Помогите с настройкой связки Alcatel 6224 + option82 + isc-dhcpd-server.
Прошивка на коммутаторе: 1.7.1.7
Конфиг коммутатора:
interface range ethernet e1,g2spanning-tree portfast autoexitinterface ethernet g2switchport mode trunkexitvlan databasevlan 1002exitinterface ethernet e1switchport access vlan 1002exitinterface ethernet g2switchport trunk allowed vlan add 1002exitip dhcp snooping ip dhcp snooping information option allowed-untrusted ip dhcp snooping vlan 1002 interface ethernet g2ip dhcp snooping trust exitinterface vlan 1ip address 172.16.0.10 255.255.0.0          exitip default-gateway 172.16.0.1
dhcp.conf
option ms-classless-static-routes code 249 = array of unsigned integer 8;option rfc3442-classless-static-routes code 121 = array of unsigned integer 8;ddns-update-style none;#ddns-update-style interim;#ignore client-updates;default-lease-time 600;max-lease-time 600;authoritative;local-address 172.16.0.2;log-facility local7;option domain-name "intset.ru";option domain-name-servers 10.0.0.11;log(info, "***");if exists agent.circuit-id {       log( info,concat("*Leased ",binary-to-ascii(10,8,".",leased-address)," (with opt82)") );       log( info,concat("*Remote-ID: ",binary-to-ascii(16,8,":",substring(option agent.remote-id,2,6))) );       log( info,concat("*Port: ",binary-to-ascii(10,8,"",suffix(option agent.circuit-id,1))) );#       log( info,concat("*Vlan ",binary-to-ascii(10,16,"",substring(option agent.circuit-id, 2, 2)) );} else {       log( info,concat("*Leased ",binary-to-ascii(10,8,".",leased-address)," (without opt82)") );}log(info, "***");subnet 192.168.200.0 netmask 255.255.255.192 {       option subnet-mask 255.255.255.192;       option broadcast-address 192.168.200.63;       option ms-classless-static-routes 8, 10, 192, 168, 200, 1, 16, 172, 16, 192, 168, 200, 1;       option rfc3442-classless-static-routes 8, 10, 192, 168, 200, 1, 16, 172, 16, 192, 168, 200, 1;       option routers 192.168.200.1;include "/etc/dhcp/switch/u1.conf";}}
class "port-1"{  match if (       binary-to-ascii(10, 16, "",  substring(option agent.circuit-id, 2, 2)) = "1002"       and       binary-to-ascii(10, 8, "",  suffix(option agent.circuit-id, 1)) = "1"   );}pool {range 192.168.200.2; allow members of "port-1"; }
log dhcp:
Jan  5 17:32:14 bmb dhcpd: ***Jan  5 17:32:14 bmb dhcpd: *Leased 192.168.200.2 (with opt82)Jan  5 17:32:14 bmb dhcpd: *Remote-ID: 0:12:cf:86:45:e0Jan  5 17:32:14 bmb dhcpd: *Port: 1Jan  5 17:32:14 bmb dhcpd: ***Jan  5 17:32:14 bmb dhcpd: DHCPDISCOVER from 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:14 bmb dhcpd: DHCPOFFER on 192.168.200.2 to 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:18 bmb dhcpd: ***Jan  5 17:32:18 bmb dhcpd: *Leased 192.168.200.2 (with opt82)Jan  5 17:32:18 bmb dhcpd: *Remote-ID: 0:12:cf:86:45:e0Jan  5 17:32:18 bmb dhcpd: *Port: 1Jan  5 17:32:18 bmb dhcpd: ***Jan  5 17:32:18 bmb dhcpd: DHCPDISCOVER from 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:18 bmb dhcpd: DHCPOFFER on 192.168.200.2 to 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:23 bmb dhcpd: ***Jan  5 17:32:23 bmb dhcpd: *Leased 192.168.200.2 (with opt82)Jan  5 17:32:23 bmb dhcpd: *Remote-ID: 0:12:cf:86:45:e0Jan  5 17:32:23 bmb dhcpd: *Port: 1Jan  5 17:32:23 bmb dhcpd: ***Jan  5 17:32:23 bmb dhcpd: DHCPDISCOVER from 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:23 bmb dhcpd: DHCPOFFER on 192.168.200.2 to 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:25 bmb dhcpd: ***Jan  5 17:32:25 bmb dhcpd: *Leased 192.168.200.2 (with opt82)Jan  5 17:32:25 bmb dhcpd: *Remote-ID: 0:12:cf:86:45:e0Jan  5 17:32:25 bmb dhcpd: *Port: 1Jan  5 17:32:25 bmb dhcpd: ***Jan  5 17:32:25 bmb dhcpd: DHCPDISCOVER from 4c:5e:0c:0b:e8:02 (MikroTik) via eth0Jan  5 17:32:25 bmb dhcpd: DHCPOFFER on 192.168.200.2 to 4c:5e:0c:0b:e8:02 (MikroTik) via eth0
Не отдает ip адреса клиенту если по vlan.
