Уважаемые форумчане, помогите найти что не так. Не работает проброс порта. Перекопал всю документацию. Помогите пожалуйста.
version 12.1X46-D40.2;
system {
   host-name srx100_1;
   root-authentication {
       encrypted-password "$1$Wyt9BEpJ$T7ECDfFYpuIQYPoaCmjNy."; ## SECRET-DATA
   name-server {
       8.8.8.8;
   login {
       user admin {
           uid 2000;
           class super-user;
           authentication {
               encrypted-password "$1$U.tKjyJY$9s6v./EHIyuYEQGG5LIP1/"; ## SECRET-DATA
   services {
       ssh;
       web-management {
           http {
               interface fe-0/0/1.0;
interfaces {
   fe-0/0/0 {
       unit 0 {
           family inet {
               address 111.111.111.111/29;
   fe-0/0/1 {
       unit 0 {
           family inet {
               address 222.222.222.222/21;
routing-options {
   static {
       route 0.0.0.0/0 next-hop 111.111.111.112;
security {
   address-book {
       global {
           address rdp_server 222.222.222.223/32;
   nat {
       source {
           rule-set trust-to-untrust {
               from zone trust;
               to zone untrust;
               rule source-nat-rule {
                   match {
                       source-address 0.0.0.0/0;
                   then {
                       source-nat {
                           interface;
       destination {
           pool rdp-server {
               address 222.222.222.223/32 port 3389;
           rule-set DNAT {
               from zone untrust;
               rule dnat_for_rdp {
                   match {
                       destination-address 111.111.111.111/32;
                       destination-port 3390;
                   then {
                       destination-nat {
                           pool {
                               rdp-server;
   policies {
       from-zone trust to-zone untrust {
           policy trust-to-untrust {
               match {
                   source-address any;
                   destination-address any;
                   application any;
               then {
                   permit;
       from-zone untrust to-zone trust {
           policy rdp_access {
               match {
                   source-address any;
                   destination-address rdp_server;
                   application any;
               then {
                   permit {
                       destination-address;
   zones {
       security-zone trust {
           host-inbound-traffic {
               system-services {
                   all;
               protocols {
                   all;
           interfaces {
               fe-0/0/1.0;
       security-zone untrust {
           interfaces {
               fe-0/0/0.0 {
                       system-services {
                           ping;
                           ssh;
MonaxGT
show sec flow session:
Session ID: 9003, Policy name: rdp_access/5, Timeout: 16, Valid
In: 333.333.333.333/59101 --> 111.111.111.111/3390;tcp, If: fe-0/0/0.0, Pkts: 3, Bytes: 180
Out: 222.222.222.223/3389 --> 333.333.333.333/59101;tcp, If: fe-0/0/1.0, Pkts: 0, Bytes: 0
show sec nat ru all:
Destination port : 3390
Action : rdp-server
Translation hits : 60
Successful sessions : 60
Number of sessions : 1
edit security nat destination
set pool RDP_client address 192.168.1.2 port 3389
set rule-set DNAT from zone untrust
set rule-set DNAT rule dnat_RDP match destination-address 91.*.*.*
set rule-set DNAT rule dnat_RDP match destination-port 3389
set rule-set DNAT rule dnat_RDP then destination-nat pool RDP_client
top edit security address-book global
set address RDP_client 192.168.1.2
top edit security policies from-zone untrust to-zone trust
set policy RDP_access match source-address any
set policy RDP_access match destination-address RDP_client
set policy RDP_access match application any
set policy RDP_access then permit
Edited by FATHER_FBI
А чем это отличается от моей конфигурации, кроме названий?
Тем что это рабочая конфигурация, которая скопирована с моего джуна
У вас точно RDP сервер слушает порт 3390?
Не сталкивался с джунами но чисто логически если смотреть ТС хочет транслировать запросы на внешний ip и порт 3390 на ip сервера и на порт 3389.
Я вот правда что то запамятовал, а в RDP клиенте порт то можно выставить?
Конечно можно
HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Terminal Server>WinStations>RDP-Tcp>PortNumber
У вас пакеты ушли в сторону машины, обратно нет - вопрос, а у вас точно работает RDP На машине?
На машине можете снифером трафик половить?
