Добрый день, коллеги. Имеется следующая схема:
R1(Mikrotik) --- GRE over IpSec --- R2 (ASR1001) -ethernet- R3(Mikrotik)
Тоесть между R1 - R2 поднять GRE туннель поверх IPSEC в транспортном режиме.
Туннель имеет следующий вид:
interface Tunnel1061701
bandwidth qos-reference 5000
ip address 172.26.170.1 255.255.255.252
ip mtu 1400
ip access-group DMZ_IN in
ip access-group DMZ_OUT out
ip tcp adjust-mss 1360
ip policy route-map Forward_GlobalIP
ip ospf network point-to-point
ip ospf mtu-ignore
ip ospf cost 10
qos pre-classify
tunnel source 1.1.1.1
tunnel destination 2.2.2.2
tunnel protection ipsec profile IPSec-AES
service-policy input Tunnel_5M_IN
service-policy output Tunnel_5M_OUT
end
На нем соответственно висят 2 куоса
service-policy input Tunnel_5M_IN и service-policy output Tunnel_5M_OUT
Они имеют следующий вид:
class-map match-all SNMP
match access-group name SNMP
class-map match-all TELNET
match access-group name TELNET
class-map match-all WSUS
match access-group name WSUS
class-map match-all WINBOX
match access-group name WINBOX
class-map match-all EMULFR
match access-group name EMULFR
class-map match-all OSPF
match protocol ospf
class-map match-all OPEN
match access-group name OPEN
class-map match-all ICMP
match protocol icmp
class-map match-all HTTP
match access-group name HTTP
class-map match-all Web_Base
match access-group name Web_Base
class-map match-all ADM_SRV
match access-group name ADM_SRV
class-map match-all FTP
match access-group name FTP
class-map match-all MRU_SRV
match access-group name MRU_SRV
class-map match-all RDP
match access-group name RDP-QOS
class-map match-all NTP
match access-group name NTP
class-map match-all SIP
match access-group name SIP
class-map match-all HTTPS
match access-group name HTTPS
class-map match-all MCAFE
match access-group name MCAFE
class-map match-all RTP
match protocol rtp
class-map match-all DNS
match access-group name DNS
class-map match-all 1C
match access-group name CITRIX
class-map match-any TunnelCls
match any
policy-map Tunnel-child
class OSPF
 bandwidth percent 2
class ICMP
 bandwidth percent 1
class NTP
 bandwidth percent 1
class TELNET
 bandwidth percent 1
class RDP
 bandwidth percent 5
class 1C
 bandwidth percent 10
class WINBOX
 bandwidth percent 2
class SNMP
 bandwidth percent 2
class SIP
 bandwidth percent 5
class DNS
 bandwidth percent 2
class HTTP
class HTTPS
class FTP
 bandwidth percent 2
class EMULFR
 bandwidth percent 2
class WSUS
 police cir percent 2
class MCAFE
class MRU_SRV
 bandwidth percent 30
class RTP
 bandwidth percent 2
class OPEN
 police cir 512000
  violate-action drop
class class-default
 fair-queue
 random-detect
policy-map Tunnel_5M_IN
class TunnelCls
 police rate 5000000
  violate-action drop
policy-map Tunnel_5M_OUT
class class-default
 shape average 5000000
 police rate 5000000
  violate-action drop
  service-policy Tunnel-child
Физический интерфейс который является SRC для туннеля:
interface GigabitEthernet0/0/3
ip address 1.1.1.1 255.255.255.240
ip nbar protocol-discovery ipv4
negotiation auto
Физический интерфейс за которым находится R3:
interface GigabitEthernet0/0/0
description # c3750e_00_s1 Uplink PO-10 #
no ip address
negotiation auto
channel-group 10 mode active
interface GigabitEthernet0/0/1
no ip address
negotiation auto
И вот тут начинаются непонятки.
Делаю BW test c R3 на R1
Протокол UPD, размер 1500
Направление Both
Результат:
RX/TX - 12.0 kbps/4.2 Mbps (обратите внимание на направление)
Первая мысль, что то в политике input (поскольку именно RX для R3 является input Tunnel_5M_IN на туннеле R2)
Убираю эту политику с интерфейса и снова запускаю тест:
RX/TX - 11.9 kbps/18.5 Mbps
Почему то поменялся TX а не RX (!!)
Возвращаю политику input Tunnel_5M_IN, удаляю output Tunnel_5M_OUT и запускаю тест:
RX/TX - 7.5 Mbps/4.1 Mbps
Как видно таким образом работает. НО 1) не работает куос на IN 2) Направления перепутаны местами.
То что должно быть INPUT влияет на TX, а то что должно быть OUTPUT влияет на RX.
С протоколом TCP ситуация в корне не меняется.
Софт на ASR asr1001-universalk9.03.13.00.S.154-3.S-ext.bin
Кто-нибудь может подсказать? А что что-то глаз замылился.
Спасибо.
