unfraget Posted January 21, 2016 Posted January 21, 2016 (edited) Здравия всем! Коллеги, имеется дивайс cisco me 6524, который давича ушел в rommon, Причем как-то странно Первая загрузка проходит, видит диски flash, bootflash с образами, после выполнения boot вновь сваливается в rammon, и вот уже кроме как crash info ничего нет. В чем может быть проблема? И как восстановить? rommon 1 > dev Devices in device table: id name bootflash: boot flash disk0: ATA slot 0 disk1: ATA slot 1 eprom: eprom rommon 2 > dir bootflash: File size Checksum File name 24954276 bytes (0x17cc5a4) 0x8d7401e0 s6523-ipbase-mz.122-33.SXH3.bin 31601156 bytes (0x1e23204) 0xa2d145f6 s6523-advipservicesk9-mz.122-33.SXH6.bin 281501 bytes (0x44b9d) 0xe8b190f9 crashinfo_20101007-230345 rommon 5 > dir disk0: Initializing ATA monitor library... Directory of disk0: 2 31601156 -rw- BOOT.BIN rommon 6 > boot Self extracting the image... [OK] Self decompressing the image : ########################################################################################################################################### [OK] Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco IOS Software, s6523_sp Software (s6523_sp-IPBASE-M), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc. Compiled Thu 24-Jul-08 17:20 by prod_rel_team Image text-base: 0x40231348, data-base: 0x41A76130 MAC based EOBC installed 00:00:08: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output. 00:00:08: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch 00:00:13: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output. 00:00:09: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output. Firmware compiled 28-Jun-08 09:47 by integ Build [100] 00:00:13: %OIR-SP-6-CONSOLE: Changing console ownership to route processor System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 2004 by cisco Systems, Inc. Cat6k-MSFC2A platform with 1048576 Kbytes of main memory rommon 1 > dev Devices in device table: id name bootflash: boot flash slot0: PCMCIA slot 0 eprom: eprom rommon 2 > dir bootflash: File size Checksum File name 58368 bytes (0xe400) 0xffffffff crashinfo_20101007-230319 (invalid) rommon 3 > dir slot0: PCMCIA slot0 device is not initialized open: read error...requested 0x4 bytes, got 0x0 trouble reading device magic number dir: cannot open device "slot0:" Edited January 21, 2016 by unfraget Вставить ник Quote
unfraget Posted January 21, 2016 Author Posted January 21, 2016 Пробовал менять память, флешку, результат один Вставить ник Quote
