Здравствуйте! Случилось так что техподдержка биллинга голимая, а документация просто в хаотическом порядке представлена...
Решил обновить сервер биллинга (Centos 6.6) yum update и обновился пакет freeradius, после чего он уже не запускался... Сначала была ошибка об отсутствии Perl, сейчас об eap модуле.
radiusd -X
radiusd: FreeRADIUS Version 2.2.6, for host x86_64-redhat-linux-gnu, built on Sep 22 2015 at 15:27:25
Copyright (C) 1999-2013 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License.
For more information about these matters, see the file named COPYRIGHT.
Starting - reading configuration files ...
including configuration file /etc/raddb/radiusd.conf
including files in directory /etc/raddb/modules/
including configuration file /etc/raddb/modules/checkval
including configuration file /etc/raddb/modules/realm
including configuration file /etc/raddb/modules/soh
including configuration file /etc/raddb/modules/always
including configuration file /etc/raddb/modules/pap
including configuration file /etc/raddb/modules/sql_log
including configuration file /etc/raddb/modules/otp
including configuration file /etc/raddb/modules/detail
including configuration file /etc/raddb/modules/radrelay
including configuration file /etc/raddb/modules/cui
including configuration file /etc/raddb/modules/rediswho
including configuration file /etc/raddb/modules/inner-eap
including configuration file /etc/raddb/modules/preprocess
including configuration file /etc/raddb/modules/expr
including configuration file /etc/raddb/modules/pam
including configuration file /etc/raddb/modules/sqlcounter_expire_on_login
including configuration file /etc/raddb/modules/ippool
including configuration file /etc/raddb/modules/chap
including configuration file /etc/raddb/modules/ntlm_auth
including configuration file /etc/raddb/modules/acct_unique
including configuration file /etc/raddb/modules/exec
including configuration file /etc/raddb/modules/unix
including configuration file /etc/raddb/modules/dynamic_clients
including configuration file /etc/raddb/modules/linelog
including configuration file /etc/raddb/modules/smbpasswd
including configuration file /etc/raddb/modules/smsotp
including configuration file /etc/raddb/modules/mac2ip
including configuration file /etc/raddb/modules/policy
including configuration file /etc/raddb/modules/mac2vlan
including configuration file /etc/raddb/modules/expiration
including configuration file /etc/raddb/modules/files
including configuration file /etc/raddb/modules/attr_filter
including configuration file /etc/raddb/modules/digest
including configuration file /etc/raddb/modules/echo
including configuration file /etc/raddb/modules/dhcp_sqlippool
including configuration file /etc/raddb/modules/logintime
including configuration file /etc/raddb/modules/passwd
including configuration file /etc/raddb/modules/perl
including configuration file /etc/raddb/modules/radutmp
including configuration file /etc/raddb/modules/wimax
including configuration file /etc/raddb/modules/sradutmp
including configuration file /etc/raddb/modules/opendirectory
including configuration file /etc/raddb/modules/mschap
including configuration file /etc/raddb/modules/etc_group
including configuration file /etc/raddb/modules/detail.log
including configuration file /etc/raddb/modules/counter
including configuration file /etc/raddb/modules/attr_rewrite
including configuration file /etc/raddb/modules/replicate
including configuration file /etc/raddb/modules/detail.example.com
including configuration file /etc/raddb/modules/cache
including configuration file /etc/raddb/sql.conf
including configuration file /etc/raddb/mikbill.conf
including files in directory /etc/raddb/sites-enabled/
including configuration file /etc/raddb/sites-enabled/mikbill
including configuration file /etc/raddb/sites-enabled/default
including configuration file /etc/raddb/sites-enabled/inner-tunnel
including configuration file /etc/raddb/sites-enabled/control-socket
main {
        allow_core_dumps = no
including dictionary file /etc/raddb/dictionary
main {
        name = "radiusd"
        prefix = "/usr"
        localstatedir = "/var"
        sbindir = "/usr/sbin"
        logdir = "/var/log/radius"
        run_dir = "/var/run/radiusd"
        libdir = "/usr/lib/freeradius"
        radacctdir = "/var/log/radius/radacct"
        hostname_lookups = no
        max_request_time = 9
        cleanup_delay = 1
        max_requests = 65535
        pidfile = "/var/run/radiusd/radiusd.pid"
        checkrad = "/usr/sbin/checkrad"
        debug_level = 0
        proxy_requests = off
log {
        stripped_names = no
        auth = no
        auth_badpass = no
        auth_goodpass = no
security {
        max_attributes = 3000
        reject_delay = 0
        status_server = yes
radiusd: #### Loading Realms and Home Servers ####
radiusd: #### Loading Clients ####
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_expr
Module: Instantiating module "expr" from file /etc/raddb/modules/expr
radiusd: #### Loading Virtual Servers ####
server { # from file
modules {
Module: Creating Auth-Type = Perl
Module: Checking authenticate {...} for more modules to load
Module: Linked to module rlm_always
Module: Instantiating module "ok" from file /etc/raddb/modules/always
always ok {
        rcode = "ok"
        simulcount = 0
        mpp = no
Module: Linked to module rlm_perl
Module: Instantiating module "perl" from file /etc/raddb/modules/perl
perl {
        module = "/etc/raddb/example.pl"
        func_authorize = "authorize"
        func_authenticate = "authenticate"
        func_accounting = "accounting"
        func_preacct = "preacct"
        func_checksimul = "checksimul"
        func_detach = "detach"
        func_xlat = "xlat"
        func_pre_proxy = "pre_proxy"
        func_post_proxy = "post_proxy"
        func_post_auth = "post_auth"
        func_recv_coa = "recv_coa"
        func_send_coa = "send_coa"
Module: Checking authorize {...} for more modules to load
Module: Linked to module rlm_preprocess
Module: Instantiating module "preprocess" from file /etc/raddb/modules/preprocess
preprocess {
        huntgroups = "/etc/raddb/huntgroups"
