agnitumus Posted February 8, 2016 Posted February 8, 2016 (edited) Итак имеем боевой сервер FreeBSD 9.1-STABLE на нем MPD5(pppoe) + Freeradius Происходит непонятная проблема В этот момент dmesg Copyright © 1992-2013 The FreeBSD Project. Copyright © 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.1-STABLE #4 r249588M: Sun Feb 7 13:47:25 EET 2016 agnitumus@gate.aida.net.ua:/usr/obj/usr/src/sys/GATE amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: Intel® Xeon® CPU E31240 @ 3.30GHz (3292.60-MHz K8-class CPU) Origin = "GenuineIntel" Id = 0x206a7 Family = 0x6 Model = 0x2a Stepping = 7 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Features2=0x1fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> AMD Features2=0x1<LAHF> TSC: P-state invariant, performance statistics real memory = 4294967296 (4096 MB) avail memory = 4058566656 (3870 MB) Event timer "LAPIC" quality 600 ACPI APIC Table: <HP ProLiant> FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 cpu4 (AP): APIC ID: 4 cpu5 (AP): APIC ID: 5 cpu6 (AP): APIC ID: 6 cpu7 (AP): APIC ID: 7 ACPI Warning: Invalid length for Pm1aControlBlock: 32, using default 16 (20110527/tbfadt-638) ACPI Warning: Invalid length for Pm2ControlBlock: 32, using default 8 (20110527/tbfadt-638) ioapic0: Changing APIC ID to 8 ioapic0 <Version 2.0> irqs 0-23 on motherboard netisr_init: forcing maxthreads to 1 and bindthreads to 0 for device polling kbd1 at kbdmux0 acpi0: <HP ProLiant> on motherboard acpi0: Power Button (fixed) cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 950 Event timer "HPET" frequency 14318180 Hz quality 550 atrtc0: <AT realtime clock> port 0x70-0x71 on acpi0 Event timer "RTC" frequency 32768 Hz quality 0 Timecounter "ACPI-safe" frequency 3579545 Hz quality 850 acpi_timer0: <24-bit timer at 3.579545MHz> port 0x908-0x90b on acpi0 pcib0: <ACPI Host-PCI bridge> on acpi0 pci0: <ACPI PCI bus> on pcib0 pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0 pci4: <ACPI PCI bus> on pcib1 pcib2: <ACPI PCI-PCI bridge> at device 6.0 on pci0 pci7: <ACPI PCI bus> on pcib2 pci0: <serial bus, USB> at device 26.0 (no driver attached) pcib3: <ACPI PCI-PCI bridge> at device 28.0 on pci0 pci10: <ACPI PCI bus> on pcib3 pcib4: <ACPI PCI-PCI bridge> at device 28.4 on pci0 pci2: <ACPI PCI bus> on pcib4 em0: <Intel® PRO/1000 Network Connection 7.3.7> port 0x4000-0x401f mem 0xfbee0000-0xfbefffff,0xfbed0000-0xfbed3fff irq 16 at device 0.0 on pci2 em0: MSIX: incorrect vectors, using MSI em0: No MSI/MSIX using a Legacy IRQ em0: Ethernet address: 00:9c:02:9b:ce:08 pcib5: <ACPI PCI-PCI bridge> at device 28.5 on pci0 pci3: <ACPI PCI bus> on pcib5 em1: <Intel® PRO/1000 Network Connection 7.3.7> port 0x5000-0x501f mem 0xfbfe0000-0xfbffffff,0xfbfd0000-0xfbfd3fff irq 17 at device 0.0 on pci3 em1: MSIX: incorrect vectors, using MSI em1: No MSI/MSIX using a Legacy IRQ em1: Ethernet address: 00:9c:02:9b:ce:09 pcib6: <ACPI PCI-PCI bridge> at device 28.6 on pci0 pci13: <ACPI PCI bus> on pcib6 pcib7: <ACPI PCI-PCI bridge> at device 28.7 on pci0 pci1: <ACPI PCI bus> on pcib7 pci1: <base peripheral> at device 0.0 (no driver attached) vgapci0: <VGA-compatible display> mem 0xf9000000-0xf9ffffff,0xfbde0000-0xfbde3fff,0xfb000000-0xfb7fffff irq 16 at device 0.1 on pci1 pci1: <base peripheral> at device 0.2 (no driver attached) pci1: <serial bus, USB> at device 0.4 (no driver attached) pci0: <serial bus, USB> at device 29.0 (no driver attached) pcib8: <PCI-PCI bridge> at device 30.0 on pci0 pci19: <PCI bus> on pcib8 isab0: <PCI-ISA bridge> at device 31.0 on pci0 isa0: <ISA bus> on isab0 atapci0: <Intel Cougar Point SATA300 controller> port 