# aptitude install default-jre-headless
The following NEW packages will be installed:
 ca-certificates-java{a} default-jre-headless icedtea-6-jre-cacao{a} icedtea-6-jre-jamvm{a} java-common{a} liblcms2-2{a} libnspr4{a} libnss3{a} openjdk-6-jre-headless{a}
 openjdk-6-jre-lib{a} tzdata-java{ab}
0 packages upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 42.1 MB of archives. After unpacking 62.6 MB will be used.
The following packages have unmet dependencies:
tzdata-java : Depends: tzdata (= 2014j-0wheezy1) but 2015e-0+deb7u1 is installed.
The following actions will resolve these dependencies:
    Keep the following packages at their current version:
1)     ca-certificates-java [Not Installed]
2)     default-jre-headless [Not Installed]
3)     icedtea-6-jre-cacao [Not Installed]
4)     icedtea-6-jre-jamvm [Not Installed]
5)     openjdk-6-jre-headless [Not Installed]
6)     openjdk-6-jre-lib [Not Installed]
7)     tzdata-java [Not Installed]
Насколько я понял, JRE почему-то требует именно 2014j-0wheezy1, а у меня установлен 2015e-0+deb7u1.
Не подскажите, как это исправить?
Поискать tzdata-java там-же, где
tzdata бралось.
https://packages.debian.org/ru/tzdata
