Добрый день!
Решили заменить cisco 7206 на ASR1002.
Перенес конфиг на новую железку, сессия поднимается трафик не ходит. Подскажите куда копать.
Если я правильно понимаю, проблема с отработкой ACL, т.к. исходящий трафик от vpn я wireshark'ок вижу и в ACL (LOCAL_in) он попадает, нету входящего на vpn подключение. Но содержание ACL (всех) - permit ip any any (для тестов)
Данные:
Настройки ISG
class-map type traffic match-any class-local
match access-group input name LOCAL_in
match access-group output name LOCAL_out
policy-map type service policy-local
class type traffic class-local
class type traffic default in-out
policy-map type control RULE1
class type control service-check event service-start
 9 service-policy type service name policy-local
 10 service-policy type service identifier service-name
class type control always event service-start
 10 service-policy type service aaa list PPPoE identifier service-name
 20 service-policy type service identifier service-name
 21 service-policy type service name policy-local
вывод ссесии
#sh sss ses de
Current Subscriber Information: Total sessions 1
Type: VPDN, UID: 30, State: authen, Identity: 123
IPv4 Address: 192.168.100.21
Session Up-time: 00:06:21, Last Changed: 00:06:21
Interface: Virtual-Access2.1
Switch-ID: 4394
Policy information:
 Context 439C2780: Handle 4C00008A
 AAA_id 0000002D: Flow_handle 0
 Authentication status: authen
 Config history for session (recent to oldest):
   Access-type: Web-service-logon Client: SM
    Policy event: Got More Keys (Service)
   Access-type: PPP Client: SM
 Active services associated with session:
   name "ex2"
   name "policy-local"
 Rules, actions and conditions executed:
   subscriber rule-map RULE1
     condition always event session-start
       1 authenticate aaa list PPPoE
       subscriber condition-map match-any service-check
         match identifier service-name ex2 [TRUE]
     condition service-check event service-start
Classifiers:
Class-id    Dir   Packets    Bytes                  Pri.  Definition
0           In    191        18772                  0    Match Any
1           Out   0          0                      0    Match Any
110         In    191        18772                  0    Match ACL LOCAL_in
111         Out   0          0                      0    Match ACL LOCAL_out
112         In    0          0                      100  Match ACL Inet_in
113         Out   0          0                      100  Match ACL Inet_out
4294967294  In    0          0                      -    Drop
4294967295  Out   0          0                      -    Drop
Features:
Absolute Timeout:
Class-id   Timeout Value    Time Remaining       Source
0          86400            23:53:38             Peruser
112        86400            23:53:38             ex2
Prepaid Time Monitor:
Class-id   Dir  Threshold  Quota    Session Time Source
112        In   86397      86400    381          ex2
113        Out  86397      86400    381          ex2
Policing:
Class-id   Dir  Avg. Rate   Normal Burst  Excess Burst Source
113        Out  104857500   19660780      0            ex2
Prepaid Volume Monitor:
Class-id   Dir  Packets    Bytes                  Source
112        In   159        11256                  ex2
113        Out  0          0                      ex2
 Usage(since last update): 11256 - Total: 11256
 Threshold:N/A - Quota:Unlimited
 Current states: Start
Configuration Sources:
Type  Active Time  AAA Service ID  Name
SVC   00:06:21     -               policy-local
SVC   00:06:21     1946157087      ex2
USR   00:06:21     -               Peruser
INT   00:06:21     -               Virtual-Template1