0x1400-0x1407,0x1408-0x140b,0x1410-0x1417,0x1418-0x141b,0x1420-0x142f,0x1430-0x143f irq 17 at device 31.2 on pci0 ata2: <ATA channel> at channel 0 on atapci0 ata3: <ATA channel> at channel 1 on atapci0 atapci1: <Intel Cougar Point SATA300 controller> port 0x1440-0x1447,0x1448-0x144b,0x1450-0x1457,0x1458-0x145b,0x1460-0x146f,0x1470-0x147f irq 17 at device 31.5 on pci0 ata4: <ATA channel> at channel 0 on atapci1 ata5: <ATA channel> at channel 1 on atapci1 acpi_tz0: <Thermal Zone> on acpi0 atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] uart0: <Non-standard ns8250 class UART with FIFOs> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xcafff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 ppc0: cannot reserve I/O port range uart1: <Non-standard ns8250 class UART with FIFOs> at port 0x2f8-0x2ff irq 3 on isa0 est0: <Enhanced SpeedStep Frequency Control> on cpu0 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est0 attach returned 6 p4tcc0: <CPU Frequency Thermal Control> on cpu0 est1: <Enhanced SpeedStep Frequency Control> on cpu1 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est1 attach returned 6 p4tcc1: <CPU Frequency Thermal Control> on cpu1 est2: <Enhanced SpeedStep Frequency Control> on cpu2 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est2 attach returned 6 p4tcc2: <CPU Frequency Thermal Control> on cpu2 est3: <Enhanced SpeedStep Frequency Control> on cpu3 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est3 attach returned 6 p4tcc3: <CPU Frequency Thermal Control> on cpu3 est4: <Enhanced SpeedStep Frequency Control> on cpu4 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est4 attach returned 6 p4tcc4: <CPU Frequency Thermal Control> on cpu4 est5: <Enhanced SpeedStep Frequency Control> on cpu5 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est5 attach returned 6 p4tcc5: <CPU Frequency Thermal Control> on cpu5 est6: <Enhanced SpeedStep Frequency Control> on cpu6 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est6 attach returned 6 p4tcc6: <CPU Frequency Thermal Control> on cpu6 est7: <Enhanced SpeedStep Frequency Control> on cpu7 est: CPU supports Enhanced Speedstep, but is not recognized. est: cpu_vendor GenuineIntel, msr 28d500002200 device_attach: est7 attach returned 6 p4tcc7: <CPU Frequency Thermal Control> on cpu7 Timecounters tick every 1.000 msec IP Filter: v4.1.28 initialized. Default = pass all, Logging = enabled ipfw2 initialized, divert enabled, nat enabled, default to accept, logging disabled DUMMYNET 0 with IPv6 initialized (100409) load_dn_sched dn_sched FIFO loaded load_dn_sched dn_sched PRIO loaded load_dn_sched dn_sched QFQ loaded load_dn_sched dn_sched RR loaded load_dn_sched dn_sched WF2Q+ loaded ada0 at ata2 bus 0 scbus0 target 0 lun 0 ada0: <VB0250EAVER HPG7> ATA-8 SATA 2.x device ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada0: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C) ada0: Previously was known as ad4 ada1 at ata3 bus 0 scbus1 target 0 lun 0 ada1: <VB0250EAVER HPG7> ATA-8 SATA 2.x device ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) ada1: 238475MB (488397168 512 byte sectors: 16H 63S/T 16383C) ada1: Previously was known as ad6 SMP: AP CPU #1 Launched! cd0 at ata5 bus 0 scbus3 target 0 lun 0 cd0: <hp DVD-ROM TS-H353C JG02> Removable CD-ROM SCSI-0 device SMP: AP CPU #3 Launched! cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes) cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed SMP: AP CPU #7 Launched! SMP: AP CPU #4 Launched! SMP: AP CPU #6 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #2 Launched! Timecounter "TSC-low" frequency 1646298649 Hz quality 1000 GEOM_MIRROR: Device mirror/boot