Добрый день, подскажите кто знает "Brocade NetIron NI-MLX-16" , а то в документации не понятно ...
1) Сколько LAG поддерживает
2) Сколько mac адресов на линейной карте
3) Какие могут быть сюрпризы с переходом, с rx
KEY FEATURES
Service provider grade IPv4/IPv6/MPLS/Multi-VRF enabled metro routers
4-, 8-, 16-, and 32-slot systems for maximum deployment versatility
Up to 2 billion pps routing performance with non-blocking 3.2 Tbps data capacity
Ideal fit for high-density demanding deployments:
• 128 10 Gigabit Ethernet (GbE)/1536 GbE ports per system
• 64 OC-192/256 OC-48 ports per system
Advanced and scalable Metro Ethernet Layer 2 services:
• Super Aggregated VLANs (Q-in-Q)
• Comprehensive set of Layer 2 control protocols: MRP, VSRP, RSTP, MSTP
• IEEE 802.1ad Provider Bridges*
MEF 9 and MEF 14 certified for offering Carrier Ethernet services
Industry leading 320 Gbps link aggregation capability for aggregating up to 32
10 GbE/OC-192 links in provider backbones
Wire-speed dual stack IPv4/IPv6 routing
Wire-speed Provider Edge (PE) and Provider core (P) Label Switching Routers
Industry-leading performance for MPLS services providing several service
choices: IP over MPLS, Virtual Leased Line (VLL), Virtual Private LAN Service
(VPLS), BGP/MPLS VPN, and Multi-VRF
High performance, robust routing via Brocade Direct Routing (BDR) for complete,
distributed programming of the Forwarding Information Base (FIB) in hardware
Full suite of unicast and multicast IPv4 and IPv6 routing protocols:
• Supported IPv4 protocols include RIP, OSPF, BGP-4, IS-IS, PIM-DM, PIM-SM/SSM, IGMP,
BGP-MP for multicast, MSDP, and Anycast RP
• Supported IPv6 protocols include RIPng, OSPFv3, IS-IS for IPv6, BGP-MP for IPv6
(BGP4+), PIM-SM/SSM, and MLD
Comprehensive MPLS signaling and path-calculation algorithms for both trafficengineered and non-traffic-engineered applications:
• OSPF-TE, IS-IS-TE, RSVP-TE, CSPF
• MPLS FRR and Hot Standby paths for traffic protection
• LDP
Secure Multi-VRF routing for supporting Virtual Routing applications over non-MPLS
backbones
Industry-leading scalability up to:**
• 2 million IPv4 BGP routes and up to 512 BGP peers
• 512K IPv4 routes in hardware (FIB)
• 112K IPv6 routes in hardware (FIB)
• 400 BGP/MPLS VPNs and up to 256K VPN routes
• 8K VLLs per system
• 4K VPLS instances and up to 256K VPLS MACs
• 4094 VLANs, and up to 1 million MAC addresses
http://www.cnct.de/fileadmin/user_upload/pdf/PDF-Foundry/Foundry_Datenblaetter_pdf/Brocade_NetIron_MLX.pdf
3 страница / серый прямоугольник
