Добрый день
Была замена коммутатор ядре и как бы не работает лацп между X670 и стеком из 3х x450a, линки все ап, но маков вообще не видать.
Со стороны 670 лацп актив, со стороны x450 пасив.
В сторону жунипера 2 лацпа и в сторону длинков, все ок, взлетело аж бегом, проблем нет
на x670 такой софт
x670-Under.1 # sh switch
SysName:          x670-Under
SysLocation:      L9
SysContact:       noc@under.net.ua
System MAC:       00:04:96:52:C9:1D
System Type:      X670-48x
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Wed Apr 29 16:06:09 2015
Timezone:         [Auto DST Enabled] GMT Offset: 120 minutes, name is Kiev.
                 DST of 60 minutes is currently in effect, name is not set.
                 DST begins every first Sunday March at 3:00
                 DST ends every last Sunday October at 3:00
Boot Time:        Wed Apr 29 12:56:34 2015
Boot Count:       45
Next Reboot:      None scheduled
System UpTime:    3 hours 9 minutes 35 seconds
Current State:    OPERATIONAL
Image Selected:   secondary
Image Booted:     secondary
Primary ver:      15.5.3.4
Secondary ver:    15.7.1.4
                 patch1-1
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.7.1.4
                 3023499 bytes saved on Wed Apr 29 14:19:30 2015
шаринг
x670-Under.2 # sh sharing
Load Sharing Monitor
Config    Current Agg     Min     Ld Share    Ld Share  Agg   Link   Link Up
Master    Master  Control Active  Algorithm   Group    а Mbr   State  Transitions
    1            LACP       1     L3_L4       1          -      R       10
    3            LACP       1     L3_L4       3          -      R        1
                                  L3_L4       4          -      R        1
    7            LACP       1     L3_L4       7          -      R        1
                                  L3_L4       8          -      R        1
   11            LACP       1     L3_L4       11         -      R        0
                                  L3_L4       12         -      R        1
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Minimum Active: (<) Group is down. # active links less than configured minimum
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
                       (L3_L4) Layer 3 address and Layer 4 port based
                       (custom) User-selected address-based configuration
Custom Algorithm Configuration: ipv4 L3-and-L4, xor
Number of load sharing trunks: 4
x670-Under.3 # sh lacp
LACP Up                             : Yes
LACP Enabled                        : Yes
System MAC                          : 00:04:96:52:c9:1d
LACP PDUs dropped on non-LACP ports : 0
Lag        Actor    Actor   Partner            Partner  Partner  Agg
          Sys-Pri  Key     MAC                Sys-Pri  Key      Count
1              0    0x03e9  00:00:00:00:00:00      0    0x0000   0
сам конфиг
enable sharing 1 grouping 1-2 algorithm address-based L3_L4 lacp
enable sharing 3 grouping 3-4 algorithm address-based L3_L4 lacp
enable sharing 7 grouping 7-8 algorithm address-based L3_L4 lacp
enable sharing 11 grouping 11-12 algorithm address-based L3_L4 lacp
configure sharing 3 lacp activity-mode passive
configure sharing 7 lacp activity-mode passive
порты 1-2 лацп в сторону х450
видно что не видит мак патнера.
Теперь конфиг х450(сейчас работает с 650)
Slot-1 under.s.ki.x450-stack.3 # sh switch
SysName:          under.s.ki.x450-stack
SysLocation:      szk
System MAC:       02:04:96:27:AB:8C
System Type:      X450a-24x (Stack)
Recovery Mode:    All
Current Time:     Wed Apr 29 08:19:05 2015
Boot Time:        Tue Jun 24 00:27:57 2014
Boot Count:       144
System UpTime:    309 days 7 hours 51 minutes 7 seconds
Slot:             Slot-1 *                     Slot-2
Current State:    MASTER                       BACKUP (In Sync)
Image Selected:   secondary                    secondary
Image Booted:     secondary                    secondary
Primary ver:      15.3.1.4                     15.3.1.4
Secondary ver:    15.3.2.11                    15.3.2.11
primary.cfg       Created by ExtremeXOS version 15.3.2.11
                 1914689 bytes saved on Mon Apr 27 22:31:44 2015
Slot-1 under.s.ki.x450-stack.1 # show sharing
Config    Current    Agg       Ld Share    Ld Share  Agg   Link    Link Up
Master    Master     Control   Algorithm   Group     Mbr   State   Transitions
  1:8    1:7        LACP      L3_L4       1:8        Y      A        0
                              L3_L4       2:8        Y      A        0
                              L3_L4       1:7        Y      A        0
                              L3_L4       2:7        Y      A        0
 1:10   1:10        LACP      L3_L4       1:10       Y      A        3
                              L3_L4       2:10       Y      A        3
 1:22   1:22        LACP      L3_L4       1:22       Y      A        0
                              L3_L4       2:22       Y      A        0
 1:23   1:23        LACP      L3_L4       1:23       Y      A        0
                              L3_L4       2:23       Y      A        0
 1:26   1:26        LACP      L3_L4       1:26       Y      A       11
                              L3_L4       2:26       Y      A        6
  2:5    2:5        LACP      L3_L4       2:5        Y      A        1
                              L3_L4       3:23       Y      A        0
Number of load sharing trunks: 6
enable sharing 1:26 grouping 1:26, 2:26 algorithm address-based L3_L4 lacp
enable sharing 1:23 grouping 1:23, 2:23 algorithm address-based L3_L4 lacp
enable sharing 1:10 grouping 1:10, 2:10 algorithm address-based L3_L4 lacp
enable sharing 1:22 grouping 1:22, 2:22 algorithm address-based L3_L4 lacp
enable sharing 1:8 grouping 1:7-8, 2:7-8 algorithm address-based L3_L4 lacp
enable sharing 2:5 grouping 2:5, 3:23 algorithm address-based L3_L4 lacp
configure sharing 1:26 lacp activity-mode passive
порты 1:26 и 2:26 лацп в сторону 670
на х650 с софтом :
* x650-Under.1 # sh switch
SysName:          x650-Under
SysLocation:      l9
System MAC:       00:04:96:51:BF:1D
System Type:      X650-24x(SSns)
Recovery Mode:    All
Current Time:     Wed Apr 29 08:21:49 2015
Boot Time:        Tue May  6 02:49:02 2014
Boot Count:       40
System UpTime:    358 days 5 hours 32 minutes 46 seconds
Image Selected:   primary
Image Booted:     primary
Primary ver:      12.5.2.6
Secondary ver:    12.4.3.5
primary.cfg       Created by ExtremeXOS version 12.5.2.6
                 2202287 bytes saved on Wed Apr 29 05:53:02 2015
все работает.
Подскажите куда копать? что делать?
Времени не было ребутить 670 что бы загрузится с
и пробовать на этой прошивке
Да и забыл добавить
Лацп со стороны х670 разбирали, ничего не поднималось. Со стороны х450 стека, возможности не было разобрать
переделывать на статический порт-ченел пробовали?
Не пробовали, но разбирали полностью шаринг на х670, результат был тот же, порт поднят, маков не видно от х450.
Аналогичная конфигурация на 650 работает сразу, как только патчкорды переставил, все заработало.
yaadoo, понятно что маков нет, ченел-то только с одной стороны поднялся. вообще, зачем lacp passive? сделайте аналогично с обеих сторон
lacp passive
Это лацпы в сторону жунипера, тут все хорошо
Позже сделаю downgrade прошивке на х670 и посмотрю что получится
