castor Опубликовано 5 июля, 2020 · Жалоба 24 минуты назад, Bachaa сказал: это что такое ? FiberFox Mini 4s Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Bachaa Опубликовано 30 июля, 2020 · Жалоба Feature:1. Compact and convenient: only 1.7kg with battery.2. 6 Motor Accurate Fiber Alignment Technology, ensures high quality and stable welding index.3. Suitable for multimode fiber (MMF/G.651), single-mode fiber (SMF/G.652), dispersion-shifted fiber (DSF/G.653), non-zero dispersion-shifted fiber (NZ-DSF/G.655), Bend-insensitive fiber (BIF/G.657) and Erbium-doped fiber (EDF) etc.4. Multi-in-one clamping device is suitable for splicing bare fibers, pigtails, drop cables, patchcord and other types of fibers.5. Automatically detect fiber endfaces, calibrate welding locations, estimate splice loss, and temperature and pressure compensation modes.6. With automatic welding function.7. 9 seconds fast welding, 25 seconds heating and adjustable heating time8. Built-in counter design prompts the user to timely replace the electrode9. Automatic discharge optimization10. With automatic heating function11. Dual V-groove design for better welding specifications12. Easy switching between X/Y single screen and X+Y dual screen, clear fiber core display13. Unique battery and host separation design, convenient battery maintenance and replacement, battery with intuitive power indicator14. With DC output function for other external devices15. Built-in lighting for dark environment and night operation16. Windproof, dustproof, waterproof, shockproof design adapts to outdoor harsh environments17. Display can be flipped back and forth to facilitate multi-angle viewing18. Simple and generous user menu, simple operation Specification: Model GS-60 Fiber Type SMF (G.652), MMF (G.651), DSF (G.653), NZ-DSF (G.655), BIF (G.657), EDF Protection Sleeve 40mm - 60mm Splicing Principle Arc Alignment 6 motors core alignment Splice Control Auto and manual splicing Arc Optimization Yes Display Mode X, Y, X+Y User Interface Graphical interface, multiple language support Splice Result Auto splice result (Loss)estimated calculation and display Data 5000 splice records (CSV format), 100 screenshots Data Port USB, driver-free Fiber Diameter Cladding: 80~150μm, coating: 100~1000μm Cleave Length ≤16mm Splice Loss MMF ≦ 0.01dB (Typical); SMF/BIF ≦ 0.02dB (Typical); DSF/NZDSF/EDF ≦ 0.04dB (Typical) Return Loss >60dB Splice Time ≤9s Heating Time ≤25s, adjustable Zoom 200x (X or Y) Electrode Life ≥5000 splices Tension Test ≥2N Start-up Time 5s Power Supply AC 220V±10%, 50Hz; 4500mAH Rechargeable lithium battery Low battery indication, battery reverse protection Battery Life ≥200 splicing and heating Chanrging Time ≤4 hours Size 125x125x135mm (L x W x H) Weight 1.7Kg (with battery) Work Temperature -20℃~+55℃ Storage Temperature -40℃~+70℃ Humidity ≤95% (non-condensing) Altitude 0 m~5000 m Wind Speed ≤15 m/s * Specifications subject to change without notice Standard Package:Splicer unit x 1, Fiber holder x 1 (pair), Lithium battery x 1, Power adapter x 1, Fiber cleaver x 1, Cooling tray x 1, USB cable x 1, Carry case x 1, Quick Reference, Alcohol pot,Miller stripper. Option Items:Rubber Protection, SCP/SOC Splicing Holder, Spare Electrode(one pair), Electrodes Cleaner, Cutting Blades, Thermal Stripper, Kevlar Scissors, Car Charger, Protection Clamp, Nipper (Plastic), Cotton Swab, Lamp, etc. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
oborisov1979 Опубликовано 4 августа, 2020 · Жалоба Дело тут в том, особенно старые волокна слегка отличаются, плюс к этому у них достаточно часто бывает, что сердцевина у них не совсем в центре, а гуляет в определенных пределах вокруг него. Если сварить "в лоб", то будет непрогнозируемое затухание. Также будет непрогнозируемое затухание, если внешний диаметр волокон отличается. Но если варить достаточно новый кабель одного производителя, то никаких проблем не будет и с V-канавочником. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 4 августа, 2020 · Жалоба А оно надо? Возиться с небесплатным V-канавочником?!)))) хотя бывают и другие задачи/ например заказчик потребовал сварить муфту так, шоб ее рефом было видно(0,1 дБ) на сварке волокна новые, аппарат магистральный!!!)))) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
