Подскажите,
через Uplink порт нужно отдать c ex4200 на Cisco несколько VLAN. Среди этих VLAN так же должен быть Q-in-Q S-VLAN в котором несколько CVLAN.
1 - Настройка QinQ vlan
set vlans vlan1007 description "pppoe s-vlan"
set vlans vlan1007 vlan-id 1007
set vlans vlan1007 dot1q-tunneling customer-vlans 200-208
2 - Настройка UPLINK порт
set interfaces xe-0/1/0 unit 0 family ethernet-switching port-mode trunk
set interfaces xe-0/1/0 unit 0 family ethernet-switching vlan members vlan1007
set interfaces xe-0/1/0 unit 0 family ethernet-switching vlan members vlan6
set interfaces xe-0/1/0 unit 0 family ethernet-switching vlan members vlan54
set interfaces xe-0/1/0 unit 0 family ethernet-switching vlan members vlan104
set interfaces xe-0/1/0 unit 0 family ethernet-switching vlan members vlan154
Настройка одного из DOWNLINK порта с котрого приходят VLAN
set interfaces ge-0/0/16 unit 0 family ethernet-switching port-mode trunk
set interfaces ge-0/0/16 unit 0 family ethernet-switching vlan members vlan2
set interfaces ge-0/0/16 unit 0 family ethernet-switching vlan members vlan3
set interfaces ge-0/0/16 unit 0 family ethernet-switching vlan members vlan4
set interfaces ge-0/0/16 unit 0 family ethernet-switching vlan members vlan5
set interfaces ge-0/0/16 unit 0 family ethernet-switching vlan members vlan208
СVLAN :200-208
теперь вопрос
хватит ли настроек из п.1 и п.2
Потому как есть предложение делать физ.петлю. с ge-0/0/21 и ge-0/0/22
set interfaces ge-0/0/21 unit 0 description "out pppoe-qinq-loop"
set interfaces ge-0/0/21 unit 0 family ethernet-switching port-mode access
set interfaces ge-0/0/21 unit 0 family ethernet-switching vlan members vlan1007
set interfaces ge-0/0/22 unit 0 description "incoming pppoe-qinq-loop"
set interfaces ge-0/0/22 unit 0 family ethernet-switching port-mode trunk
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan200
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan201
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan202
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan203
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan204
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan205
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan206
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan207
set interfaces ge-0/0/22 unit 0 family ethernet-switching vlan members vlan208
Edited by MasterJey
