Доброе время суток!
Есть роутер Cisco 6500 с парой SUP720-3B, при установке WS-X6748-GE-TX получаю ругань вида:
*Jan  1 00:02:43.948: %DIAG-SP-3-MINOR: Module 1: Online Diagnostics detected a Minor Error. Please use 'show diagnostic result <target>' to see test results.
*Jan  1 00:02:43.948: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestL3VlanMet failed sh module 1
*Jan  1 00:02:44.961: %OIR-SP-6-SP_INSCARD: Card inserted in slot 1, interfaces are now online
диагностика модуля:
Router#show diagnostic result module 1
Current bootup diagnostic level: minimal
Module 1: CEF720 48 port 10/100/1000mb Ethernet  SerialNo : SAD0919028V
 Overall Diagnostic Result for Module 1 : MINOR ERROR
 Diagnostic level at card bootup: minimal
 Test results: (. = Pass, F = Fail, U = Untested)
   1) TestLoopback:
  Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
   2) TestTxPathMonitoring ------------> .
   3) TestSynchedFabChannel -----------> .
   4) TestL3VlanMet -------------------> F
   5) TestIngressSpan -----------------> .
   6) TestEgressSpan ------------------> .
   7) TestAsicMemory ------------------> U
   8) TestEobcStressPing --------------> U
   9) TestFirmwareDiagStatus ----------> .
  10) TestAsicSync --------------------> .
  11) TestUnusedPortLoopback:
        U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
  12) TestOBFL ------------------------> .
  13) TestErrorCounterMonitor ---------> .
  14) TestPortTxMonitoring:
  15) TestLtlFpoeMemoryConsistency ----> .
  16) TestRwEngineOverSubscription ----> U
немного информации о железке:
Router#sh module all
Mod Ports Card Type                              Model              Serial No.
 1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD0919028V
 5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1034ZGUD
Mod MAC addresses                       Hw    Fw           Sw           Status
 1  0013.8050.f788 to 0013.8050.f7b7   2.2   Unknown      Unknown      Other
 5  0017.9441.acc8 to 0017.9441.accb   5.2   8.4(2)       15.1(1)SY    Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
 1  Centralized Forwarding Card WS-F6700-CFC       SAD092202F7  2.0    Other
 5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1034Z3JD  2.3    Ok
 5  MSFC3 Daughterboard         WS-SUP720          SAL1035ZQM5  2.5    Ok
Mod  Online Diag Status
 1  Unknown
 5  Pass
Router#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(1)SY, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 09-Oct-12 15:13 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
Uptime for this control processor is 2 minutes
System returned to ROM by  power cycle at
v0P ^E8
v0ATP ^E8@ms8P`W0P ^E8E (SP by power on)
System image file is "disk0:s72033-adventerprisek9-mz.151-1.SY.bin"
Last reload reason: bus error at PC 0x42B8E4D8, address 0x0
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C6506-E (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID SAL1135Z4U5
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
50 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Router#sh power
system power redundancy mode = redundant
system power redundancy operationally = non-redundant
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power used =       988.68 Watts (23.54 Amps @ 42V)
system power available = 1782.48 Watts (42.44 Amps @ 42V)
                       Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  -      -      off
                       Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN       98.70  2.35  OK
                       Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
5    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
6    (Redundant Sup)       -     -      282.24  6.72  -     -
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   7266.00 Watts (173.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =               988.68 Watts (23.54 Amps @ 42V)
system auxiliary power used =            0 Watt
Это программная или аппаратная проблема?
Заранее всем спасибо за помощь!
а что статус unknown так и остается?
у нас было такое на одном модуле WS-X6708 при переезде с 6500 SUP720 на 7600 RSP 720,
TestL3VlanMet
This test verifies that the multicast functionality of the replication engine is working properly. The replication engine is configured to perform multicast replication of a diagnostic packet onto two different VLANs. After the diagnostic packet is sent out from the supervisor engine's inband port, the test verifies that two packets are received back in the inband port on the two VLANs configured in the replication engine.
решилось тем, что заменили глючный 6708 на такой же, но с более новой HW ревизией из соседнего 6500. "Глючный" модуль поставили в 6500 - полет нормальный, ошибок нет.
Прошу прощения, статус со временем меняется:
 6    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1132X789
 1  0013.8050.f788 to 0013.8050.f7b7   2.2   12.2(18r)S1  15.1(1)SY    Ok
 6  0016.c848.0004 to 0016.c848.0007   5.6   8.4(2)       15.1(1)SY    Ok
 1  Centralized Forwarding Card WS-F6700-CFC       SAD092202F7  2.0    Ok
 6  Policy Feature Card 3       WS-F6K-PFC3B       SAL1132X9DS  2.3    Ok
 6  MSFC3 Daughterboard         WS-SUP720          SAL1132XE6U  3.1    Ok
 1  Minor Error
 6  Pass
но сообщение о ошибке остается
  • 1 year later...
Это весьма похоже на баг CSCuz60556 в IOS (см. https://quickview.cloudapps.cisco.com/quickview/bug/CSCuz60556 ). Этот баг исправлен в IOS 15.3(3)S9, 15.5(3)S4.
Также Cisco рекомендует при этом отключить немного фильтров:
no mls rate-limit multicast ipv4 fib-miss
no mls rate-limit multicast ipv4 non-rpf
Edited by Tester111