        hints = "/etc/raddb/hints"
        with_ascend_hack = no
        ascend_channels_per_line = 23
        with_ntdomain_hack = no
        with_specialix_jetstream_hack = no
        with_cisco_vsa_hack = no
        with_alvarion_vsa_hack = no
reading pairlist file /etc/raddb/huntgroups
reading pairlist file /etc/raddb/hints
Module: Linked to module rlm_realm
Module: Instantiating module "suffix" from file /etc/raddb/modules/realm
realm suffix {
        format = "suffix"
        delimiter = "@"
        ignore_default = no
        ignore_null = no
Module: Linked to module rlm_mschap
Module: Instantiating module "mschap" from file /etc/raddb/modules/mschap
mschap {
        use_mppe = yes
        require_encryption = no
        require_strong = no
        allow_retry = yes
Module: Checking preacct {...} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating module "acct_unique" from file /etc/raddb/modules/acct_unique
acct_unique {
        key = "User-Name, Acct-Session-Id, NAS-IP-Address, NAS-Identifier, NAS-Port"
Module: Checking accounting {...} for more modules to load
Module: Checking session {...} for more modules to load
Module: Linked to module rlm_sql
Module: Instantiating module "sql" from file /etc/raddb/sql.conf
sql {
        driver = "rlm_sql_mysql"
        server = "localhost"
        port = "3306"
        login = "mikbill"
        password = "ПАРОЛЬ"
        radius_db = "mikbill"
        read_groups = yes
        sqltrace = no
        sqltracefile = "/var/log/radius/sqltrace.sql"
        readclients = yes
        deletestalesessions = yes
        num_sql_socks = 1
        lifetime = 0
        max_queries = 0
        sql_user_name = "%{User-Name}"
        default_user_profile = ""
        nas_query = "SELECT id, nasname, shortname, type, secret FROM radnas"
        authorize_check_query = "SELECT id, username, attribute, value, op              FROM radcheck           WHERE username = BINARY '%{SQL-User-Name}'              ORDER BY id"
        authorize_reply_query = "SELECT id, username, attribute, value, op              FROM radreply           WHERE username = BINARY '%{SQL-User-Name}'              ORDER BY id"
        authorize_group_check_query = "SELECT id, groupname, attribute,                 Value, op               FROM radgroupcheck              WHERE groupname = '%{Sql-Group}'                ORDER BY id"
        authorize_group_reply_query = "SELECT id, groupname, attribute,                 value, op               FROM radgroupreply              WHERE groupname = '%{Sql-Group}'                ORDER BY id"
        accounting_onoff_query = "              UPDATE radacct          SET                     acctstoptime    = '%S',                         acctsessiontime = unix_timestamp('%S') -        unix_timestamp(acctstarttime),                  acctterminatecause = '%{Acct-Terminate-Cause}',                         acctstopdelay   = %{%{Acct-Delay-Time}:-0}              WHERE acctstoptime IS NULL              AND nasipaddress        = '%{NAS-IP-Address}'           AND acctstarttime       <= '%S'"
        accounting_update_query = "             UPDATE radacct          SET                     framedipaddress = '%{Framed-IP-Address}',                       acctsessiontime         = '%{Acct-Session-Time}',                       acctinputoctets         = '%{%{Acct-Input-Gigawords}:-0}' << 32 |                                                               '%{%{Acct-Input-Octets}:-0}',                   acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 |                                                             '%{%{Acct-Output-Octets}:-0}'           WHERE acctsessionid = '%{Acct-Session-Id}'              AND username    = '%{SQL-User-Name}'            AND nasipaddress = '%{NAS-IP-Address}'"
        accounting_update_query_alt = "                 INSERT INTO radacct                     (acctsessionid, acctuniqueid,   username,                       realm,          nasipaddress,   nasportid,                      nasporttype,    acctstarttime,  acctsessiontime,                        acctauthentic, connectinfo_start, acctinputoctets,                      acctoutputoctets, calledstationid, callingstationid,                    servicetype,    framedprotocol, framedipaddress,                        acctstartdelay, xascendsessionsvrkey)           VALUES                  ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                     '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}',                     DATE_SUB('%S',                                  INTERVAL (%{%{Acct-Session-Time}:-0} +                                                          %{%{Acct-Delay-Time}:-0}) SECOND),                                      '%{Acct-Session-Time}',                         '%{Acct-Authentic}', '',                        '%{%{Acct-Input-Gigawords}:-0}' << 32 |                         '%{%{Acct-Input-Octets}:-0}',                   '%{%{Acct-Output-Gigawords}:-0}' << 32 |                        '%{%{Acct-Output-Octets}:-0}',                  '%{Called-Station-Id}', '%{Calling-Station-Id}',                        '%{Service-Type}', '%{Framed-Protocol}',                        '%{Framed-IP-Address}',                         '0', '%{X-Ascend-Session-Svr-Key}')"
        accounting_start_query = "              INSERT INTO radacct                     (acctsessionid, acctuniqueid,   username,                       realm,          nasipaddress,   nasportid,                      nasporttype,    acctstarttime, acctstoptime,                    acctsessiontime, acctauthentic, connectinfo_start,                      connectinfo_stop, acctinputoctets, acctoutputoctets,                    calledstationid, callingstationid, acctterminatecause,                  servicetype,    framedprotocol, framedipaddress,                        acctstartdelay, acctstopdelay, xascendsessionsvrkey)            VALUES                  ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                     '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}', '%S', NULL,                         '0', '%{Acct-Authentic}', '%{Connect-Info}',                    '', '0', '0',                   '%{Called-Station-Id}', '%{Calling-Station-Id}', 'Online',                      '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}',                        '%{%{Acct-Delay-Time}:-0}', '0', '%{X-Ascend-Session-Svr-Key}')"