BAHbKA Опубликовано 4 августа, 2020 · Жалоба 3 часа назад, Lexandr_kaz сказал: А оно надо? Возиться с небесплатным V-канавочником?!)))) хотя бывают и другие задачи/ например заказчик потребовал сварить муфту так, шоб ее рефом было видно(0,1 дБ) на сварке волокна новые, аппарат магистральный!!!)))) аттенюация есть в сварках нормальных Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
RaZeT Опубликовано 7 октября, 2020 · Жалоба Приветствую , почитал тему все хвалят свое болото вроде как ))) появилась потребность взять аппарат пользовался только с выравниванием по сердцевине ,вот и вопрос по цене смогу взять наверное только V канавочник .Не когда не пользовался ими хотелось бы узнать на улице/в пыли/в колодцах с таким лучше не лесть или они спокойно варят если не гнаться за магистральными потерями ?или лучше искать б/у сердцевинник? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Bachaa Опубликовано 7 октября, 2020 · Жалоба 1 минуту назад, RaZeT сказал: спокойно варят Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
BAHbKA Опубликовано 7 октября, 2020 · Жалоба 10 минут назад, RaZeT сказал: Приветствую , почитал тему все хвалят свое болото вроде как ))) появилась потребность взять аппарат пользовался только с выравниванием по сердцевине ,вот и вопрос по цене смогу взять наверное только V канавочник .Не когда не пользовался ими хотелось бы узнать на улице/в пыли/в колодцах с таким лучше не лесть или они спокойно варят если не гнаться за магистральными потерями ?или лучше искать б/у сердцевинник? тот же Джилонг 280 которым торгует наг вполне голодный аппарат. Выравнивание по канавкам. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба Варят и те и другие. ))) а еще и файберлоки и корелинки есть и мехконнекторы!!! Вообще аппарат не нужен! )) Все зависит от обьема решаемых задач и себестоимости единицы. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба Сигналфайер таки рулит- и неплохой ядерник и цена весьма приемлема и забавные фичи на борту особенно в версии AI-9. А пыль и прочие загрязнители, в принципе, одинаково влияют на оба типа- V- канавки есть у обоих. Если взвешеной пыли много ( как в литейных цехах), то она просто осаживается на очищенное волокно и тип сведения апппарата решающего значения не имеет. Для подключения абонентов джипона в больших обьемах и с высокой интенсивностью ( чтобы заработать!!) гораздо важнее удобство работы с аппаратом. Китайцы сейчас выпускают подобный V-канавочник под несколькими брендами 0,3 дБ средние потери на сплайсе. А так, ядерник более универсален Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
BAHbKA Опубликовано 7 октября, 2020 · Жалоба 1 час назад, Lexandr_kaz сказал: Варят и те и другие. ))) а еще и файберлоки и корелинки есть и мехконнекторы!!! Вообще аппарат не нужен! )) Все зависит от обьема решаемых задач и себестоимости единицы. Этим пользоваться могут только опытные бойцы. иначе это чревато перерасходом материала. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба Посмотри на али youysi-t9 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
RaZeT Опубликовано 7 октября, 2020 · Жалоба @Lexandr_kaz а опыт есть с аппаратом ?) Да нет наверное болие существенный аппарат нужен скорее.Просто понимаю что придется иногда в яме на улице варить и не пойму канавочные смогут 8мь волокон сварить или после каждого придется продувать, ну не имел опыта с ними фуджи/сумитомы сердцевинники только были ))) .Вот по бюджету сигналфаир интересный аппарат. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
