Есть девайс SNR-VG-3112 и астериск . Сделал транк - подключил к астериску (в интерфейсе SNR-VG-3112 сип тольок в двух местах в FXS и FXO) логически предположил что надо конфигурировать FXO в Основных настройках выбрал Безусловную переадресацию по SIP на номерное пространство которое живет у меня в астериске. Однако при звонке на PSTN номер на этот девайс не происходит иногда ничего вообще (длинные гудки -нет ответа) либо девайс поднимает трубку и дальше тишина. настроил SYSLOG
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 401, Unauthorized in 14-Oct 16:24:37.23 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:24:38.29 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 200 OK, User is successfully registred! in 14-Oct 16:24:38.31 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 100 Trying, Call is being processed! in 14-Oct 16:25:20.17 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 603 Declined, 6xx received for Call! in 14-Oct 16:25:20.20 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 603, Declined in 14-Oct 16:25:20.20 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 100 Trying, Call is being processed! in 14-Oct 16:25:32.93 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 603 Declined, 6xx received for Call! in 14-Oct 16:25:32.95 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 603, Declined in 14-Oct 16:25:32.95 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:25:38.34 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:26:38.80 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 401, Unauthorized in 14-Oct 16:27:23.23 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:27:24.31 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 200 OK, User is successfully registred! in 14-Oct 16:27:24.33 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 100 Trying, Call is being processed! in 14-Oct 16:27:56.81 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 603 Declined, 6xx received for Call! in 14-Oct 16:27:56.83 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 603, Declined in 14-Oct 16:27:56.83 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 100 Trying, Call is being processed! in 14-Oct 16:28:9.61 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 603 Declined, 6xx received for Call! in 14-Oct 16:28:9.63 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: 603, Declined in 14-Oct 16:28:9.63 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:28:24.35 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 101 Dialog Establishement, New call received! in 14-Oct 16:31:23.55 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1: ACK received! in 14-Oct 16:31:23.59 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:31:24.43 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: 200 OK, Bye Received! in 14-Oct 16:31:50.31 from 192.168.1.90
SNR-VP-3112: [00:1f:c1:1a:cd:3c] aid 1 RECV: OPTIONS,New request outside call received! in 14-Oct 16:32:24.46 from 192.168.1.90
Настройки делал согласно вот этому
http://shop.nag.ru/article/nastrojka-voip-shlyuzov-fxo-sovmestno-s-asterisk-elastix
http://shop.nag.ru/article/udlinenie-analogovyh-linij-s-pomoschyu-fxs--i-fxo-shlyuzov-voip
Подскажите если кто понимает где моя ошибка.. Пардон если ошибка туповата :)
смущает еще вот что : 401, Unauthorized
а еще покажи конфиг в скриншотах, и на vg-3112 по умолчанию FXO заворачивается в FXS, нужно эту опцию отключать.