        accounting_start_query_alt = "          UPDATE radacct SET                      acctstarttime   = '%S',                         acctterminatecause = 'Online',                  acctstartdelay = '%{%{Acct-Delay-Time}:-0}',                    connectinfo_start = '%{Connect-Info}'           WHERE acctsessionid = '%{Acct-Session-Id}'              AND username            = '%{SQL-User-Name}'            AND nasipaddress        = '%{NAS-IP-Address}'"
        accounting_stop_query = "               UPDATE radacct SET                      acctstoptime    = '%S',                         acctsessiontime = '%{Acct-Session-Time}',                       acctinputoctets = '%{%{Acct-Input-Gigawords}:-0}' << 32 |                                                               '%{%{Acct-Input-Octets}:-0}',                   acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 |                                                             '%{%{Acct-Output-Octets}:-0}',                  acctterminatecause = '%{Acct-Terminate-Cause}',                         acctstopdelay   = '%{%{Acct-Delay-Time}:-0}',                   connectinfo_stop = '%{Connect-Info}'            WHERE acctsessionid = '%{Acct-Session-Id}'              AND username            = '%{SQL-User-Name}'            AND nasipaddress        = '%{NAS-IP-Address}'"
        accounting_stop_query_alt = "           INSERT INTO radacct                     (acctsessionid, acctuniqueid, username,                         realm, nasipaddress, nasportid,                         nasporttype, acctstarttime, acctstoptime,                       acctsessiontime, acctauthentic, connectinfo_start,                      connectinfo_stop, acctinputoctets, acctoutputoctets,                    calledstationid, callingstationid, acctterminatecause,                  servicetype, framedprotocol, framedipaddress,                   acctstartdelay, acctstopdelay)          VALUES                  ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                     '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}',                     DATE_SUB('%S',                          INTERVAL (%{%{Acct-Session-Time}:-0} +                          %{%{Acct-Delay-Time}:-0}) SECOND),                      '%S', '%{Acct-Session-Time}', '%{Acct-Authentic}', '',                  '%{Connect-Info}',                      '%{%{Acct-Input-Gigawords}:-0}' << 32 |                         '%{%{Acct-Input-Octets}:-0}',                   '%{%{Acct-Output-Gigawords}:-0}' << 32 |                        '%{%{Acct-Output-Octets}:-0}',                  '%{Called-Station-Id}', '%{Calling-Station-Id}',                        '%{Acct-Terminate-Cause}',                      '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}',                        '0', '%{%{Acct-Delay-Time}:-0}')"
        group_membership_query = "SELECT groupname              FROM radusergroup               WHERE username = BINARY '%{SQL-User-Name}'              ORDER BY priority"
        connect_failure_retry_delay = 60
        simul_count_query = "SELECT COUNT(*)                                                    FROM radacct                                                    WHERE username = '%{SQL-User-Name}'                                                     AND acctterminatecause = 'Online'"
        simul_verify_query = "SELECT radacctid, acctsessionid, username,                                                        nasipaddress, nasportid, framedipaddress,                                                       callingstationid, framedprotocol                                                        FROM radacct                                                    WHERE username = '%{SQL-User-Name}'                                                     AND acctterminatecause = 'Online'"
        postauth_query = "INSERT INTO radpostauth (username, pass,                                      packettype,replymessage, nasipaddress, nasportid, callingstationid, authdate) VALUES ( '%{User-Name}',                                  '%{%{User-Password}:-%{Chap-Password}}',                                        '%{reply:Packet-Type}','%{reply:Reply-Message}', '%{NAS-IP-Address}',                                           '%{NAS-Port}', '%{Calling-Station-Id}', '%S')"
        safe-characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /"
rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
rlm_sql (sql): Attempting to connect to mikbill@localhost:3306/mikbill
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
rlm_sql_mysql: Starting connect to MySQL server for #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): Processing generate_sql_clients
rlm_sql (sql) in generate_sql_clients: query is SELECT id, nasname, shortname, type, secret FROM radnas
rlm_sql (sql): Reserving sql socket id: 0
rlm_sql (sql): Read entry nasname=localhost,shortname=localhost,secret=secret
rlm_sql (sql): Adding client 127.0.0.1 (localhost, server=<none>) to clients list
rlm_sql (sql): Read entry nasname=10.1.0.1,shortname=NAS-1,secret=secret
rlm_sql (sql): Adding client 10.1.0.1 (NAS-1, server=<none>) to clients list
rlm_sql (sql): Released sql socket id: 0
Module: Checking post-proxy {...} for more modules to load
} # modules
} # server
server inner-tunnel { # from file /etc/raddb/sites-enabled/inner-tunnel
modules {
Module: Creating Post-Auth-Type = REJECT
Module: Linked to module rlm_pap
Module: Instantiating module "pap" from file /etc/raddb/modules/pap
pap {
        encryption_scheme = "auto"
        auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating module "chap" from file /etc/raddb/modules/chap
Module: Linked to module rlm_unix
Module: Instantiating module "unix" from file /etc/raddb/modules/unix
unix {
        radwtmp = "/var/log/radius/radwtmp"
/etc/raddb/sites-enabled/inner-tunnel[237]: Failed to find "eap" in the "modules" section.