BAHbKA Опубликовано 7 октября, 2020 · Жалоба 1 минуту назад, RaZeT сказал: @Lexandr_kaz а опыт есть с аппаратом ?) Да нет наверное болие существенный аппарат нужен скорее.Просто понимаю что придется иногда в яме на улице варить и не пойму канавочные смогут 8мь волокон сварить или после каждого придется продувать, ну не имел опыта с ними фуджи/сумитомы сердцевинники только были ))) .Вот по бюджету сигналфаир интересный аппарат. джилонг в ямах и грязных подвалах отлично себя показал Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Salat Опубликовано 7 октября, 2020 · Жалоба 2 часа назад, Lexandr_kaz сказал: Посмотри на али youysi-t9 О да это же https://aliexpress.ru/i/4000839529052.html ну хоть пишут честно. но если хоть немного больше денег то брать стоит что-то посерьезнее. хоть тотже 39й, или 50й. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба 3 минуты назад, Salat сказал: О да это же https://aliexpress.ru/i/4000839529052.html ну хоть пишут честно. но если хоть немного больше денег то брать стоит что-то посерьезнее. хоть тотже 39й, или 50й. Новый AI-9 таки будет и лучше и дешевле древних 50, 39 . Ибо за такие деньги отдадут аппарат только с мертвыми АКБ ( и прочими сюрпризами). И еще они мееедленные и громоздкие. 39 повеселее будет, но про обьективы их микроскопов уже все знают. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Salat Опубликовано 7 октября, 2020 (изменено) · Жалоба 6 минут назад, Lexandr_kaz сказал: Новый AI-9 таки будет и лучше и дешевле древних 50, 39 . Ибо за такие деньги отдадут аппарат только с мертвыми АКБ ( и прочими сюрпризами). И еще они мееедленные и громоздкие. 39 повеселее будет, но про обьективы их микроскопов уже все знают. У него авто определение волокон есть? и еще там забавная фигня с регистрацией электродов, ну нафиг. Изменено 7 октября, 2020 пользователем Salat Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба Мой AI-7 уже обогащает нового щастливого владельца!! А разница в скорости печки, таки имеет значение при количестве сварок больше 20 на одном месте. 27 секунд у s178a против 13 У сигналфайра. На 10 сварках это будут смешные 140-160 сек, а вот для 50 и более.... 1 минуту назад, Salat сказал: У него авто определение волокон есть? и еще там забавная фигня с регистрацией электродов, ну нафиг. Есть и автоопределение, весьма корректно работает на последних версиях. С регистрацией проблем никаких- полторы секунды. Электроды чистить можно. в апреле перед началом серьезного обьема калибровали все аппараты сварщиков , чтобы понимать насколько они врут. Простой стенд: оптический тестер, ОВ оконцованное и по 20 сварок на аппарат под тестером. Зоопарк был знатный и 50 и 178 и 740 и AI-7 и прочее. Угадай с двух раз кто был в аутсайдерах? )) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
BAHbKA Опубликовано 7 октября, 2020 · Жалоба 46 минут назад, Lexandr_kaz сказал: Новый AI-9 таки будет и лучше и дешевле древних 50, 39 . Ибо за такие деньги отдадут аппарат только с мертвыми АКБ ( и прочими сюрпризами). И еще они мееедленные и громоздкие. 39 повеселее будет, но про обьективы их микроскопов уже все знают. У меня 2006 года 39тка с пробегом 19000. Самая старая ревизия. Работает на ура Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Lexandr_kaz Опубликовано 7 октября, 2020 · Жалоба 5 минут назад, BAHbKA сказал: У меня 2006 года 39тка с пробегом 19000. Самая старая ревизия. Работает на ура Для нее это не пробег...два, три года не очень активной работы. Бывший AI-7 уже подбирается к этому пробегу. Я с начала года на 178 уже более 8000 сварил. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Salat Опубликовано 9 октября, 2020 · Жалоба В 07.10.2020 в 17:37, Lexandr_kaz сказал: Для нее это не пробег...два, три года не очень активной работы. Бывший AI-7 уже подбирается к этому пробегу. Я с начала года на 178 уже более 8000 сварил. В общем кому как а Горелов на своем канале к AI-7 скептичен. Хотя он кроме инно ко всему скептичен. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
sauroneg Опубликовано 9 октября, 2020 · Жалоба @Salat Горелов- это который в файбертул? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Salat Опубликовано 9 октября, 2020 · Жалоба 1 час назад, sauroneg сказал: @Salat Горелов- это который в файбертул? да Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
sauroneg Опубликовано 9 октября, 2020 · Жалоба @Salat он был скептичен, потому что нет опыта длительного использования у народа, не выявлены болячки и т. д. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Salat Опубликовано 9 октября, 2020 · Жалоба 38 минут назад, sauroneg сказал: @Salat он был скептичен, потому что нет опыта длительного использования у народа, не выявлены болячки и т. д. да черт его знает он его и в мае матюгнул Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
