCPD: remote id 020a00000a5a15210e000000
007709: Mar 20 00:29:35.728 Yakutsk:   DHCPD: interface = Vlan62
007710: Mar 20 00:29:35.728 Yakutsk:   DHCPD: class id 4d53465420352e30
007711: Mar 20 00:29:35.728 Yakutsk:   DHCPD: out_vlan_id 0
Из логов, делаю вывод, что dhcpd не может найти класс, соответсвующий порту, и не даёт хосту адрес. И тут у меня ступор, это "фича" такая? Если в пуле указан хотя бы один класс, то теперь все адреса нужно сопоставить с портами, или как?
Помогите мне разобраться, пожалуйста!