/etc/raddb/sites-enabled/inner-tunnel[190]: Errors parsing authenticate section.
В интернете нашёл только про реген ключей в cert, я их сгенерировал, но толку не дало...
Может кто сталкивался с таким, подскажите пожалуйста как решить такую проблему...
Переустановка системы и биллинга, по мне, очень плохой вариант...
Скорее всего при обновлении пакета freeradius были добавлены ненужные файлы конфигурации в /etc/raddb.
Посмотрите - в архиве с установщиком mikbill есть каталог с конфигурацией freeradius. Я бы попробовал использовать его вместо существующей конфигурации (сохранив то, что есть сейчас).
Или можете посмотреть по дате - какие файлы были добавлены и переместить их куда-нибудь из /etc/raddb.
У вас много модулей которые вообще не нужны в данном случае. Вот достаточный минимум:
acct_unique
always
chap
detail
detail.log
expiration
expr
linelog
logintime
mschap
pap
perl
preprocess
radutmp
realm
sradutmp
unix
Edited by avb1987
ibdir = /usr/lib/freeradius
libdir = /usr/lib64/freeradius
proxy_requests = no
некоторые несовпадения в конфиге старого и нового.
Ошибку выдавало из-за отсутствия
$INCLUDE eap.conf
в modules секции radiusd.conf
Но после успешного запуска radius клиент залогиниться по-прежнему не может, пока не могу понять из-за чего...
Сейчас лог выглядит так:
radiusd -Xradiusd: FreeRADIUS Version 2.2.6, for host x86_64-redhat-linux-gnu, built on Sep 22 2015 at 15:27:25Copyright © 1999-2013 The FreeRADIUS server project and contributors.There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR APARTICULAR PURPOSE.You may redistribute copies of FreeRADIUS under the terms of theGNU General Public License.For more information about these matters, see the file named COPYRIGHT.Starting - reading configuration files ...including configuration file /etc/raddb/radiusd.confincluding files in directory /etc/raddb/modules/including configuration file /etc/raddb/modules/realmincluding configuration file /etc/raddb/modules/alwaysincluding configuration file /etc/raddb/modules/papincluding configuration file /etc/raddb/modules/detailincluding configuration file /etc/raddb/modules/preprocessincluding configuration file /etc/raddb/modules/exprincluding configuration file /etc/raddb/modules/chapincluding configuration file /etc/raddb/modules/acct_uniqueincluding configuration file /etc/raddb/modules/execincluding configuration file /etc/raddb/modules/unixincluding configuration file /etc/raddb/modules/expirationincluding configuration file /etc/raddb/modules/filesincluding configuration file /etc/raddb/modules/attr_filterincluding configuration file /etc/raddb/modules/digestincluding configuration file /etc/raddb/modules/logintimeincluding configuration file /etc/raddb/modules/perlincluding configuration file /etc/raddb/modules/radutmpincluding configuration file /etc/raddb/modules/sradutmpincluding configuration file /etc/raddb/modules/mschapincluding configuration file /etc/raddb/modules/detail.logincluding configuration file /etc/raddb/eap.confincluding configuration file /etc/raddb/sql.confincluding configuration file /etc/raddb/sql/mysql/dialup.confincluding files in directory /etc/raddb/sites-enabled/including configuration file /etc/raddb/sites-enabled/mikbillincluding configuration file /etc/raddb/sites-enabled/defaultincluding configuration file /etc/raddb/sites-enabled/inner-tunnelincluding configuration file /etc/raddb/sites-enabled/control-socketmain {               allow_core_dumps = no}including dictionary file /etc/raddb/dictionarymain {               name = "radiusd"               prefix = "/usr"               localstatedir = "/var"               sbindir = "/usr/sbin"               logdir = "/var/log/radius"               run_dir = "/var/run/radiusd"               libdir = "/usr/lib64/freeradius"               radacctdir = "/var/log/radius/radacct"               hostname_lookups = no               max_request_time = 30               cleanup_delay = 1               max_requests = 65535               pidfile = "/var/run/radiusd/radiusd.pid"               checkrad = "/usr/sbin/checkrad"               debug_level = 0               proxy_requests = offlog {               stripped_names = no               auth = yes               auth_badpass = yes               auth_goodpass = yes}security {               max_attributes = 500               reject_delay = 0               status_server = yes}}radiusd: #### Loading Realms and Home Servers ####radiusd: #### Loading Clients ####radiusd: #### Instantiating modules ####instantiate {Module: Linked to module rlm_exprModule: Instantiating module "expr" from file /etc/raddb/modules/expr}radiusd: #### Loading Virtual Servers ####server { # from filemodules { Module: Creating Auth-Type = PerlModule: Checking authenticate {...} for more modules to loadModule: Linked to module rlm_alwaysModule: Instantiating module "ok" from file /etc/raddb/modules/always always ok {               rcode = "ok"               simulcount = 0               mpp = no }Module: Linked to module rlm_perlModule: Instantiating module "perl" from file /etc/raddb/modules/perl perl {               module = "/etc/raddb/mikbill.pl"               func_authorize = "authorize"               func_authenticate = "authenticate"               func_accounting = "accounting"               func_preacct = "preacct"               func_checksimul = "checksimul"               func_detach = "detach"               func_xlat = "xlat"               func_pre_proxy = "pre_proxy"               func_post_proxy = "post_proxy"               func_post_auth = "post_auth"               func_recv_coa = "recv_coa"               func_send_coa = "send_coa" }Module: Checking authorize {...