cisco_1
interface GigabitEthernet0/0.22
description IS-IS
encapsulation dot1Q 22
ip address 10.46.1.2 255.255.255.0
ip router isis
ipv6 address FE80::A2E:102 link-local
ipv6 enable
ipv6 router isis
interface GigabitEthernet0/0.25
encapsulation dot1Q 25
ip address 192.168.25.248 255.255.255.0
ipv6 address FE80::C0A8:19F8 link-local
ipv6 enable
ipv6 address 2001:0002::45a/64
router isis
net 49.0001.0000.0000.2002.00
metric-style wide
log-adjacency-changes
redistribute static ip
passive-interface default
no passive-interface GigabitEthernet0/0.22
address-family ipv6
multi-topology
redistribute static
exit-address-family
cisco_2
interface FastEthernet0/0.22
ip address 10.46.1.1 255.255.255.0
ipv6 address FE80::A2E:101 link-local
ipv6 enable
ipv6 address 2001:0002::45c/64
ip router isis
ipv6 router isis
router isis
net 49.0001.0000.0000.2001.00
metric-style wide
no passive-interface FastEthernet0/0.22
address-family ipv6
multi-topology
redistribute static
exit-address-family
%CLNS-5-ADJCHANGE: ISIS: Adjacency to 0000.0000.2002 (FastEthernet0/0.22) Up, new adjacency
%CLNS-5-ADJCHANGE: ISIS: Adjacency to 0000.0000.2002 (FastEthernet0/0.22) Up, new adjacencyxit
Проверка
cisco_1
ping 2001:0002::45c
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 2001:2::45C, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
cisco_2
ping 192.168.25.248
Sending 5, 100-byte ICMP Echos to 192.168.25.248, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
ping 2001:2::45A
Sending 5, 100-byte ICMP Echos to 2001:2::45A, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/4 ms
Роутинг с Cisco_1
Gateway of last resort is not set
172.16.0.0/32 is subnetted, 1 subnets
i L1 172.16.172.1 [115/10] via 10.46.1.1, 00:01:00, GigabitEthernet0/0.22
show ipv6 route isis
IPv6 Routing Table - default - 2 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
B - BGP, HA - Home Agent, MR - Mobile Router, R - RIP
H - NHRP, I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea
IS - ISIS summary, D - EIGRP, EX - EIGRP external, NM - NEMO
ND - ND Default, NDp - ND Prefix, DCE - Destination, NDr - Redirect
O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2, la - LISP alt
lr - LISP site-registrations, ld - LISP dyn-eid, a - Application
I1 2001:2::/64 [115/10]
via FE80::A2E:101, GigabitEthernet0/0.22
теперь RedbAck SE600
interface IS-IS
ip address 10.46.1.3/24
ipv6 link-local fe80::a2e:103
router isis SSE600_2
net 49.0001.0000.0000.2003.00
address-family ipv4 unicast
redistribute static
address-family ipv6 unicast
redistribute static
interface IS-IS
! bind to link-group dot1q-1q pvc 100
проверка
Cisco_1#ping 10.46.1.3
Sending 5, 100-byte ICMP Echos to 10.46.1.3, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
Cisco_2#ping fe80::a2e:103
Output Interface: FastEthernet0/0.22
Sending 5, 100-byte ICMP Echos to FE80::A2E:103, timeout is 2 seconds:
Packet sent with a source address of FE80::A2E:101
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
sse600
RSSE2#show isis database
IS-IS level 1 link-state database for tag SSE600_2:
LSPID Sequence Checksum Holdtime AT/OL Len
RSSE2.00-00* 0xf 0x3834 1134 1/0 87
Total IS-IS LSP(s) for tag SSE600_2 in Level-1: 1
IS-IS level 2 link-state database for tag SSE600_2:
RSSE2.00-00* 0xd 0x3721 1134 0/0 212
Total IS-IS LSP(s) for tag SSE600_2 in Level-2: 1
Логи с эриксона
May 29 09:00:28: %SHMM-6-INFO: ndd: Attaching to existing shared memory instance for key 77834 in sds-ipcc(0x1001fe000)
May 29 09:05:12: %SHMM-6-INFO: isisd: Attaching to existing shared memory instance for key 77834 in sds-ipcc(0x1003e5000)
и ничего не работает
кто знает в чем причина ?
Edited by alexpn
интерфейсы все добавлены? Соседство покажите
дак во соседства с эрриксоном то и нет
странно както в доке все есть
да и в доке есть функция multi-topology
у меня её нет !!! прикол какойто
IOS
show version
Redback Networks SmartEdge OS Version SEOS-12.1.1.9-Release
Built by sysbuild@eussjlx7016.sj.us.am.ericsson.se Mon Jan 26 23:09:19 PST 2015
Copyright © 1998-2015, Redback Networks Inc. All rights reserved.
System Bootstrap version is Mips,rev2.0.2.68
Installed minikernel version is 11.7
Router Up Time - 102 days, 12 hours 37 minutes 3 secs
Edited by alexpn
Вроде как ISIS на эрике только для межконтекстной маршрутизации.
ну в доке то все ок !!!
это как рекомендация, т.к. ISIS самый легкий в настройке. Вы можете для межконтекстной использовать и другие протоколы.
странным кажется команда
напишите
no passive на нужный интерфейс
напишите
Проблема была банальна
в circuit mtu
установил значение чуть меньше чем на циске и все заработало
show ip route isis
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 10.46.1.3 to network 0.0.0.0
i*L1 0.0.0.0/0 [115/10] via 10.46.1.3, 00:02:10, GigabitEthernet0/0.22
10.0.0.0/8 is variably subnetted, 11 subnets, 3 masks
i L2 10.0.14.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.1.0.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.1.2.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.1.3.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.1.11.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.10.255.0/30
i L2 10.46.0.0/24 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.50.1.0/30 [115/10] via 10.46.1.3, 00:02:08, GigabitEthernet0/0.22
i L2 10.50.1.4/30 [115/10] via 10.46.1.3, 00:02:10, GigabitEthernet0/0.22
вообщем помогите кто знает
заводится IS-IS только с MTU 1500
мне нужно чтоб на интерфейсе MTU был 9198
пробовал следующее
cisco
clns mtu 1500 не помогает
no isis hello padding не помогает
на эриксоне
circuit mtu 1500
по другому не заводится
кто знает куда копать ???
на интерфейсе с виланом MTU задать отдельно не могу
clns mtu 1500 не воспринимается
