Здравствуйте!
Есть бордер (ipfw NAT, dummynet шейпер) вот такого вида
i5-4460  CPU @ 3.20GHz
4Gb RAM
Freebsd 8.2
Intel(R) PRO/1000 Network Connection version - 2.2.3 - igb
Применен стандартный тюнинг loader.conf sysctl.conf для igb
На нем подсети для абонентов натятся в пул из 48 белых ip. Большую часть времени по нагрузке все нормально, но иногда, в часы пик, вылазит вот такое
   0 root          -68    0     0K   240K -       2  72.2H 36.23% {igb1 que}
   0 root          -68    0     0K   240K -       1  73.2H 35.35% {igb1 que}
   0 root          -68    0     0K   240K -       3  71.6H 33.59% {igb1 que}
   0 root          -68    0     0K   240K -       0  82.0H 29.79% {igb1 que}
В целом по системе
last pid: 74549;  load averages:  4.03,  4.21,  4.21                                                          up 129+13:25:47 20:13:49
148 processes: 16 running, 113 sleeping, 19 waiting
CPU 0:  1.9% user,  0.0% nice, 46.3% system, 42.6% interrupt,  9.3% idle
CPU 1:  0.0% user,  0.0% nice, 35.2% system, 55.6% interrupt,  9.3% idle
CPU 2:  0.0% user,  0.0% nice, 44.4% system, 53.7% interrupt,  1.9% idle
CPU 3:  0.0% user,  0.0% nice, 31.5% system, 61.1% interrupt,  7.4% idle
Mem: 200M Active, 1207M Inact, 652M Wired, 12K Cache, 405M Buf, 1759M Free
Swap: 4096M Total, 4096M Free
 PID USERNAME      PRI NICE   SIZE    RES STATE   C   TIME   WCPU COMMAND
  12 root          -68    -     0K   448K CPU2    2 609.6H 55.86% {irq258: igb0:que}
  12 root          -68    -     0K   448K CPU3    3 615.3H 51.17% {irq259: igb0:que}
  12 root          -68    -     0K   448K CPU0    0 384.1H 50.24% {irq256: igb0:que}
  12 root          -68    -     0K   448K WAIT    1 604.1H 46.44% {irq257: igb0:que}
   0 root          -68    0     0K   240K -       0 1496.6 14.60% {dummynet}
   0 root          -68    0     0K   240K -       1  42.5H 10.64% {igb0 que}
  11 root          171 ki31     0K    64K RUN     1 2284.2  8.40% {idle: cpu1}
  11 root          171 ki31     0K    64K RUN     3 2292.1  6.69% {idle: cpu3}
  11 root          171 ki31     0K    64K RUN     2 2286.5  5.18% {idle: cpu2}
  11 root          171 ki31     0K    64K RUN     0 1074.8  3.37% {idle: cpu0}
   0 root          -68    0     0K   240K RUN     1  23.6H  2.54% {igb0 que}
  12 root          -68    -     0K   448K WAIT    1  76.6H  2.39% {irq262: igb1:que}
  12 root          -68    -     0K   448K RUN     0  78.1H  2.34% {irq261: igb1:que}
   0 root          -68    0     0K   240K -       3  25.0H  2.05% {igb0 que}
  12 root          -68    -     0K   448K RUN     3  77.1H  2.00% {irq264: igb1:que}
  12 root          -68    -     0K   448K RUN     2  77.5H  1.90% {irq263: igb1:que}
   0 root          -68    0     0K   240K -       2  24.1H  0.93% {igb0 que}
  13 root           44    -     0K    32K sleep   1  66:39  0.68% {ng_queue0}
  12 root          -32    -     0K   448K RUN     0  29.1H  0.54% {swi4: clock}
igb1 это сетевая, которая смотрит внутрь локальной сети, и обычно процессы igb1 que не нагружают проц больше чем на доли %
Трафик на сетевой в это время
netstat -w1 -h -I igb1
           input         (igb1)           output
  packets  errs idrops      bytes    packets  errs      bytes colls
      46K     0     0        15M        64K     0        78M     0
      38K     0     0        12M        55K     0        68M     0
      41K     0     0        13M        59K     0        73M     0
На что обратить внимание, что может так загружать эту сетевую?
Обновить систему.
И начать разбираться, откуда от абонентов прилетает мультикаст.
Обновить пора, согласен. Но ведь такая аномалия в нагрузке появляется не всегда, значит дело не в версии ОС.
Значимого количества мультикаста от абонов нет, один пакет в пару секунд не в счет, вот статистика на порту из сети на igb1 в сторону этого сервера
Output packets statistics:
   14147591214 output packets, 5726773091420 bytes, 0 underruns
   1262240916 unicast packets, 146773 multicast packets, 301637 broadcast packets
Что вообще обрабатывается в процессах {igb1 que}? Какой трафик попадает туда а не в {irqххх: igb1:que}?
Неправильное следствие.
Некоторые ОС более спокойнее реагируют на мусор.
Начинайте снимать статистику пакетов с коммутатора.
приведеные данные именно с порта коммутатора, в который включена igb1
Со ссылками ознакомлен. По ним, и не только, ответа на основной вопрос - Что вообще обрабатывается в процессах {igb1 que}? Какой трафик попадает туда а не в {irqххх: igb1:que}? нету. Вообще в найденных темах ни у кого нагрузки такого вида не вылазит.
При включённом фастфорвадинге там обрабатывается всё что приходит с этого интерфейса, там и правила шейпера и фаерволы и нетфлоу и хз что у тебя ещё.
Если очень хочется смотреть что грузит проц:
один раз: kldload hwpmc
и периодически во время загрузки: pmcstat -TS instructions -w1
ещё полезна небольшая доработочка ipfw nat (точнее, libalias) для лимитирования количества трансляций:
/usr/src/sys/netinet/libalias/alias_db.c
AddLink()
добавляем
switch (link_type) {
case LINK_ICMP:
       if(la->icmpLinkCount > 100) return (NULL);
       break;
case LINK_UDP:
       if(la->udpLinkCount > 2000) return (NULL);
       break;
case LINK_TCP:
       if(la->tcpLinkCount > 2000) return (NULL);
       break;
default:
       if(la->protoLinkCount > 100) return (NULL);
       break;
и ещё новость:
https://wiki.freebsd.org/ProjectsRoutingProposal 12MPPS on 16-core box which is 6-10 times better than stock HEAD
  • 2 weeks later...
hwpmc использовать не получилось, в 8.2 он был слишком старый и не работал с установленным процом. Обновился до 10.2, нагружающие проц {igb1 que} из топа пропали, хотя максимальный LA так и остался выше 4. Виновником оказался dummynet, который в top хоть и показывал 0% нагрузки, но по факту нагружал 30% system на одном из ядер. Решением оказалась установка net.inet.ip.dummynet.expire=0 Это снизило нагрузку system, которую создавал dummynet, в 2-2.5 раз и LA в пике теперь до 3.75.
