Добрый день. Подскажите как настроить relay-information на ES4626-SFP в бинарном виде. Т.е.
Switch-1 (es3528)		    |	port 1/8 |-----------|	port 1/1  |DHCP
Relay-information:		    |----------->| ES4626-SFP|----------->|Agent Circuit ID:
0106000400690101020800067072cfae08dc|		 |-----------|		  |566c616e3130352b45746865726e6574312f387072cf59f5cd
								  |В ansi: "Vlan105+Ethernet1/8" и мак адрес
Получить на DHCP "Vlan105+Ethernet1/8" в "0106 0004 0069 0108 0208 0006 7072cf59f5cd".
Настройка
en
config
service dhcp
ip forward-protocol udp bootps
ip dhcp relay information option
ip dhcp snooping enable
ip dhcp snooping vlan 105
int eth 1/1-8
ip dhcp snooping trust
exit
interface vlan 4000
ip address 10.128.0.1 255.255.0.0
int eth 1/1
switchport access vlan 4000
int vlan 105
ip address 10.0.5.1 255.255.255.0
ip helper-address 10.128.10.1
Часть конфига
ip dhcp snooping vlan 1;101-106
vlan 1;101-106;4000
Interface Ethernet1/1
Interface Ethernet1/8
switchport mode trunk
interface Vlan105
 !forward protocol udp 67(active)!
ip helper-address 10.128.10.1   <-- DHCP
interface Vlan4000
ip address 10.128.0.8 255.255.0.0
В качестве DHCP "DHCP server with SQL support on Perl" Ivan_83
ES4626-SFP Device
SoftWare Version 6.2.150.18
BootRom Version 4.12.1
HardWare Version 3.0
CPLD Version 2.0
