Доброго времени суток всем.
asr1000-rp2, после обновления rommon с 15.2(1r)S до 15.3(1r)S вылезло следующее:
Initializing Hardware ...
FPGA load not complete !!!
Calculating the ROMMON CRC ... CRC is correct
System Bootstrap, Version 15.3(1r)S, RELEASE SOFTWARE (fc1)
Copyright © 1994-2012 by cisco Systems, Inc.
CPLD Version: 1 (MM/DD/YY): 09/24/13 ASR1000-RP2 Slot:0
Current image running: Boot ROM1
Last reset cause: Watchdog/ICH
Reading confreg 0x8000
Reading monitor variables from NVRAM
Enabling interrupts
Clearing CMOS RAM ...
Initializing SATA controller...done
Initializing USB host controller...done
Checking for PCIe device presence...
Did not recognize HT/FPGA. Got 0xffffffff, Expected 0x00201137
done
ASR1000-RP2 platform with 8388608 Kbytes of main memory
autoboot entry: NVRAM VALUES: bootconf: 0x0, autobootstate: 0
autobootcount: 0, autobootsptr: 0x0
Scooby PartNum read error, expected :0x7b2245, read 0x000000
Failed to read PCA8550 EEPROM DIP device
rommon 1 >
при попытке бута чего-либо получается такое:
rommon 3 > boot harddisk:asr1000rp2-ipbase.03.08.01.S.153-1.S1.bin
Warning: filesystem is not clean
File size is 0x202492f4
Located asr1000rp2-ipbase.03.08.01.S.153-1.S1.bin
Image size 539267828 inode num 12, bks cnt 131658 blk size 8*512
Booting image with bootparam="root=/dev/ram rw console=ttyS2,9600 max_loop=64 crashkernel=128M@16M SR_BOOT=harddi"
Boot image size = 539267828 (0x202492f4) bytes
get_mac_addr: Couldn't find a valid macaddr
Image Base is: 0x000000005d1b2018
Image Size is: 0x202492f4
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated e81a464d:cd070986:06d4270b:bcf3c8d2:385e4ba7
expected e81a464d:cd070986:06d4270b:bcf3c8d2:385e4ba7
Package type:30000, flags:0x0
Parsing package TLV info:
000: 00000009:0000001d:4b45595f:544c565f - KEY_TLV_
010: 5041434b:4147455f:434f4d50:41544942 - PACKAGE_COMPATIB
020: 494c4954:59000000:00000009:0000000b - ILITY
030: 4652555f:52505f54:59504500:00000009 - FRU_RP_TYPE
040: 00000018:4b45595f:544c565f:5041434b - KEY_TLV_PACK
050: 4147455f:424f4f54:41524348:00000009 - AGE_BOOTARCH
060: 0000000e:41524348:5f693638:365f5459 - ARCH_i686_TY
070: 50450000:00000009:00000014:4b45595f - PE KEY_
080: 544c565f:424f4152:445f434f:4d504154 - TLV_BOARD_COMPAT
090: 00000009:0000000e:424f4152:445f7270 - BOARD_rp
0a0: 325f5459:50450000:00000009:00000018 - 2_TYPE
0b0: 4b45595f:544c565f:43525950:544f5f4b - KEY_TLV_CRYPTO_K
0c0: 45595354:52494e47:00000009:00000004 - EYSTRING
TLV(0): T=9, L=29, V=KEY_TLV_PACKAGE_COMPATIBILITY
FRU Key detected
TLV(1): T=9, L=11, V=FRU_RP_TYPE
found package fru type FRU_RP_TYPE
TLV(2): T=9, L=24, V=KEY_TLV_PACKAGE_BOOTARCH
ARCH Key detected
TLV(3): T=9, L=14, V=ARCH_i686_TYPE
found package arch type ARCH_i686_TYPE
TLV(4): T=9, L=20, V=KEY_TLV_BOARD_COMPAT
TLV(5): T=9, L=14, V=BOARD_rp2_TYPE
TLV(6): T=9, L=24, V=KEY_TLV_CRYPTO_KEYSTRING
TLV(7): T=9, L=4, V=none
skipping unknown TLV type 201326592
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): harddisk 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): prep_storage took: 154 seconds, expected max time 10 seconds
%IOSXEBOOT-4-BOOT_SRC: (rp/0): HD Boot
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): platform_specific_mount_media took: 155 seconds, expected max time 3s
Starting IOS XE kernel dump from previous failure.
Expected completion time is less than 5 minutes.
System will automatically reboot within 20 minutes.
Никогда еще не видел такого на asr1000(ни на rp1 ни на rp2)
Может кто знает от чего оно и как его поправить?
PS Заранее спасибо за Ваше время...
