flashwolf Posted January 1, 2005 Posted January 1, 2005 Как я понимаю, большинство присутствующих представляет себе суть проблемы. Для остальных приведу пример: # ping -c 1000 -f -s 512 10.1.2.4 PING 10.1.2.4 (10.1.2.4): 512 data bytes ................................................................................ ........................... --- 10.1.2.4 ping statistics --- 1000 packets transmitted, 745 packets received, +150 duplicates, 25% packet loss round-trip min/avg/max/stddev = 4.428/34.379/75.297/18.716 ms и еще один: # ping -s 1024 -c 10 10.1.2.2 PING 10.1.2.2 (10.1.2.2): 1024 data bytes 1032 bytes from 10.1.2.2: icmp_seq=0 ttl=64 time=8.523 ms 1032 bytes from 10.1.2.2: icmp_seq=1 ttl=64 time=12.485 ms 1032 bytes from 10.1.2.2: icmp_seq=2 ttl=64 time=8.933 ms 1032 bytes from 10.1.2.2: icmp_seq=3 ttl=64 time=8.030 ms 1032 bytes from 10.1.2.2: icmp_seq=4 ttl=64 time=10.191 ms 1032 bytes from 10.1.2.2: icmp_seq=4 ttl=64 time=11.662 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=4 ttl=64 time=14.586 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=4 ttl=64 time=17.852 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=9.138 ms 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=9.770 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=10.438 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=11.144 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=15.382 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=5 ttl=64 time=20.829 ms (DUP!) 1032 bytes from 10.1.2.2: icmp_seq=6 ttl=64 time=8.949 ms 1032 bytes from 10.1.2.2: icmp_seq=7 ttl=64 time=8.869 ms 1032 bytes from 10.1.2.2: icmp_seq=8 ttl=64 time=8.522 ms 1032 bytes from 10.1.2.2: icmp_seq=9 ttl=64 time=12.208 ms --- 10.1.2.2 ping statistics --- 10 packets transmitted, 10 packets received, +8 duplicates, 0% packet loss round-trip min/avg/max/stddev = 8.030/11.528/20.829/3.454 ms бридж - DWL-2000AP+ HW:B1 FW:2.0 в наличии имеется уже около десятка - все страдают этим нюансом, вне зависимости от режима работы и длины линка (на маленьких линках - 1-2м - дупов правда мало) конкретные примеры приведены для случая, когда DWL-2000AP+ работает как клиент к TEW-411BRP в режиме AP есть ли методы борьбы с данным явлением? Вставить ник Quote
MaXToP Posted January 1, 2005 Posted January 1, 2005 есть ли методы борьбы с данным явлением? Для д-линка это нормальное явление - проблема с ACK тайменгом уже не однократно обсуждалась на форуме. Относительно этого оборудования поможет только замена его. Вставить ник Quote
flashwolf Posted January 1, 2005 Author Posted January 1, 2005 MaXToP, возможно, есть какие-то beta-версии прошивок? судя по форуму на длинк.ру, для A-версий hardware проблема вроде решена... или, возможно, в него можно залить "чужую" прошивку - оборудование-то явно не "уникальное"? Вставить ник Quote
doubtpoint Posted January 2, 2005 Posted January 2, 2005 На версии v115b13(вроде даже на 1.14) эта проблема решена. На более старых версиях существенно снижается количество дупов при установки фиксированной скорости. PS: Извиняюсь. Не заметил, что у тебя версия B. Выше сказанное относится к А1, А2. Про В не знаю. Вставить ник Quote
Guest Posted January 3, 2005 Posted January 3, 2005 Какая прога умеет показывать DUPы? Вставить ник Quote
flashwolf Posted January 3, 2005 Author Posted January 3, 2005 в смысле - какая? обычный ping... под любой нормальной ОС - хоть под Linux, хоть под FreeBSD Вставить ник Quote
Guest Posted January 3, 2005 Posted January 3, 2005 А как правильно задавать этот пинг?? Вставить ник Quote
flashwolf Posted January 12, 2005 Author Posted January 12, 2005 в смысле - как правильно? обычный пинг... по всем нюансам - man ping ;) Вставить ник Quote
doubtpoint Posted January 14, 2005 Posted January 14, 2005 izuware, Вроде да, покрайне мере пока прошивки на них глючные. Вставить ник Quote
Guest Posted January 14, 2005 Posted January 14, 2005 это у неё враждённое... ja, ja ... они самые ... замечены за TI и еще как ни странно, что наводит на определенные мысли, за PRISM GT ... за atheros такого глюка пока небыло замечено ... Посему, рыдать и плакать :)))))) Посему Блинк, вернее GL, в DWL-2000AP+ (они же GL-2454AP) вставляет уже карточки на чипе atheros :D А как же со стройной нУмберацией ;) Вставить ник Quote
Guest Posted January 14, 2005 Posted January 14, 2005 жаль .. а что сейчас в Москве можно найти из точек доступа 802.11b взамен длинк ? стоит ли ориентироваться на openWRT ? кто держал сие в руках ? Вставить ник Quote
Guest Posted January 14, 2005 Posted January 14, 2005 в DWL-2000AP+ (они же GL-2454AP) вставляет уже карточки на чипе atheros :D то есть легко сегодня купить не горбатую железку и у длинка ?? и как его в прайсе узнать? Вставить ник Quote
Guest Posted January 14, 2005 Posted January 14, 2005 GL-2454AP версий железа с этой маркировкой очень много ... сегодня купить не горбатую железку и у длинка ? на чипе atheros у блинка пока таких нет ... Вставить ник Quote
lamer Posted January 15, 2005 Posted January 15, 2005 Эх..., какое было начало: Посему Блинк, вернее GL, в DWL-2000AP+ (они же GL-2454AP) вставляет уже карточки на чипе atheros :D и какой конец: на чипе atheros у блинка пока таких нет ... А жаль. Вставить ник Quote
Tet Posted January 15, 2005 Posted January 15, 2005 Эх..., какое было начало: Посему Блинк, вернее GL, в DWL-2000AP+ (они же GL-2454AP) вставляет уже карточки на чипе atheros :D и какой конец: на чипе atheros у блинка пока таких нет ... А жаль. Странно - 2000(без плюса), 2100(без плюса) - на сколько я знаю содержат в себе вожделенный atheros. Только это напоминает ложку меда в бочке D-ерьма - флешка маленькая... Для справки - "ДУПА" переводится с украинского как "ЖОПА". Вставить ник Quote
izuware Posted January 17, 2005 Posted January 17, 2005 GL-2454AP версий железа с этой маркировкой очень много ... подскажите марку у конкретного продавца? планет там, зком какойнить или асер с кучей ещё маркировщиков ??? а то создается нежелание брать не ддлинк :) знаю что г... зато знаю какое и паяльник вотон =о) а возьмёшь новое, и хлоп те, придётся все сначала... Вставить ник Quote
