Не приходят от абонентских портов ACK на приём адреса, может что-то в конфиге коммутатора не так?
VLAN30 - Абонентский
VLAN2 - управление
Current configuration:
vlan 2
name manager2
normal 1-8
fixed 9
forbidden ""
untagged ""
ip address default-management 10.100.100.130 255.255.255.0
ip address default-gateway 10.100.100.2
exit
vlan 30
normal ""
fixed 1-9
forbidden ""
untagged 1-8
exit
interface port-channel 1
pvid 30
exit
interface port-channel 2
pvid 30
exit
interface port-channel 3
pvid 30
exit
interface port-channel 4
pvid 30
exit
interface port-channel 5
pvid 30
exit
interface port-channel 6
pvid 30
exit
interface port-channel 7
pvid 30
exit
interface port-channel 8
pvid 30
exit
interface port-channel 9
name uplink
exit
hostname 01
dhcp smart-relay
dhcp smart-relay helper-address 10.100.100.2
dhcp smart-relay option
dhcp smart-relay information
01#
Edited by BAHbKA
Вся проблема была в соблюдении http://zyxel.by/kb/1307 и конечно же в зикселе в зависимости от HOSTNAME генерируется несуществующий MAC :)
Building configuration...
vlan 2
name manager2
normal 1-8
fixed 9
forbidden ""
untagged ""
exit
vlan 30
normal ""
fixed 1-9
forbidden ""
untagged 1-8
ip address 10.99.30.200 255.255.255.0
ip address default-gateway 10.99.30.1
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
pvid 30
exit
name uplink
exit
hostname f0
dhcp smart-relay
dhcp smart-relay helper-address 10.100.100.2 10.99.30.1
f0#