} for more modules to loadModule: Linked to module rlm_preprocessModule: Instantiating module "preprocess" from file /etc/raddb/modules/preprocess preprocess {               huntgroups = "/etc/raddb/huntgroups"               with_ascend_hack = no               ascend_channels_per_line = 23               with_ntdomain_hack = no               with_specialix_jetstream_hack = no               with_cisco_vsa_hack = no               with_alvarion_vsa_hack = no }reading pairlist file /etc/raddb/huntgroupsModule: Linked to module rlm_realmModule: Instantiating module "suffix" from file /etc/raddb/modules/realm realm suffix {               format = "suffix"               delimiter = "@"               ignore_default = no               ignore_null = no }Module: Linked to module rlm_mschapModule: Instantiating module "mschap" from file /etc/raddb/modules/mschap mschap {               use_mppe = yes               require_encryption = no               require_strong = no               with_ntdomain_hack = no               allow_retry = yes }Module: Checking preacct {...} for more modules to loadModule: Linked to module rlm_acct_uniqueModule: Instantiating module "acct_unique" from file /etc/raddb/modules/acct_unique acct_unique {               key = "User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port" }Module: Checking accounting {...} for more modules to loadModule: Checking session {...} for more modules to loadModule: Linked to module rlm_sqlModule: Instantiating module "sql" from file /etc/raddb/sql.conf sql {               driver = "rlm_sql_mysql"               server = "localhost"               port = "3306"               login = "mikbill"               password = "пароль"               radius_db = "mikbill"               read_groups = yes               sqltrace = no               sqltracefile = "/var/log/radius/sqltrace.sql"               readclients = no               deletestalesessions = yes               num_sql_socks = 16               lifetime = 0               max_queries = 0               sql_user_name = "%{User-Name}"               default_user_profile = ""               nas_query = "SELECT id, nasname, shortname, type, secret, server FROM nas"               authorize_check_query = "SELECT id, username, attribute, value, op                 FROM radcheck                   WHERE username = '%{SQL-User-Name}'             ORDER BY id"               authorize_reply_query = "SELECT id, username, attribute, value, op                 FROM radreply                   WHERE username = '%{SQL-User-Name}'             ORDER BY id"               authorize_group_check_query = "SELECT id, groupname, attribute,            Value, op               FROM radgroupcheck              WHERE groupname = '%{Sql-Group}'                ORDER BY id"               authorize_group_reply_query = "SELECT id, groupname, attribute,            value, op               FROM radgroupreply              WHERE groupname = '%{Sql-Group}'                ORDER BY id"               accounting_onoff_query = "                UPDATE radacct                   SET                    acctstoptime     =  '%S',                       acctsessiontime       =  unix_timestamp('%S') -        unix_timestamp(acctstarttime),                    acctterminatecause =  '%{Acct-Terminate-Cause}',                        acctstopdelay   =  %{%{Acct-Delay-Time}:-0}              WHERE acctstoptime IS NULL              AND nasipaddress       =  '%{NAS-IP-Address}'                   AND acctstarttime     <= '%S'"               accounting_update_query = "                UPDATE radacct                  SET                    framedipaddress = '%{Framed-IP-Address}',                       acctsessiontime        = '%{%{Acct-Session-Time}:-0}',                          acctinputoctets        = '%{%{Acct-Input-Gigawords}:-0}'  << 32 |        '%{%{Acct-Input-Octets}:-0}',                     acctoutputoctets      = '%{%{Acct-Output-Gigawords}:-0}' << 32 |        '%{%{Acct-Output-Octets}:-0}'              WHERE acctsessionid = '%{Acct-Session-Id}'              AND username         = '%{SQL-User-Name}'               AND nasipaddress     = '%{NAS-IP-Address}'"               accounting_update_query_alt = "            INSERT INTO radacct                   (acctsessionid,        acctuniqueid,     username,                       realm,                        nasipaddress,     nasportid,                      nasporttype,    acctstarttime,         acctsessiontime,                         acctauthentic,        connectinfo_start, acctinputoctets,                       acctoutputoctets, calledstationid,   callingstationid,                          servicetype,    framedprotocol,       framedipaddress,                          acctstartdelay,   xascendsessionsvrkey)                  VALUES                        ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                      '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}',                     DATE_SUB('%S',                                           INTERVAL (%{%{Acct-Session-Time}:-0} +        %{%{Acct-Delay-Time}:-0}) SECOND),                                        '%{%{Acct-Session-Time}:-0}',                          '%{Acct-Authentic}', '',                        '%{%{Acct-Input-Gigawords}:-0}' << 32 |                         '%{%{Acct-Input-Octets}:-0}',                   '%{%{Acct-Output-Gigawords}:-0}' << 32 |                        '%{%{Acct-Output-Octets}:-0}',                          '%{Called-Station-Id}', '%{Calling-Station-Id}',                        '%{Service-Type}', '%{Framed-Protocol}',                        '%{Framed-IP-Address}',                         '0', '%{X-Ascend-Session-Svr-Key}')"               accounting_start_query = "                 INSERT INTO radacct                   (acctsessionid,        acctuniqueid,    username,                        realm,                        nasipaddress,    nasportid,                       nasporttype,    acctstarttime,        acctstoptime,                     acctsessiontime,  acctauthentic,      connectinfo_start,                        