Просьба сбросить примеры конфигурационных файлов, у кого работает такая связка.
у вас dhcp-server находится в vlan? что-то типа via eth0.1002
class "port-1"
  match if (
       and
к своему классу можете показать:
tcpdump -nn -s 0 -v port 67 or port 68
tcpdump -nn -s 0 -v port 67 or port 68 -i eth.1002(?)
и еще, зачем ip dhcp snooping information option allowed-untrusted?
dhcp server находиться в том же влане, верней vlan1 использую как менеджмент vlan.
ip dhcp snooping information option allowed-untrusted - это не мешает и без него не отдают.
vlan 1002 клиентский
я не понял, вы не используете relay, потому и вопрос - dhcp-server с dhcp-client находяться в одном vlan?
клиент--е1(vlan1002)-(ls6224)-g2(vlan1)--L3(коммутатор)--dhcp-server
dhcp-server= 172.16.0.2
ls6224(vlan1)=172.16.0.10
g2-транковый порт
dhcp-server отвечает видит клиента через L3, а с ls6224 в одном влане vlan1
и по этой схеме у меня работают куча свичей(des3526,snr s2960,qsw2800)и нет с ними проблем, а тут привезли ls6224
Пишу с другой учетки
10:55:30.689240 IP (tos 0x0, ttl 128, id 255, offset 0, flags [none], proto UDP (17), length 334)
   0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from e8:03:9a:2f:84:43, length 306, xid 0xb2e368bf, secs 3072, Flags [none]
         Client-Ethernet-Address e8:03:9a:2f:84:43
         Vendor-rfc1048 Extensions
           Magic Cookie 0x63825363
           DHCP-Message Option 53, length 1: Discover
           Client-ID Option 61, length 7: ether e8:03:9a:2f:84:43
           Hostname Option 12, length 7: "ibra-M-^OM-^J"
           Vendor-Class Option 60, length 8: "MSFT 5.0"
           Parameter-Request Option 55, length 12:
             Subnet-Mask, Domain-Name, Default-Gateway, Domain-Name-Server
             Netbios-Name-Server, Netbios-Node, Netbios-Scope, Router-Discovery
             Static-Route, Classless-Static-Route, Classless-Static-Route-Microsoft, Vendor-Option
           Agent-Information Option 82, length 18:
             Circuit-ID SubOption 1, length 6: ^@^D^CM-j^A^A
             Remote-ID SubOption 2, length 8: ^@^F^@^RM-OM-^FEM-`
10:55:31.699563 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 363)
   172.16.0.2.67 > 192.168.200.2.68: BOOTP/DHCP, Reply, length 335, xid 0xb2e368bf, secs 3072, Flags [none]
         Your-IP 192.168.200.2
         Server-IP 172.16.0.2
           DHCP-Message Option 53, length 1: Offer
           Server-ID Option 54, length 4: 172.16.0.2
           Lease-Time Option 51, length 4: 600
           Subnet-Mask Option 1, length 4: 255.255.255.192
           Domain-Name Option 15, length 9: "intset.ru"
           Default-Gateway Option 3, length 4: 192.168.200.1
           Domain-Name-Server Option 6, length 4: 10.0.0.11
           Classless-Static-Route Option 121, length 13: (10.0.0.0/8:192.168.200.1),(172.16.0.0/16:192.168.200.1)
           Classless-Static-Route-Microsoft Option 249, length 13: (10.0.0.0/8:192.168.200.1),(172.16.0.0/16:192.168.200.1)
10:55:31.699670 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 363)
давайте с dhcpdump -i eth0 покажите запрос, а то не понятно:
class "port-1"
  match if (
       and
я так понимаю, если
class "port-1"
  match if (
то работает, а если:
class "port-1"
  match if (
       and
не работает, правильно?