launched (2/2). GEOM_MIRROR: Device mirror/root launched (2/2). GEOM_MIRROR: Device mirror/swap launched (2/2). Trying to mount root from ufs:/dev/mirror/root [rw]... loader.conf kern.maxusers=2048 kern.maxfiles=204800 kern.maxfilesperproc=200000 kern.ipc.nmbclusters=132768 kern.ipc.maxsockets=409600 kern.ipc.maxpipekva=70000000 kern.ipc.somaxconn=8388608 kern.ipc.maxsockets=409600 kern.ipc.nmbclusters=1582428 net.inet.tcp.tcbhashsize=65535 # EM tuning hw.em.rxd=4096 hw.em.txd=4096 hw.em.rx_process_limit=4096 hw.em.fc_setting=0 #hw.em.max_interrupt_rate=32000 dev.em.0.rx_int_delay=250 dev.em.0.tx_int_delay=250 dev.em.0.rx_abs_int_delay=4000 dev.em.0.tx_abs_int_delay=4000 dev.em.1.rx_int_delay=250 dev.em.1.tx_int_delay=250 dev.em.1.rx_abs_int_delay=4000 dev.em.1.tx_abs_int_delay=4000 # Networking net.isr.maxthreads=8 net.isr.bindthreads=1 net.isr.defaultqlimit=8192 net.inet.tcp.tcbhashsize=32000 net.link.ifqmaxlen=10240 net.inet.tcp.tso=0 hw.pci.enable_msix=1 hw.pci.enable_msi=1 net.graph.maxdata=256000 net.graph.maxalloc=256000 net.graph.threads=4 net.isr.maxthreads=4 net.isr.bindthreads=0 hw.em.max_interrupt_rate=32000 sysctl.conf net.inet.ip.fw.autoinc_step=10 net.inet.ip.fw.one_pass=0 net.inet.ip.forwarding=1 net.inet.ip.fastforwarding=1 net.inet.ip.dummynet.expire=0 net.inet.ip.dummynet.hash_size=65535 net.inet.ip.dummynet.io_fast=1 net.inet.ip.check_interface=1 net.inet.ip.intr_queue_maxlen=1024 net.inet.tcp.msl=65535 net.inet.tcp.blackhole=2 net.inet.tcp.sack.enable=0 net.inet.tcp.sendspace=231072 net.inet.tcp.recvspace=231072 net.inet.udp.blackhole=1 net.inet.icmp.drop_redirect=1 net.inet.icmp.log_redirect=0 net.inet.icmp.icmplim=10000 net.inet.icmp.maskrepl=0. net.graph.maxdgram=18388680 net.graph.recvspace=18388680 net.link.ether.inet.log_arp_permanent_modify=0 net.link.ether.inet.log_arp_movements=0 net.link.ether.inet.log_arp_wrong_iface=0 net.link.ether.ipfw=0 kern.ipc.maxsockbuf=23175936 net.isr.dispatch=direct net.inet.udp.blackhole=0 net.inet.ip.redirect=0 net.inet.tcp.delayed_ack=0 net.inet.tcp.recvbuf_max=16777216 net.inet.tcp.sendbuf_max=16777216 net.inet.tcp.drop_synfin=1 net.inet.tcp.nolocaltimewait=1 net.inet.ip.sourceroute=0 net.inet.ip.accept_sourceroute=0 net.inet.udp.recvspace=64080 net.inet.ip.rtmaxcache=1024 kern.ipc.nmbclusters=1824288 kern.ipc.maxsockbuf=183886080 kern.ipc.maxsockets=102400 net.local.stream.recvspace=32768 net.local.stream.sendspace=32768 kern.ipc.somaxconn=32768 net.inet.tcp.maxtcptw=65535 net.inet.tcp.sendbuf_inc=16384 net.inet.tcp.recvbuf_inc=524288 # IPFW net.inet.ip.fw.dyn_max=65535 net.inet.ip.fw.dyn_buckets=2048 net.inet.ip.fw.dyn_syn_lifetime=10 net.inet.ip.fw.dyn_ack_lifetime=120 net.inet.ip.fw.verbose=0 # Dummynet net.inet.ip.dummynet.hash_size=65536 net.inet.ip.dummynet.pipe_slot_limit=1000 # ICMP net.inet.icmp.bmcastecho=0 net.inet.icmp.maskrepl=0 # /dev/random optimize networking kern.random.sys.harvest.ethernet=0 kern.random.sys.harvest.point_to_point=0 kern.random.sys.harvest.interrupt=0 net.inet.raw.maxdgram=16384 net.inet.raw.recvspace=16384 net.route.netisr_maxqlen=8192 net.inet.ip.intr_queue_maxlen=10240 net.isr.dispatch=deferred net.inet.icmp.icmplim=65535 kern.ipc.somaxconn=65535 kern.ipc.nmbjumbop=15824288 net.inet.tcp.tso=0 net.inet.tcp.syncache.rexmtlimit=10 net.graph.maxalloc=256000 net.inet.icmp.icmplim=50 net.inet.icmp.icmplim_output=0 net.inet.tcp.icmp_may_rst=0 net.local.stream.sendspace=65535 net.local.stream.recvspace=65536 hw.intr_storm_threshold=9000 net.link.ether.inet.max_age=600 dev.em.0.fc=0 dev.em.1.fc=0 dev.em.0.rx_int_delay=200 dev.em.0.tx_int_delay=200 dev.em.0.rx_abs_int_delay=4000 dev.em.0.tx_abs_int_delay=4000 