connectinfo_stop, acctinputoctets,  acctoutputoctets,                   calledstationid,  callingstationid, acctterminatecause,                         servicetype,    framedprotocol,   framedipaddress,                      acctstartdelay,   acctstopdelay,      xascendsessionsvrkey)              VALUES                        ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                      '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}', '%S', NULL,                         '0', '%{Acct-Authentic}', '%{Connect-Info}',                    '', '0', '0',                   '%{Called-Station-Id}', '%{Calling-Station-Id}', '',                    '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}',                        '%{%{Acct-Delay-Time}:-0}', '0', '%{X-Ascend-Session-Svr-Key}')"               accounting_start_query_alt = "             UPDATE radacct SET                     acctstarttime  = '%S',                          acctstartdelay        = '%{%{Acct-Delay-Time}:-0}',                     connectinfo_start = '%{Connect-Info}'            WHERE acctsessionid  = '%{Acct-Session-Id}'             AND username          = '%{SQL-User-Name}'              AND nasipaddress      = '%{NAS-IP-Address}'"               accounting_stop_query = "                  UPDATE radacct SET                     acctstoptime     = '%S',                        acctsessiontime       = '%{%{Acct-Session-Time}:-0}',                   acctinputoctets       = '%{%{Acct-Input-Gigawords}:-0}' << 32 |        '%{%{Acct-Input-Octets}:-0}',                          acctoutputoctets   = '%{%{Acct-Output-Gigawords}:-0}' << 32 |                                                            '%{%{Acct-Output-Octets}:-0}',                         acctterminatecause = '%{Acct-Terminate-Cause}',                         acctstopdelay   = '%{%{Acct-Delay-Time}:-0}',                   connectinfo_stop   = '%{Connect-Info}'                   WHERE acctsessionid   = '%{Acct-Session-Id}'            AND username           = '%{SQL-User-Name}'             AND nasipaddress       = '%{NAS-IP-Address}'"               accounting_stop_query_alt = "              INSERT INTO radacct                   (acctsessionid, acctuniqueid, username,                          realm, nasipaddress, nasportid,                         nasporttype, acctstarttime, acctstoptime,                       acctsessiontime, acctauthentic, connectinfo_start,                      connectinfo_stop, acctinputoctets, acctoutputoctets,                    calledstationid, callingstationid, acctterminatecause,                          servicetype, framedprotocol, framedipaddress,                   acctstartdelay, acctstopdelay)                   VALUES                        ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}',                      '%{SQL-User-Name}',                     '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}',                         '%{NAS-Port-Type}',                     DATE_SUB('%S',                                  INTERVAL (%{%{Acct-Session-Time}:-0} +                                  %{%{Acct-Delay-Time}:-0}) SECOND),                      '%S', '%{%{Acct-Session-Time}:-0}', '%{Acct-Authentic}', '',                    '%{Connect-Info}',                      '%{%{Acct-Input-Gigawords}:-0}' << 32 |                         '%{%{Acct-Input-Octets}:-0}',                   '%{%{Acct-Output-Gigawords}:-0}' << 32 |                        '%{%{Acct-Output-Octets}:-0}',                          '%{Called-Station-Id}', '%{Calling-Station-Id}',                        '%{Acct-Terminate-Cause}',                      '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}',                        '0', '%{%{Acct-Delay-Time}:-0}')"               group_membership_query = "SELECT groupname                 FROM radusergroup               WHERE username = '%{SQL-User-Name}'             ORDER BY priority"               connect_failure_retry_delay = 60               simul_count_query = ""               simul_verify_query = "SELECT radacctid, acctsessionid, username,        nasipaddress, nasportid, framedipaddress,                                                               callingstationid, framedprotocol        FROM radacct                                                            WHERE username = '%{SQL-User-Name}'                                                             AND acctstoptime IS NULL"               postauth_query = "INSERT INTO radpostauth                                                  (username, pass, reply, authdate)                                               VALUES (                                                '%{User-Name}',                                                 '%{%{User-Password}:-%{Chap-Password}}',                                                '%{reply:Packet-Type}', '%S')"               safe-characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /" }rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linkedrlm_sql (sql): Attempting to connect to mikbill@localhost:3306/mikbillrlm_sql (sql): starting 0rlm_sql (sql): Attempting to connect rlm_sql_mysql #0rlm_sql_mysql: Starting connect to MySQL server for #0rlm_sql (sql): Connected new DB handle, #0rlm_sql (sql): starting 1rlm_sql (sql): Attempting to connect rlm_sql_mysql #1rlm_sql_mysql: Starting connect to MySQL server for #1rlm_sql (sql): Connected new DB handle, #1rlm_sql (sql): starting 2rlm_sql (sql): Attempting to connect rlm_sql_mysql #2rlm_sql_mysql: Starting connect to MySQL server for #2rlm_sql (sql): Connected new DB handle, #2rlm_sql (sql): starting 3rlm_sql (sql): Attempting to connect rlm_sql_mysql #3rlm_sql_mysql: Starting connect to MySQL server for #3rlm_sql (sql): Connected new DB handle, #3rlm_sql (sql): starting 4rlm_sql (sql): Attempting to connect rlm_sql_mysql #4rlm_sql_mysql: Starting