Доброго времени суток всем, помогите с настройкой DHCP Relay на Dasan v5812g
активировал
service dhcp
ip dhcp helper-address
трафика нет
[root@SMK_plus ~]# tcpdump -nvvei any port 67 or port 68
tcpdump: listening on any, link-type LINUX_SLL (Linux cooked), capture size 65535 bytes
[7]+ Stopped tcpdump -nvvei any port 67 or port 68
[root@SMK_plus ~]#
что еще нужно.
на биллинге DHCP запустился
Mar 8 14:05:49 SMK_plus dhcpd: No subnet declaration for dummy0 (169.1.80.81).
Mar 8 14:05:49 SMK_plus dhcpd: ** Ignoring requests on dummy0. If this is not what
Mar 8 14:05:49 SMK_plus dhcpd: you want, please write a subnet declaration
Mar 8 14:05:49 SMK_plus dhcpd: in your dhcpd.conf file for the network segment
Mar 8 14:05:49 SMK_plus dhcpd: to which interface dummy0 is attached. **
Mar 8 14:05:49 SMK_plus dhcpd: Listening on LPF/eth0/00:1f:29:e0:56:fa/ISC
Mar 8 14:05:49 SMK_plus dhcpd: Sending on LPF/eth0/00:1f:29:e0:56:fa/ISC
Mar 8 14:05:49 SMK_plus dhcpd: Sending on Socket/fallback/fallback-net
заранее спасибо
DHCP Relay вроде работает.
13:58:24.770976 In 00:d0:cb:86:e5:1e ethertype IPv4 (0x0800), length 354: (tos 0x0, ttl 127, id 1546, offset 0, flags [none], proto UDP (17), length 338)
10.1.10.3.bootpc > 10.1.0.2.bootps: [udp sum ok] BOOTP/DHCP, Request from 20:89:84:17:cd:ff, length 310, xid 0x30ccf17e, secs 1024, Flags [broadcast] (0x8000)
Gateway-IP 10.1.10.3
Client-Ethernet-Address 20:89:84:17:cd:ff
Vendor-rfc1048 Extensions
Magic Cookie 0x63825363
DHCP-Message Option 53, length 1: Request
Client-ID Option 61, length 7: ether 20:89:84:17:cd:ff
Requested-IP Option 50, length 4: 10.1.10.15
Hostname Option 12, length 10: "FUJITSU-PC"
FQDN Option 81, length 13: "FUJITSU-PC"
Vendor-Class Option 60, length 8: "MSFT 5.0"
Parameter-Request Option 55, length 12:
Subnet-Mask, Domain-Name, Default-Gateway, Domain-Name-Server
Netbios-Name-Server, Netbios-Node, Netbios-Scope, Router-Discovery
Static-Route, Classless-Static-Route, Classless-Static-Route-Microsoft, Vendor-Option
13:58:24.771457 Out 00:1f:29:e0:56:fa ethertype IPv4 (0x0800), length 344: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 328)
10.1.0.2.bootps > 10.1.10.3.bootps: [bad udp cksum 8357!] BOOTP/DHCP, Reply, length 300, xid 0x30ccf17e, secs 1024, Flags [broadcast] (0x8000)
Your-IP 10.1.10.15
DHCP-Message Option 53, length 1: ACK
Server-ID Option 54, length 4: 10.1.0.2
Lease-Time Option 51, length 4: 172800
Subnet-Mask Option 1, length 4: 255.255.255.0
Default-Gateway Option 3, length 4: 10.1.10.1
Domain-Name-Server Option 6, length 4: 8.8.8.8
13:58:28.861044 In 00:d0:cb:86:e5:1e ethertype IPv4 (0x0800), length 344: (tos 0x0, ttl 127, id 1624, offset 0, flags [none], proto UDP (17), length 328)
10.1.10.3.bootpc > 10.1.0.2.bootps: [udp sum ok] BOOTP/DHCP, Request from 20:89:84:17:cd:ff, length 300, xid 0xc75c0861, Flags [broadcast] (0x8000)
Client-IP 10.1.10.15
DHCP-Message Option 53, length 1: Inform
Parameter-Request Option 55, length 13:
