Люди подскажите в чём трабл. Есть радиус связанный с мускулом где хранятся учётки узверей с привязанными ip из 10.0.0.0/8 сетки. Наступил на след грабли, если выделяю ip с 3-мя знаками в последнем октете (в остальных актетах не пробовал) pppd вываливается с ошибкой Fatal signal 11. А юзеры с ip 10.0.0.1-10.0.0.99 авторизуются нормально и работают.
Причём radtest проверяет учётку на ура. Где копать?
=================messages========================
Feb 9 20:33:29 R1 pppoe-server[11980]: Session 35 created for client 00:40:45:08:1d:2f (10.67.15.35) on eth1 using Service-Name ''
Feb 9 20:33:29 R1 pppd[11980]: Plugin /etc/ppp/plugins/rp-pppoe.so loaded.
Feb 9 20:33:29 R1 pppd[11980]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
Feb 9 20:33:29 R1 pppd[11980]: Plugin radius.so loaded.
Feb 9 20:33:29 R1 pppd[11980]: RADIUS plugin initialized.
Feb 9 20:33:29 R1 pppd[11980]: pppd 2.4.2 started by root, uid 0
Feb 9 20:33:29 R1 pppd[11980]: Using interface ppp30
Feb 9 20:33:29 R1 pppd[11980]: Connect: ppp30 <--> eth1
Feb 9 20:33:29 R1 pppd[11980]: Couldn't increase MTU to 1500
Feb 9 20:33:29 R1 pppd[11980]: Couldn't increase MRU to 1500
Feb 9 20:33:29 R1 pppd[11980]: peer from calling number 00:40:45:08:1D:2F authorized
Feb 9 20:33:29 R1 /etc/hotplug/net.agent: assuming ppp30 is already up
Feb 9 20:33:29 R1 pppd[11980]: local IP address 172.16.0.25
Feb 9 20:33:29 R1 pppd[11980]: remote IP address 10.0.0.101
Feb 9 20:33:29 R1 kernel: device ppp30 entered promiscuous mode
Feb 9 20:33:29 R1 pppd[11991]: Fatal signal 11
Feb 9 20:33:29 R1 kernel: device ppp30 left promiscuous mode
Feb 9 20:33:29 R1 pppd[11991]: Exit.
Feb 9 20:33:29 R1 /etc/hotplug/net.agent: NET unregister event not supported
Feb 9 20:33:29 R1 pppoe-server[3979]: Session 35 closed for client 00:40:45:08:1d:2f (10.67.15.35) on eth1
Feb 9 20:33:29 R1 pppoe-server[3979]: Sent PADT
==============ppp.log============================
Fatal signal 11