connect to MySQL server for #4rlm_sql (sql): Connected new DB handle, #4rlm_sql (sql): starting 5rlm_sql (sql): Attempting to connect rlm_sql_mysql #5rlm_sql_mysql: Starting connect to MySQL server for #5rlm_sql (sql): Connected new DB handle, #5rlm_sql (sql): starting 6rlm_sql (sql): Attempting to connect rlm_sql_mysql #6rlm_sql_mysql: Starting connect to MySQL server for #6rlm_sql (sql): Connected new DB handle, #6rlm_sql (sql): starting 7rlm_sql (sql): Attempting to connect rlm_sql_mysql #7rlm_sql_mysql: Starting connect to MySQL server for #7rlm_sql (sql): Connected new DB handle, #7rlm_sql (sql): starting 8rlm_sql (sql): Attempting to connect rlm_sql_mysql #8rlm_sql_mysql: Starting connect to MySQL server for #8rlm_sql (sql): Connected new DB handle, #8rlm_sql (sql): starting 9rlm_sql (sql): Attempting to connect rlm_sql_mysql #9rlm_sql_mysql: Starting connect to MySQL server for #9rlm_sql (sql): Connected new DB handle, #9rlm_sql (sql): starting 10rlm_sql (sql): Attempting to connect rlm_sql_mysql #10rlm_sql_mysql: Starting connect to MySQL server for #10rlm_sql (sql): Connected new DB handle, #10rlm_sql (sql): starting 11rlm_sql (sql): Attempting to connect rlm_sql_mysql #11rlm_sql_mysql: Starting connect to MySQL server for #11rlm_sql (sql): Connected new DB handle, #11rlm_sql (sql): starting 12rlm_sql (sql): Attempting to connect rlm_sql_mysql #12rlm_sql_mysql: Starting connect to MySQL server for #12rlm_sql (sql): Connected new DB handle, #12rlm_sql (sql): starting 13rlm_sql (sql): Attempting to connect rlm_sql_mysql #13rlm_sql_mysql: Starting connect to MySQL server for #13rlm_sql (sql): Connected new DB handle, #13rlm_sql (sql): starting 14rlm_sql (sql): Attempting to connect rlm_sql_mysql #14rlm_sql_mysql: Starting connect to MySQL server for #14rlm_sql (sql): Connected new DB handle, #14rlm_sql (sql): starting 15rlm_sql (sql): Attempting to connect rlm_sql_mysql #15rlm_sql_mysql: Starting connect to MySQL server for #15rlm_sql (sql): Connected new DB handle, #15Module: Checking post-proxy {...} for more modules to load} # modules} # serverserver inner-tunnel { # from file /etc/raddb/sites-enabled/inner-tunnelmodules { Module: Creating Post-Auth-Type = REJECTModule: Checking authenticate {...} for more modules to loadModule: Linked to module rlm_papModule: Instantiating module "pap" from file /etc/raddb/modules/pap pap {               encryption_scheme = "auto"               auto_header = no }Module: Linked to module rlm_chapModule: Instantiating module "chap" from file /etc/raddb/modules/chapModule: Linked to module rlm_unixModule: Instantiating module "unix" from file /etc/raddb/modules/unix unix {               radwtmp = "/var/log/radius/radwtmp" }Module: Linked to module rlm_eapModule: Instantiating module "eap" from file /etc/raddb/eap.conf eap {               default_eap_type = "md5"               timer_expire = 60               ignore_unknown_eap_types = no               cisco_accounting_username_bug = no               max_sessions = 65535 }Module: Linked to sub-module rlm_eap_md5Module: Instantiating eap-md5Module: Linked to sub-module rlm_eap_leapModule: Instantiating eap-leapModule: Linked to sub-module rlm_eap_gtcModule: Instantiating eap-gtc  gtc {               challenge = "Password: "               auth_type = "PAP"  }Module: Linked to sub-module rlm_eap_tlsModule: Instantiating eap-tls  tls {               rsa_key_exchange = no               dh_key_exchange = yes               rsa_key_length = 512               dh_key_length = 512               verify_depth = 0               CA_path = "/etc/raddb/certs"               pem_file_type = yes               private_key_file = "/etc/raddb/certs/server.pem"               certificate_file = "/etc/raddb/certs/server.pem"               CA_file = "/etc/raddb/certs/ca.pem"               private_key_password = "whatever"               dh_file = "/etc/raddb/certs/dh"               fragment_size = 1024               include_length = yes               check_crl = no               cipher_list = "DEFAULT"               ecdh_curve = "prime256v1"       cache {               enable = no               lifetime = 24               max_entries = 255       }       verify {       }       ocsp {               enable = no               override_cert_url = yes               url = "http://127.0.0.1/ocsp/"               use_nonce = yes               timeout = 0               softfail = no       }  }Module: Linked to sub-module rlm_eap_ttlsModule: Instantiating eap-ttls  ttls {               default_eap_type = "md5"               copy_request_to_tunnel = no               use_tunneled_reply = no               virtual_server = "inner-tunnel"               include_length = yes  }Module: Linked to sub-module rlm_eap_peapModule: Instantiating eap-peap  peap {               default_eap_type = "mschapv2"               copy_request_to_tunnel = no               use_tunneled_reply = no               proxy_tunneled_request_as_eap = yes               virtual_server = "inner-tunnel"               soh = no  }Module: Linked to sub-module rlm_eap_mschapv2Module: Instantiating eap-mschapv2  mschapv2 {               with_ntdomain_hack = no               send_error = no  }Module: Checking authorize {...} for more modules to loadModule: Linked to module rlm_filesModule: Instantiating module "files" from file /etc/raddb/modules/files files {               usersfile = "/etc/raddb/users"               acctusersfile = "/etc/raddb/acct_users"               preproxy_usersfile = "/etc/raddb/preproxy_users"               compat = "no" }reading pairlist file /etc/raddb/usersreading pairlist file /etc/raddb/acct_usersreading pairlist file /etc/raddb/preproxy_usersModule: Linked to module rlm_expirationModule: Instantiating module "expiration" from file /etc/raddb/modules/expiration expiration {               reply-message = "Password Has Expired  " }Module: Linked to module rlm_logintimeModule: Instantiating module "logintime" from file /etc/raddb/modules/logintime logintime {               reply-message = "You are calling outside your allowed timespan  "               minimum-timeout = 60 }Module: Checking session {...