Option 252
13:58:28.861682 Out 00:1f:29:e0:56:fa ethertype IPv4 (0x0800), length 344: (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto UDP (17), length 328)
10.1.0.2.bootps > 10.1.10.15.bootpc: [bad udp cksum cdb4!] BOOTP/DHCP, Reply, length 300, xid 0xc75c0861, Flags [broadcast] (0x8000)
и в логах
> /app/collector/var/log/messages <
Mar 9 14:00:02 SMK_plus wall9359: wall: user root broadcasted 1 lines (66 chars)
Mar 9 14:00:02 SMK_plus wall9400: wall: user root broadcasted 1 lines (67 chars)
Mar 9 14:00:02 SMK_plus wall9701: wall: user root broadcasted 1 lines (66 chars)
Mar 9 14:00:03 SMK_plus wall9740: wall: user root broadcasted 1 lines (67 chars)
Mar 9 14:00:49 SMK_plus dhcpd:
Mar 9 14:00:49 SMK_plus dhcpd: DHCPREQUEST for 10.1.10.15 from 20:89:84:17:cd:ff via 10.1.10.3
Mar 9 14:00:49 SMK_plus dhcpd: DHCPACK on 10.1.10.15 to 20:89:84:17:cd:ff via 10.1.10.3
Mar 9 14:00:54 SMK_plus dhcpd:
Mar 9 14:00:54 SMK_plus dhcpd: DHCPINFORM from 10.1.10.15 via 10.1.10.3
Mar 9 14:00:54 SMK_plus dhcpd: DHCPACK to 10.1.10.15 (20:89:84:17:cd:ff) via eth0
может кто подскажет опции по opt82
Добрый, новый парсер обычно делается на основе старого :)
Выставите получения адреса по маку тогда в messages будет отображаться результат парсинга. Дальше методом научного тыка или с помощью описания формата опции в коммутаторе пишем парсер. Все просто... это как нарисовать сову)
Edited by Red_Sam
спасибо разобрался, АЙПИ выдаются в зависимости от МАК.
нет связи абонента с интернетом.
при проверке пишет
[root@SMK_plus (asr_billing) /]# rtsh session АЙПИ accept
для вашего оборудования не определена комнада session
нужно создать либо использовать стандартную схему
Список оборудования
/var/oss/core/_Cisco_ISG
/var/oss/core/Cisco_Kharino_IPoE
Edited by Andrey75
в диагностике:
Биллинг
Веб-интерфейс биллинга:[ OK ]
Radius-сервер (авторизация)[FAILED]
Radius-сервер (аккаунтинг)[FAILED]
Radius-voip-сервер (авторизация)(отключен)[ OK ]
Radius-voip-сервер (аккаунтинг)(отключен)[ OK ]
Radius-wimax-сервер (авторизация)(отключен)[ OK ]
Radius-wimax-сервер (аккаунтинг)(отключен)[ OK ]
Radius-traf-сервер (авторизация)[ OK ]
Radius-traf-сервер (аккаунтинг)[ OK ]
Размер основной базы данных (35M)[ OK ]
Размер основной базы данных (4.6M)[ OK ]
Проверка работы DNS:[ OK ]
Критические ошибки в логе worker за последний час: 0[ OK ]
Личный кабинет
не стартует радиус, ????
Edited by Andrey75
Не могу сказать почему не стартуют демоны биллинга, к тому же это отдельная тема.
В схемах карбона используется принцип что абоненты "всегда" авторизуются по IP, однако он может быть выдан разными способами.
Заголовок гласит что необходимо настроить именно выдачу адреса. У Вас получилось выдавать по опции, не по MAC-у (т.е вы написали парсер и выдаете адреса на основе классов, сформированных в dhcpd.conf)?
Вы не правильно используете rtsh, надо находиться в oss-каталоге оборудования. Дока http://docs.carbonsoft.ru/pages/viewpage.action?pageId=51708913
