Коллеги, хотим на по снмп снимать данные DDM с установленных модулей. Сами модули тоже с DDM
для:
Juniper ex-4550
Juniper ex-4500
Dlink -DGS3620-sc
Dlink -DGS3627G
Заранее очень признателен
лучше скачайте mibs и найдите сами.
http://habrahabr.ru/post/206612/
Для dlink вам нужно вот эта ветка
dmvy@dmvy-tn:/mnt/bigdata/mibs/3620/proprietaryMIB$ snmptranslate -Ln \
-M ./Dlink-common-mgmt/:./Dlink-mgmt/:/usr/share/mibs/ietf:/usr/share/mibs/iana \
-m DDM-MGMT-MIB \
-On -Tp .1.3.6.1.4.1.171.12.72
+--swDdmMIB(72)
  +--swDdmCtrl(1)
  |  +-- -RW- EnumVal   swDdmTrapState(1)
  |  |        Values: enabled(1), disabled(2)
  |  +-- -RW- EnumVal   swDdmLogState(2)
  |  +-- -RW- EnumVal   swDdmPowerUnit(3)
  |           Values: mw(1), dbm(2)
  +--swDdmInfo(2)
  |  +--swDdmStatus(1)
  |     +--swDdmStatusTable(1)
  |        +--swDdmStatusEntry(1)
  |           |  Index: swDdmPort
  |           +-- -R-- INTEGER   swDdmPort(1)
  |           |        Range: 1..65535
  |           +-- -R-- String    swDdmTemperature(2)
  |           |        Textual Convention: DisplayString
  |           +-- -R-- String    swDdmVoltage(3)
  |           +-- -R-- String    swDdmBiasCurrent(4)
  |           +-- -R-- String    swDdmTxPower(5)
  |           +-- -R-- String    swDdmRxPower(6)
  +--swDdmMgmt(3)
  |  +--swDdmThresholdMgmt(1)
  |  |  +--swDdmThresholdMgmtTable(1)
  |  |     +--swDdmThresholdMgmtEntry(1)
  |  |        |  Index: swDdmPort, swDdmThresholdType
  |  |        +-- -R-- EnumVal   swDdmThresholdType(1)
  |  |        |        Values: temperature(1), voltage(2), bias(3), txPower(4), rxPower(5)
  |  |        +-- -RW- String    swDdmHighAlarm(2)
  |  |        +-- -RW- String    swDdmLowAlarm(3)
  |  |        +-- -RW- String    swDdmHighWarning(4)
  |  |        +-- -RW- String    swDdmLowWarning(5)
  |  +--swDdmActionMgmt(2)
  |     +--swDdmActionMgmtTable(1)
  |     |  +--swDdmActionMgmtEntry(1)
  |     |     |  Index: swDdmPort, swDdmActionType
  |     |     +-- -R-- EnumVal   swDdmActionType(1)
  |     |     |        Values: alarm(1), warning(2)
  |     |     +-- -RW- EnumVal   swDdmShutdown(2)
  |     |     |        Values: enabled(1), disabled(2), other(3)
  |     |     +-- -RW- EnumVal   swDdmTrapAndLog(3)
  |     +--swDdmPortMgmtTable(2)
  |        +--swDdmPortMgmtEntry(1)
  |           |  Index: swDdmPort
  |           +-- -RW- EnumVal   swDdmPortState(1)
  |           +-- -RW- EnumVal   swDdmPortShutdown(2)
  |                    Values: alarm(1), warning(2), none(3), other(4)
  +--swDdmNotify(4)
     +--swDdmNotifyPrefix(0)
     |  +--swDdmAlarmTrap(1)
     |  +--swDdmWarningTrap(2)
     +--swDdmNotificationBinding(1)
        +-- ---N EnumVal   swDdmThresholdExceedType(1)
        |        Values: high(1), low(2)
        +-- ---N EnumVal   swDdmThresholdExceedOrRecover(2)
                 Values: exceed(1), recover(2)
Нашел эту ветку командой:
-m ALL \
-Tp 1|grep -i ddm
           |     |  |  |     |        Values: sendSABM(1), sendDISC(2), sendDM(3), none(4), other(5)
           |     |  |  +--swDdmMIB(72)
           |     |  |  |  +--swDdmCtrl(1)
           |     |  |  |  +--swDdmInfo(2)
           |     |  |  |  |  +--swDdmStatus(1)
           |     |  |  |  |           |  Index: swDdmPort
           |     |  |  |  +--swDdmMgmt(3)
           |     |  |  |  |           |  Index: swDdmPort
           |     |  |  |  +--swDdmNotify(4)
Оставалось найти в каком модуле упоминается swDdmMIB и указать искать только в этом модуле.
Juniper ex
не поддерживает снятие уровней по SNMP.
(есть пара мест, где написано, что поддерживает, но это неправда)
З.Ы. через JUNOScript снимать не пробовали, спасибо за наводку.
Edited by ollsanek
