Victor Pestov Posted September 1, 2015 Posted September 1, 2015 (edited) http://data.nag.ru/SNR%20ERD/Programs/SNR_Flasher Использование: Output/ubuntu/SNR_Flasher file.hex ERD_IP где ERD_IP - IPv4 адрес ERD device. example: 192.168.15.20 file.hex - файл прошивки устройства Проверено на linux i386 Поддерживаемые устройства: SNR-ERD-2.3 SNR-ERD-3.2 SNR-ERD-3S SNR-ERD-GSM-1.0 SNR-ERD-GSM-1.1 Octopus-GSM (SNR-GSM-SERIAL-1.2) Octopus-GSM (SNR-GSM-SERIAL-1.1) SNR-ERD-COUNTER-1.0 SNR-ERD-COUNTER-1.1 Отпишитесь, кто попробует Edited September 1, 2015 by Victor Pestov Вставить ник Quote
LynxChaus Posted February 16, 2018 Posted February 16, 2018 Попробовал. Не работает. $ snmpwalk -v1 -c public 10.4.4.102 SNMPv2-MIB::sysDescr.0 = STRING: Fmv_6.5 SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.40418.2.2 SNMPv2-MIB::sysName.0 = STRING: SNR IF-MIB::ifIndex.0 = INTEGER: 1 IF-MIB::ifPhysAddress.0 = STRING: f8:f0:82:2:11:99 IP-MIB::ipAdEntAddr.0 = IpAddress: 10.4.4.102 $ ./SNR_Flasher firmware_SNR-ERD-2.3.hex 10.4.4.102 argv[1] firmware_SNR-ERD-2.3.hex argv[2] 10.4.4.102 Set ip: 10.4.4.102 File loaded 27548 bytes Work with: 10.4.4.102 Send reboot...OK Look ERD boot loader.....Faild Entering programming mode.....Faild Query flash block size.....FaildLen: -1 Set address to start......Faild Get flash blockFloating point exception Вставить ник Quote
Victor Pestov Posted February 19, 2018 Author Posted February 19, 2018 В 16.02.2018 в 20:14, LynxChaus сказал: Попробовал. Не работает. $ snmpwalk -v1 -c public 10.4.4.102 SNMPv2-MIB::sysDescr.0 = STRING: Fmv_6.5 SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.40418.2.2 SNMPv2-MIB::sysName.0 = STRING: SNR IF-MIB::ifIndex.0 = INTEGER: 1 IF-MIB::ifPhysAddress.0 = STRING: f8:f0:82:2:11:99 IP-MIB::ipAdEntAddr.0 = IpAddress: 10.4.4.102 $ ./SNR_Flasher firmware_SNR-ERD-2.3.hex 10.4.4.102 argv[1] firmware_SNR-ERD-2.3.hex argv[2] 10.4.4.102 Set ip: 10.4.4.102 File loaded 27548 bytes Work with: 10.4.4.102 Send reboot...OK Look ERD boot loader.....Faild Entering programming mode.....Faild Query flash block size.....FaildLen: -1 Set address to start......Faild Get flash blockFloating point exception При этом есть пинг до устройства? Какое время ответа? Приложите, пожалуйста, trace лог Вставить ник Quote
LynxChaus Posted February 19, 2018 Posted February 19, 2018 3 hours ago, Victor Pestov said: При этом есть пинг до устройства? Был до запуска прошивальщика. Теперь - нет. 3 hours ago, Victor Pestov said: Какое время ответа? ~50ms 3 hours ago, Victor Pestov said: trace лог trace чего? Вставить ник Quote
seprize Posted February 20, 2018 Posted February 20, 2018 В 16.02.2018 в 20:14, LynxChaus сказал: Попробовал. Не работает. $ snmpwalk -v1 -c public 10.4.4.102 SNMPv2-MIB::sysDescr.0 = STRING: Fmv_6.5 SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.40418.2.2 SNMPv2-MIB::sysName.0 = STRING: SNR IF-MIB::ifIndex.0 = INTEGER: 1 IF-MIB::ifPhysAddress.0 = STRING: f8:f0:82:2:11:99 IP-MIB::ipAdEntAddr.0 = IpAddress: 10.4.4.102 $ ./SNR_Flasher firmware_SNR-ERD-2.3.hex 10.4.4.102 argv[1] firmware_SNR-ERD-2.3.hex argv[2] 10.4.4.102 Set ip: 10.4.4.102 File loaded 27548 bytes Work with: 10.4.4.102 Send reboot...OK Look ERD boot loader.....Faild Entering programming mode.....Faild Query flash block size.....FaildLen: -1 Set address to start......Faild Get flash blockFloating point exception Интересует traceroute до устройства 10.4.4.102 Судя по логу программатор не смог связаться с устройством ( Look ERD boot loader.....Faild ) После того как отправил в перезагрузку (Send reboot...OK) Этот лог это единственный запуск программатора, или были еще запуски? как предположение, что этот лог уже после появления проблем с устройством, т.к. в логе нет информации даже о начале загрузке прошивки в само устройство Вставить ник Quote
LynxChaus Posted February 20, 2018 Posted February 20, 2018 Там 5 хопов. Какое это отношение имеет к работе софта? 5 hours ago, seprize said: После того как отправил в перезагрузку (Send reboot...OK) Ага. В ребут то оно уходит. А потом еще с пару суток не пингуется. 5 hours ago, seprize said: Этот лог это единственный запуск программатора, или были еще запуски? Не в курсе, я запускал только один раз. Сразу скажу, железка физически километрах в 200 от меня и на светодиодики посмотреть возможности нет. Как и дернуть её по питанию. Вставить ник Quote