да да!!! так не работает
class "port-1"
  match if (
       and
dhcpdump
Ignored non IPv4 packet: 129
 TIME: 2016-01-06 16:28:54.464
   IP: 172.16.0.2 (68:5:ca:7:6f:30) > 255.255.255.255 (ff:ff:ff:ff:ff:ff)
   OP: 2 (BOOTPREPLY)
HTYPE: 1 (Ethernet)
 HLEN: 6
 HOPS: 0
  XID: 378842b9
 SECS: 0
FLAGS: 7f80
CIADDR: 0.0.0.0
YIADDR: 192.168.200.2
SIADDR: 172.16.0.2
GIADDR: 0.0.0.0
CHADDR: 4c:5e:0c:0b:e8:02:00:00:00:00:00:00:00:00:00:00
SNAME: .
FNAME: .
OPTION:  53 (  1) DHCP message type         2 (DHCPOFFER)
OPTION:  54 (  4) Server identifier         172.16.0.2
OPTION:  51 (  4) IP address leasetime      600 (10m)
OPTION:   1 (  4) Subnet mask               255.255.255.192
OPTION:   3 (  4) Routers                   192.168.200.1
OPTION:   6 (  4) DNS server                10.0.0.11
OPTION:  82 ( 18) Relay Agent Information
                 Circuit-ID    00:04:03:ea:01:01
                 Remote-ID     00:06:00:12:cf:86:45:e0
 TIME: 2016-01-06 16:28:55.552
   OP: 2 (BOOTPREPLY)
HTYPE: 1 (Ethernet)
 HLEN: 6
 HOPS: 0
  XID: a539eab7
 SECS: 0
FLAGS: 7f80
CIADDR: 0.0.0.0
SIADDR: 172.16.0.2
GIADDR: 0.0.0.0
SNAME: .
FNAME: .
Так конфиг на свиче дефолтный.
И настроен по минимум.
В acl тоже пустые. Может есть какие то дефолтные ограничения ?
Тут конфиг непричем. Видно же, что оффер уходит, но до клиента не доходит.
эти ответы, что вы показали, с match на vlan в конфиге dhcp-server?
все работает по этой же схеме на други коммутаторах, у меня от 6 производителей коммутаторы и все работают, а эти алкатели нет ((((((
Edited by OvNazu
ну они в include "/etc/dhcp/switch/u1.conf"
да это понятно, просто уточняю, что этот ответ от dhcp:
сервер отдал при конфиге:
class "port-1"
  match if (
       and
или все же
class "port-1"
  match if (
class "port-1"
  match if (
       and
понятно ))))), а где в конфиге свича ошибся??? сделал как в оф.доках
у кого есть опыт использования alcatel ls6224 помогите
Edited by OvNazu
Давно было дело, кусок конфига, всё работало.
interface range ethernet g(1-2)
switchport trunk allowed vlan add 701
exit
switchport trunk allowed vlan add 771
exit
ip dhcp snooping
ip dhcp snooping database
no ip dhcp snooping verify
ip dhcp snooping vlan 701
interface ethernet g1
exit
exit