dev.em.0.rx_processing_limit=4096 dev.em.0.max_interrupt_rate=32000 dev.em.1.rx_int_delay=200 dev.em.1.tx_int_delay=200 dev.em.1.rx_abs_int_delay=4000 dev.em.1.tx_abs_int_delay=4000 dev.em.1.rx_processing_limit=4096 dev.em.1.max_interrupt_rate=32000 Если что-то лишнее подскажите mpd5.conf startup: set user admin admin admin set console self 127.0.0.1 5005 set console open set web self 0.0.0.0. set web open set radsrv peer 172.16.0.2 aidaradmpd set radsrv open set radsrv enable coa disconnect log -all default: load def_conf def_conf: create bundle template B set iface enable proxy-arp set bundle disable compression set iface idle 0 set iface disable on-demand.. set iface enable tcpmssfix set ipcp yes vjcomp set ippool add aidapool 10.0.0.10 10.0.3.254. set ipcp ranges X.Y.Z.0/32 ippool aidapool. set ipcp dns X.Y.Z.1 X.Y.Z.2 set ipcp nbns X.Y.Z.1 X.Y.Z.2 load PPPoE PPPoE: create link template PPPoE pppoe set pppoe iface em0 set pppoe service "*" set pppoe mac-format unix-like set link disable peer-as-calling set link disable multilink set link action bundle B set link mtu 1459 set link max-children 2000 #set link no pap eap #set link enable chap set link disable chap pap eap set link enable pap set link no acfcomp protocomp set link keep-alive 10 120. set link enable incoming load radius radius: set radius server localhost radpwd 1812 1813 set radius retries 5 set radius timeout 10 set radius enable message-authentic set auth acct-update 600 set auth enable radius-auth.... set auth enable radius-acct set ipcp enable radius-ip. set iface enable radius-idle radius-session radius-mtu radius-route. set ccp enable radius set auth disable internal set auth disable acct-mandatory если что-то еще нужно, говорите выложу ! вообще из-за чего lo0 может иметь высокий пинг и потери ? Заранее спасибо P.S: lspci 00:00.0 Host bridge: Intel Corporation Xeon E3-1200 Processor Family DRAM Controller (rev 09) 00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) 00:06.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) 00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) 00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) 00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5) 00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5) 00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5) 00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5) 00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5) 00:1f.0 ISA bridge: Intel Corporation C204 Chipset Family LPC Controller (rev 05) 00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller (rev 05) 00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller (rev 05) 01:00.0 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Slave Instrumentation & System Support (rev 05) 01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH 01:00.2 System peripheral: Hewlett-Packard Company Integrated Lights-Out Standard Management Processor Support and Messaging (rev 05) 01:00.4 USB controller: Hewlett-Packard Company Integrated Lights-Out Standard Virtual USB Controller (rev 02) 02:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection 03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection Edited February 9, 2016 by agnitumus Вставить ник Quote
rdc Posted February 8, 2016 Posted February 8, 2016 прежде всего - вырубите в биосе hyperthreading. и выложите ещё раз те же скрины Вставить ник Quote
agnitumus Posted February 8, 2016 Author Posted February 8, 2016 (edited) прежде всего - вырубите в биосе hyperthreading. и выложите ещё раз те же скрины Спасибо ! Обязательно сегодня попробую ... Попутный вопрос: Это нормально ? Сервер другой ... Edited February 8, 2016 by agnitumus Вставить ник Quote
