Здрасьте всем!
Проблема в том, что в (switchport trunk allowed vlan 1,840,931,1002-1005) VLAN 1 и 1002-1005 появляются автоматом и не позволяют себя удалить.
WS-C3524-PWR-RusDvor#sh ver
Cisco Internetwork Operating System Software
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
WS-C3524-PWR-RusDvor uptime is 1 week, 5 days, 9 hours, 11 minutes
System returned to ROM by power-on
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3524-PWR-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID CHK0623W1PK, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:E8:1B:F9:40
Motherboard assembly number: 73-4033-08
Power supply part number: 34-0968-02
Motherboard serial number: CAT062304RM
Power supply serial number: LIT062101WG
Model revision number: F0
Motherboard revision number: A0
Model number: WS-C3524-PWR-XL-EN
Daughterboard serial number: CAT0623023C
System serial number: CHK0623W1PK
Configuration register is 0xF
WS-C3524-PWR-RusDvor#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname WS-C3524-PWR-RusDvor
enable secret 5 $1$yj4Z$C4H1VZ/TR179UciDebARf0
ip subnet-zero
interface FastEthernet0/1
description Trunk IKS  ! Это аплинк на провайдера 2 и здесь пойдет VLAN 840 и VLAN 931 но VLAN 1 нужно убрать.
switchport trunk encapsulation dot1q
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description Uplink Enter   ! Это аплинк на провайдера 1
switchport access vlan 198
power inline never
no cdp enable
interface GigabitEthernet0/1
description Trunk Office ! А это транк в офис
switchport trunk allowed vlan 1,198,199,1002-1005
interface GigabitEthernet0/2
description Grigorich Home
interface VLAN1
ip address 192.168.199.212 255.255.255.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 192.168.199.199
snmp-server engineID local 0000000902000009E81BF940
snmp-server community private RW
snmp-server community public RO
line con 0
transport input none
stopbits 1
line vty 0 4
password password
login
line vty 5 15
password password
login
end
Свитч стоит на площадке провайдера.
Edited by sunrise333
switchport trunk allowed vlan remove 1 ?
Команду то я знал, только она не проходила в старых свитчах.
И всё равно спасибо.
я просто не знаком с данной моделью. Есть коммутаторы, на которых нельзя убрать первый влан с порта.
а что нить типа
switchport trunk native ?
 vlan  Set native VLAN when interface is in trunking mode
есть? Может этим поиграться?
или
switchport trunk ?
pruning        Set pruning VLAN characteristics when interface is in trunking mode
Edited by ShumBor
Можно полностью уйти с ВЛАН1 на этом динозавре, например на ВЛАН2. А ВЛАН1 в транке на офис сечь нижестоящим оборудованием.
Также на порте прова можно указать другую native и выключить этот ВЛАН. Это если надо оградиться от нетегированных кадров.
Идея: не использовать ВЛАНы которые нельзы удалить из конфига, и блочить untag кадры от прова.
Ага а вот и динозавр нашелся.
Собственно совет то нужен в том, что бы управляющий VLAN не летел в сторону провайдера.
version 12.0
no service pad
hostname Switch_IKS
enable secret 5 $password
no spanning-tree vlan 1
ip subnet-zero
switchport trunk allowed vlan 1,800,898,1002-1005
switchport access vlan 898
switchport access vlan 800
interface VLAN1
ip address 192.168.189.202 255.255.255.0
no ip route-cache
line con 0
stopbits 1
line vty 0 4
password password
login
line vty 5 15
login
end
Switch_IKS#sh ver
Switch_IKS uptime is 5 weeks, 19 hours, 30 minutes
Processor board ID CHK0621V1C8, with hardware revision 0x00
Base ethernet MAC Address: 00:09:B7:D4:E0:C0
Motherboard serial number: CAT062003ZF
Power supply serial number: DAB06210GGF
Daughterboard serial number: CAT062006XB
System serial number: CHK0621V1C8
Если встроенной функции удаления PVID нет, создаёте гарантированно не существующий нигде на вашей сети vlan, вписываете его PVID'ом. Всё. Тов. Лобанов об этом уже писал.
У Вас управляющий VLAN 1 ? Поздравляю! Впрочем если из других зарезервированных/специальных - тоже не сахар.
Меняйте VLAN иначе вечно будут всякие сюрпризы.
VLAN 1 часто у разных вендоров ведет себя особым образом. И совершенно разным. Вплоть до того что он глобально общий без возможности его запретить или же с возможностью, но где-то в глобальных настройках...
