Всем привет.
Столкнулся с такой проблемой.
Есть Huawei S2326TP software, Version 5.70
В Портах GigabitEthernet0/0/1 и GigabitEthernet0/0/2 стоят SFP модуля, инфа ниже.
[b]GigabitEthernet0/0/1[/b] transceiver information:
Common information:
 Transceiver Type               :1000_BASE_LX_SFP
 Vendor PN                      :SFP-LX.LC.20
 Connector Type                 :LC
 Wavelength(nm)                 :0
 Transfer Distance(m)           :10000(90um),550(50um),550(62.5um)
 Digital Diagnostic Monitoring  :NO
 Vendor Name                    :VIMCOM
 Ordering Name                  :
[b]GigabitEthernet0/0/2[/b] transceiver information:
Common information:
 Vendor PN                      :SFP-WDM5.10
 Connector Type                 :SC
 Wavelength(nm)                 :1550
 Vendor Name                    :OptiCin
 Ordering Name                  :
С других сторон стоят такие же модуля, а в качестве коммутуторов рубики 8ми портовые.
При включении рубика в сеть, в логах хуавея сыпился такая портянка
Jun 25 2015 19:38:08+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[0]:Interface GigabitEthernet0/0/2 has tu
rned into UP state.
Jun 25 2015 19:36:13+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[1]:Interface GigabitEthernet0/0/2 has tu
rned into DOWN state.
Jun 25 2015 19:36:13+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[2]:Interface GigabitEthernet0/0/2 has tu
rned into UP state.
Jun 25 2015 19:35:37+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[3]:Interface GigabitEthernet0/0/2 has tu
Jun 25 2015 19:35:37+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[4]:Interface GigabitEthernet0/0/2 has tu
rned into UP state.
Jun 25 2015 19:35:02+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[5]:Interface GigabitEthernet0/0/2 has tu
Jun 25 2015 19:35:02+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[6]:Interface GigabitEthernet0/0/2 has tu
rned into UP state.
Jun 25 2015 19:34:26+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[7]:Interface GigabitEthernet0/0/2 has tu
Jun 25 2015 19:34:26+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[8]:Interface GigabitEthernet0/0/2 has tu
rned into UP state.
Jun 25 2015 19:33:51+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[9]:Interface GigabitEthernet0/0/2 has tu
Jun 25 2015 19:33:51+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[10]:Interface GigabitEthernet0/0/2 has t
urned into UP state.
Jun 25 2015 19:33:15+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[11]:Interface GigabitEthernet0/0/2 has t
urned into DOWN state.
Jun 25 2015 19:33:15+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[12]:Interface GigabitEthernet0/0/2 has t
Jun 25 2015 19:32:45+03:00 MRJ_CORE %%01IFNET/4/IF_STATE(l)[13]:Interface GigabitEthernet0/0/2 has t
И вот так сыпится минут 20, потом порт подымается и идет трафик.
Что с этим хуавеем не так? До него был длин 3200-26, и на нем было все хорошо.
undo negotiation auto + speed 1000 на порту попробуйте. ещё в хуавее на v1r5 и v1r6 до какого-то патча надо явно задавать режим комбо-порта (combo-port fiber), иначе линк флапает. но это уже давно починили, так что dis ver и dis pat в студию
Huawei Versatile Routing Platform Software
VRP (R) software, Version 5.70 (S2300 V100R005C01SPC100)
Copyright (C) 2000-2011 HUAWEI TECH CO., LTD
Quidway S2326TP-EI Routing Switch uptime is 0 week, 5 days, 5 hours, 2 minutes
EFFE 0(Master) : uptime is 0 week, 5 days, 5 hours, 1 minute
64M bytes DDR Memory
16M bytes FLASH
Pcb      Version :  VER C
Basic  BOOTROM  Version :  128 Compiled at Aug 24 2010, 21:58:24
Software Version : VRP (R) Software, Version 5.70 (S2300 V100R005C01SPC100)
Patch Package Name   :flash:/s23_33_53-v100r005sph006.pat
Patch Package Version:V100R005SPH006
*                The hot patch information, as follows:                *
    Slot           Type           State          Count
    0              C              Running        10
interface GigabitEthernet0/0/1
undo ntdp enable
ndp enable
port media type fiber
combo-port auto
interface GigabitEthernet0/0/2
undo ntdp enable
ndp enable
combo-port auto
да, на этом патче есть баг с комбопортом. делайте combo-port fiber для начала или ставьте патч актуальный(так удобнее). баг исправлен и в v1r5 и в v1r6. какой патч щас актуальный для v1r5 я хз
Понял. Спасибо. Тема закрыта.
Сделал combo-port fiber вроде помогло. Пока не флапаются порты.
Конечно. Ребутнули на каждой стороне по коммутатору. Линк поднялся сразу.
ну отлично. но всё же рекомендую патч. никогда не знаешь когда внезапно понадобится медный GE-порт) особенно когда кол-во свитчей измеряется тысячами
This topic is now closed to further replies.