Ivan_83 Posted February 8, 2016 Posted February 8, 2016 Чем больше ядер - тем больше накладных расходов. net.inet.tcp. net.inet.udp. net.inet.raw. net.inet.icmp. Никак не влияют на пакеты которые роутятся/натятся, это только для случая когда этот хост учавствует в соединении в качестве конечной точки. net.inet.tcp.sack.enable=0 - это зло, на мой взгляд, при дропах скорость передачи с хоста/на хост будет хреновой, но если на него только по ссш ходят по админить то пофик. Вставить ник Quote
kosmich7 Posted February 9, 2016 Posted February 9, 2016 Происходит непонятная проблема Поставьте нормальную igb сетевую. Это нормально ? Сервер другой ... Сокет 2011, два проца, мать какая модель ? Вставить ник Quote
agnitumus Posted February 9, 2016 Author Posted February 9, 2016 (edited) Происходит непонятная проблема Поставьте нормальную igb сетевую. Это нормально ? Сервер другой ... Сокет 2011, два проца, мать какая модель ? ProLiant DL380p Gen8 2xIntel® Xeon® CPU E5-2620 v2 @ 2.10GHz Сеточки 03:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01) 03:00.1 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01) 03:00.2 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01) 03:00.3 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01) 07:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01) 07:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01) <-- ix1 только через него трафик ifconfig ix1 ix1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO> ether 90:e2:ba:97:ab:21 inet 10.0.0.1 netmask 0xffff0000 broadcast 10.0.255.255 inet 10.1.0.1 netmask 0xffff0000 broadcast 10.1.255.255 media: Ethernet autoselect (10Gbase-SR <full-duplex>) status: active Edited February 9, 2016 by agnitumus Вставить ник Quote
agnitumus Posted February 9, 2016 Author Posted February 9, 2016 (edited) прежде всего - вырубите в биосе hyperthreading. и выложите ещё раз те же скрины Спасибо ! Никто и нигде не пишет о том. что hyperthreading может мешать работе ... Надеюсь помогло =) Edited February 9, 2016 by agnitumus Вставить ник Quote
GrandPr1de Posted February 9, 2016 Posted February 9, 2016 прежде всего - вырубите в биосе hyperthreading. и выложите ещё раз те же скрины Спасибо ! Никто и нигде не пишет о том. что hyperthreading может мешать работе ... Надеюсь помогло =) на форумах вечно обсасывают эту проблему и обычно первое предложение в таких темах "выруби hyperthreading" Вставить ник Quote
kosmich7 Posted February 9, 2016 Posted February 9, 2016 Попутный вопрос: Это нормально ? Сервер другой ... Стоп. Давайте по порядку. ОСь, top -SH ? ProLiant DL380p Gen8 2xIntel® Xeon® CPU E5-2620 v2 @ 2.10GHz Что в топе смущает ? У меня при приближении чуть выше этих цифр в топе при двух линках ix сервер начинал скукоживаться.Выньте один проц должно полегчать, в моем случае так и случилось. А трафа сколько netstat -hw1 -I ix0 ? прежде всего - вырубите в биосе hyperthreading. и выложите ещё раз те же скрины Спасибо ! Никто и нигде не пишет о том. что hyperthreading может мешать работе ... Надеюсь помогло =) на форумах вечно обсасывают эту проблему и обычно первое предложение в таких темах "выруби hyperthreading" И чем вырубание помогает ? :) Вставить ник Quote
agnitumus Posted February 9, 2016 Author Posted February 9, 2016 Стоп. Давайте по порядку. ОСь, top -SH ? Думаю попробую вынуть проц ... И чем вырубание помогает ? :) В моёем случае: больше пинг на локальной петле не подымался ... (надеюсь пермаментно) Вставить ник Quote
kosmich7 Posted July 5, 2016 Posted July 5, 2016 Думаю попробую вынуть проц ... Помогло ? Как вопрос решился ? Вставить ник Quote