} for more modules to loadModule: Linked to module rlm_radutmpModule: Instantiating module "radutmp" from file /etc/raddb/modules/radutmp radutmp {               filename = "/var/log/radius/radutmp"               username = "%{User-Name}"               case_sensitive = yes               check_with_nas = yes               perm = 384               callerid = yes }Module: Checking post-proxy {...} for more modules to loadModule: Checking post-auth {...} for more modules to loadModule: Linked to module rlm_attr_filterModule: Instantiating module "attr_filter.access_reject" from file /etc/raddb/modules/attr_filter attr_filter attr_filter.access_reject {               attrsfile = "/etc/raddb/attrs.access_reject"               key = "%{User-Name}"               relaxed = no }reading pairlist file /etc/raddb/attrs.access_reject} # modules} # serverradiusd: #### Opening IP addresses and Ports ####listen {               type = "auth"               ipaddr = *               port = 0}listen {               type = "acct"               ipaddr = *               port = 0}listen {               type = "control"listen {               socket = "/var/run/radiusd/radiusd.sock"}}listen {               type = "auth"               ipaddr = 127.0.0.1               port = 18120}Listening on authentication address * port 1812Listening on accounting address * port 1813Listening on command file /var/run/radiusd/radiusd.sockListening on authentication address 127.0.0.1 port 18120 as server inner-tunnelReady to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 48252Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 52039Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 52039Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 52039Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 33283Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 45537Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 33283Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 45537Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 33283Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 45537Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 50025Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 50025Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 50025Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 34121Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 34121Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 34121Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 56104Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 56104Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 56104Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 42813Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 42813Ready to process requests.Ignoring request to accounting address * port 1813 from unknown client 10.1.0.1 port 42813Ready to process requests.^C
Под клиентом здесь подразумевается сервер доступа (т.е. NAS). Посмотрите - возможно у него поменялся IP-адрес? Совпадает ли он с тем, что указан в справочнике NAS в Mikbill?
ИМХО, проблема будет решена гораздо быстрее если вы обратитесь в платную техподдержку.
Edited by avb1987
В "сервера NAS" вижу записи с верными адресами, в базе тоже эти записи имеются.
Надо ли что-то делать с clients.conf ? Если информация идёт с БД то зачем что-то записывать в файл?
Правил строки
client 10.1.0.1 {
secret = secret
shortname = 10.1.0.1
Но ожидаемого результата не дало :(
Edited by korsakik
Вы заменили каталог raddb каталогом с конфигурацией из установщика Mikbill?
Если да то откуда у вас clients.conf? его быть не должно.
Никакого EAP там тоже быть не должно.
Если вы перемещали лишние файлы, то попробуйте еще оттуда переместить все из sites-enabled кроме dhcp и mikbill.
А также:
/etc/raddb/eap.conf
Если вы добавили вручную ссылки на эти файлы из radiusd.conf то закомментируйте.
Модули digest и files тоже стоит отключить.
Небольшое пояснение:
Модуль EAP может понадобиться если вы используете авторизацию 802.1x. В таком случае нужно брать файлы из /freeradius/EAP - соответствующие конфигурации сайтов, модуля EAP и т.д.
Во всех остальных случаях он обычно не используется и конфигурацию (в том числе сайтов) надо брать из /Centos6x/raddb (или из другого каталога соответствующего вашей ОС).
Если вы не используете Mikbill DHCP, то dhcp в sites-enabled так же быть не должно.
Edited by avb1987
Как раз при использовании файлов из дистрибутива я и получаю ошибку. Получал точнее. Я действовал немного по-другому, удалил freeradius полностью, с папкой. Потом установил заново пакеты, начинал править конфигурацию, так как на старой мне выдавало ошибки, и он запустился, но пока unknown host.
Хорошо, давайте попробуем сначала.
Пакет freeradius у вас уже установлен. Удалите каталог raddb (сделав бекап) и замените его каталогом DISTR/Centos6x/raddb.
Скопируйте файл raddb/serialize.pm в /usr/lib/perl5/vendor_perl/5.X.X/
В файле raddb/sql.conf укажите настройки для подключения к БД.
После этого запустите radiusd -f -X и скопируйте сюда лог.
Даже и не знаю как Вас отблагодарить, всё заработало, спасибо Вам огромное!
Ну, хорошо если так.
Очень жаль, что та информация, которая представлена разработчиками биллинга либо неактуальна, либо неполная.
К примеру нужно было банально PCQ шейпера настроить для тарифов день\ночь, в документации сказано одно, тех отдел мне открытым текстом говорит что статья неправильная, по ней не делайте, делайте по другой статье, и кидают ссылку на отельную доку, которая ни с чем не связана, только в догадках...
Уже не раз говорил об этом, даже не я один, но никто не прислушивается, к сожалению.
